1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 04-25-2007, 09:34 AM
455z4ever's Avatar
455z4ever 455z4ever is offline
Default Puttin a better rear in the 79 lemans-am
Any of you G body guys put the 66 to 70 Coil spring rears in your G bodys? I went to malibu thunder to ask, but haven't gotten logged in yet.. I know SSM made a conversion kit to do it, but didn't they go outta business?? Any pics, preffered year for the rears in terms of width ect??
Old 04-28-2007, 09:48 PM
iowapub's Avatar
iowapub iowapub is offline
nope, still building stock crap. Try maliburacing.com
They know their G-bodies!
Old 04-30-2007, 09:29 PM
key006 key006 is offline
Default 12 bolt under a "G" body
Are you wanting to put a 12 bolt under a "G" body? I put a 12 bolt (70) Monte Carlo under my 78 Malibu using the South Side Machine bar kit #1328. I think they are out of business now but you may find one on E-Bay. I actually sold mine there last year (went with ladder bar/coil overs). The key to using these wide rear ends and getting the tires inside the wheel well is a wheel with a 5 1/2 back spacing. My wheels were 8" wide. I ran 275X15X60 Hoosier Quick Time tires or 28X11.50X15 ET streets. If you can find one, a Grand National or "T" Type 10 bolt 8.5 rearend is a better choice and will bolt right in using your existing control arms, etc. Hope I have helped.
Old 05-01-2007, 07:53 PM
dirty joe dirty joe is offline
well, the only thing you have to do is get the right upper control arms that are made for this swap. everything, else, bolts right in. but, you will have to get a different back spacing wheel since it is 1" wider on each side. but, there is a guy on ebay that sells double adjustable upper and lowers for this swap for like $280 buy it now
i love racing at the track
Old 05-04-2007, 07:19 AM
zbuickman's Avatar
zbuickman zbuickman is offline
84-87 T-Type, GN had the 8.5 with 3:42 gears and 86-87 442 had the 8.5 with 3:73 gears. and they are bolt in
Brent
65 "X"vert
84 T-Type
my cars
Old 05-07-2007, 03:56 PM
monzaz's Avatar
monzaz monzaz is offline
Default g-body 12 bolt rear
I can make you up a 12 bolt g-body rear that will only need the upper control arms and I can even supply them for 150.00 if you like. all the rest of the mounting points will be stock and the length will only be 1" wider that is a 1/2" on each side. I can make it exact but the axles will be more expensive. 28 1/2 is not as common as the 29". PLUS you will have 30 spline axles to boot with this set-up. Race away. Let me know. Jim
about 1250.00 with out control arms. But your getting a 12 bolt not and 8.5
New axles
New eaton type clutch posi
New yukon axles
New mega bearing kit with all new seals bearings (even axle bearings and seal)
Made from stock GM housings so all replacement parts can be bought from any auto part store in the future. NO Crazy expensive trick stuff just good strong off the shelf parts .
Jim Mitschke
J D Race and Restoration
Richfield, Oh
JDRACE3@GMAIL.COM
Old 05-09-2007, 04:07 PM
shotgun shotgun is offline
PY Staff -Tech
I have an empty 12 bolt housing narrowed and set up for ladder bar.It bolts in.
Email if interested
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date 10.00@130.92 mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
