how hard is it to change brake lines on a 64 2dr 4spd hardtop?
Can you snake the front passenger line under the motor? How about the front to back line, and rear lines? thanks for any help. |
It would be easiest to buy prebent lines from InLine Tubing.
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield ------------------------------ 2015 Jaguar F-Type 340hp Convertible, Polaris White/Ebony Interior 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red/Black Interior 1965 Chrysler 300 Convertible, 383/727TF, Factory Air, Spanish Red/Red Interior/White Top |
thanks, i plan on buying pre-bent lines.
Can you install the new lines without too much trouble? Can you get the front passenger line under/around the motor without too much trouble? How about the "front to back" and "rear" lines? sorry, my original question was not very clear... |
Patience, a lift and a couple of friends and it can be done. There are clips holding the brake line to the front crossmember, they might be a small problem. I don't recall if you will be able to get to them without jacking the engine up a little. The rest of the lines should be ok.
More pictures of my former Goat: http://www.barrett-jackson.com/appli.../w_search.aspx My old car is listed in the 2007 Scottsdale Auction, Lot #1016 - $60K And in the 2008 Scottsdale auction, Lot #960 - $80K Eventually sold by Brighton Motor Sports in Scottsdale, AZ -$89,900 |
