Hi all, what is the maximum bore you can safely take a 400 out to? My WT code 400 is already .060 and I would like to freshen it up.
Some can be bored more than .060 and some can't. I've bored one .065 after having it soniced, but I've found blocks that couldn't go over .030. All in all, you need to have it sonic checked. I figure that a cylinder of .150" on the thrust side is the minimum for a non filled block, about .090 on the others.
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. [email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
What kind of availability is there on Poncho pistons over .060?
You could also sleeve the block and go back to standard. It's about $50 a cylinder around here - may end up cheaper than custom pistons.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
