Old 05-28-2007, 01:15 PM
7D9TA's Avatar
7D9TA 7D9TA is offline
1979 TA. low 12 second 400 on 93 octane pump gas
This site answered many of my questions while building this car. Used key word searches to get most of my answers. Thx to everyone for putting this information out there for ppl to learn from.
1973 2 bolt 400 block bored .030 over ARP main and head studs
Block hard filled to bottom of center freeze plugs
TRW forged pistons
Proline rods from P-dude
400 crank turned .010/.010
Total Seal gapless rings
Rotating assembly balanced
Stock oil pan, oil pump
P-Dude crank scraper
Tomahawk Windage tray
#62 heads hand ported by me using Jim Hand/Pete McCarthy Method.
Used 1.66 sizing valve for intake and 1.60 for exhaust
Exhaust crossover filled with aluminum
Chambers opened to 78 CC
Bronze guides
Stock 2.11 1.77 valves reinstalled
No flow numbers
Cam is a Crane H-296-2
234/242 @ .050 296/304 advertised
.520/.532 lift with 1.65 rockers
112 LSA
Performer RPM intake with water crossover divorced and the exhaust crossover cut off. Plenum center divider cut down 1 inch
Gasket matched to heads
Holley 750 Vac Second carb with air horn milled off
Mallory 140 GPH electric pump and return style regulator.
Sump welded to bottom and fitting for return line welded to front top of stock tank.
MSD 6AL and Petronix Flame Thrower coil. Big cap HEI. Taylor 8MM wires
Hooker headers 1 3/4 with Pypes 3 inch exhaust with X pipe.
DynoMax Ultra Flow mufflers
400 Turbo tranny with manual VB.
Hughes 3000 Converter
Dana 60 rear end with 3.73 gears
M/T ET Street tires 275/60/15 on 8x15 rims
Stock leaf springs with slapper bars.
3710 race weight with me in it
60 ft 1.72
1/8 ET 7.78
1/8 MPH 88.27
1/4 ET 12.20
1/4 MPH 109.84
  #42
Old 05-28-2007, 07:32 PM
GTOLIB GTOLIB is offline
Default 428
435
stock crank,
stock rods ,shot peened and polished,arp bolts
sealed power pistons .040
#62 heads ported [email protected]
Ultradyne solid cam ,com cams Mag 1.5 rockers
263/272 .556 108sep 106 IC
HEI dist Msd 6A ext coil
timing total 12/ 32 total
Torker 2 intake , also used . Holley Dom ,RPM,Victor
Holley 850 ,modified
Carb shop Holley blue pump
BG reg #8 line
T400 rev manual.trans brake
8" ati 4100stall slipage 7%
12bolt/ 4.56
29.5 slicks 10.5 worn
shift 6400 trap 6200
Hedman 1 3/4 x 3in
3in exh to rear
40s FM+dumps
weight 3650
60ft 1.71-1.74
best 60ft 1.64
11.9/111 ave
best 11.86 111.9
Ran 12.6s/106 with stock heads and hyd cam
click link to garage for more
  #43
Old 06-07-2007, 10:02 PM
joes455 joes455 is offline
Default Pontiac 455
76 TA
Eagle crank
Cat rods
trw pistons
edelbrock heads cleaned up
CC solid roller 262/268 112 custom
2" SC hookers
rpm intk
830 QFT
locked timing msd 6a starter retard
turbo 400 redneck 3500 stall
3.42 screw
3800 lb with me
ran it last night at Gainsville which ran best time so far
11.75 @117 60ft was only 1.815.I went easy on launch ,didn't want to break anything.
  #44
Old 06-07-2007, 10:14 PM
Nickv's Avatar
Nickv Nickv is offline
67 GTO
455+0.030 over
SD rods
TRW Pistons
80# oil pump
Torker 1 intake with 1" spacer
825 CFM Barry Grant, mechanical secondaries. #86,#94 jets, No power valves
Box stock 87cc E-heads
Comp Cam 292 cam with 1.65" HS roller rockers
Mallory Unilite with MSD 6 ignition with retard box when hitting the spray
Hedman Hustler headers with full 3" exhaust
Stock radiator with shroud and flex fan
TH400 with shift kit
Redneck 3000 stall converter
12 bolt rear with 3:73 gears
15 gallon fuel cell with Holley blue pump. 2nd Holley blue pump for nitrous system when spraying.
Battery in Trunk also.
Weighs around 3500lbs.
Best ET on motor 11.5@118 mph Best Et on 150HP shot of Nitrous 10.8@121.
This car is never trailered anywhere, including driving to dragstrip. This car is truly a street car. I can drive this car for hours with no overheating issues or problems even in the full heat of Summer.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecargalore.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger Scat Pack 392, 6 speed
2021 Ford Explorer
  #45
Old 06-15-2007, 11:22 AM
JoePapa's Avatar
JoePapa JoePapa is offline
My 400 has been a pretty good combo and took years of abuse. My best all motor pass was 12.50. This setup consistently ran anywhere from 12.6 to 12.9 depending on heat, humidity, and motor temp. The cars best 60’ time is 1.64 but I’ve been unable to duplicate that and it usually runs anywhere from mid 1.7’s to 1.9 range. I need to work on this area. This motor liked to rev to 6000 rpm. The car is a ’69 Firebird 400 and race weight is 3800 pounds.
Engine Modifications:
'69 400 2 bolt block bored .030
Deck height set to zero
#62 Iron heads, minor bowl blend – milled about .015 - no flow numbers.
Stock 10/10 crank
Eagle H-beam rods with ARP fasteners
Forged TRW pistons
Crower 60211 cam/lifter set
Crower 1.6:1 roller rockers
Mallory Hyfire IV
Mallory Mechanical magnetic distributor
Edelbrock Performer RPM Intake, top 1” milled out of plenum divider
825 CFM Mighty Demon
Transmission:
’69 Muncie has been upgraded with Super Case, Iron Mid plate, M22 wide ratio gears
McLeod SFI Aluminum Flywheel
11” clutch
Rearend:
Dana 60 with 4.10 gears and 35 spline Strange axles and Aerospace disc brakes
Suspension
Multi-leaf rear springs
QA-1 Drag Race coil over shocks/springs up front
CE adjustable drag shocks in back
1 1/8” sway bar up front
Cal-trac’s
A new configuration is in progress and the changes are:
Motor bored .030 – dingle berry hone to remove glaze (bores are good)
#62 Iron heads – owner ported using Jim Hand method and Pete McArthy video.
275 / 188 cfm @ 500 lift on intake / exhaust, respectively
New Manley valves
Probe SRS Pistons with Mahle rings
* Converting to Solid flat tappet cam – not selected yet
I’ll post final configuration changes and results once I get them.
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
  #46
Old 06-17-2007, 11:12 PM
rkm1003's Avatar
rkm1003 rkm1003 is offline
MOTOR- '69 400 YA, .060 over, stock crank, SpeedPro L2262F pistons, CAT H-beam rods, HS 1.65 rockers, Crane cam kit # 283802, Edelbrock 72cc heads, Performer RPM Intake, Q-jet(waiting on new one from Cliff), 2" MadDog Headers, RobbMc starter. Will be installing Summit 3" cutouts with DMH electric cutouts in a couple weeks.
DRIVETRAIN- 200-4R, Transgo HD shift kit, 12 bolt, 4.10 Posi built by Pyle Bros. Hurst V-matic II shifter.
Took car to San Antonio Raceway last year, ran 17's, hence the new 400 was called for. Broke cam in this afternoon, ran around for about hour today.........think I can kiss 17's goodbye ;-).
My car is a driver first, take to track couple times a year. Last November, drove my car from Corpus Christi, to SAR for racing, 300 mile roundtrip, then following weekend, drove it to Houston 400 mile roundtrip, and was entrant in Autorama, got Honorable Mention, was pretty cool.
Look forward to going back to SAR and posting some "lower times" Kelly
Name:	rebuilt 1 (Medium).jpg
ID:	94949   Click image for larger version
Name:	Cragars 004 (Large).jpg
ID:	94950   Click image for larger version
Name:	TD Kel @ tree2 (Medium).jpg
'69 Pontiac 400 YA, .060 over, stock crank, 10.2:1 comp, CAT H-beam rods, HS 1.65 rockers, Crane cam 248/252 660 lift, Edelbrock 72cc heads ported 300 cfm, Performer RPM Intake, Ruggles 800 cfm Q-jet, Summit 140 gph electric fuel pump, 12 bolt 4.10 posi, 200-4R, Transgo HD shift kit, 2800 stall, aluminum radiator, 2" MadDog Headers, DMH 3" cutouts.
12.51 et @ 111 mph
The Following User Says Thank You to rkm1003 For This Useful Post:
  #47
Old 06-26-2007, 11:43 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
Car: 1968 LeMans
Weight: 3750 wet, no driver
Engine: 350 (Stock 2BBL was 265hp/335ft. lbs)
Carb: Quadrajet (from `71 Pontiac, rebuilt), choke stove functional
Compression: 9.2:1
Heads: Stock
Intake: `68 Cast
Transmission: Rebuilt TH350 (from `71) with B&M Transpak. Hurst V2 shifter.
Converter: 2,000 Stall
Rear End: 10 bolt new Eaton Posi with 3:55’s
Tires: 235/45R17
Cam Specs: Summit 2800
Operating Range: 1500-4500 RPM
Ignition: ProForm HEI for now. Dave's Small Body HEI planned
Exhaust: Stock Manifolds mated to a 2 ½” mandrel bent pipes, X-pipe with flowmaster 40 series mufflers and stock 2" tail pipes and tips.
Fuel System: Stock (new stainless steel line)
Current ET: CAN'T WAIT TO FIND OUT!
Many pics and details on my web site, link in signature.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
  #48
Old 07-03-2007, 03:31 PM
misaac misaac is offline
1964 Tempest Custom wagon
1972 2 bolt 455 +.060
TRW flattops, stock rods ARP bolts, stock crank
1971 96 unported, gasket matched, compression 9. something
RPM manifold secondary divider cut .500, Holley 830 DP
(borrowed NOS 150hp Cheater plate)
Carter M6907 pump, 3/8" line from tank, no return
UD 288/296 hydr. 231/239 @.050, .485/.507 w/1.5 Magnums, 112LSA
MSD ready to run distributor, Blaster 2 coil
Dougs 1.75 coated, 3" X-crossover, 3" welded Ultra flows to 2.5 tailpipes
THM400 w/TransGo kit, HD sprag, 3.5 steel shaft w/1350 Spicer joints
'68 GTO 10 bolt w/Auburn Pro Series posi, 3.23, stock axles (YIKES)
old MT ET drags, 28x10 14" rim (64 spinner hubcaps on the street)
A-body power disc brakes front, 9.5" drums rear
4000 pounds with driver, 1/4 tank, full bottle, no rear seat
Typically 13.0's @103-104 on engine only. 1.8-1.95 60ft. Best 12.85@104
On the bottle, 11.75@113 1.63-1.65 60ft. Best 11.69@115
When it was just a 66 Tri power, RA manifolds, and open exhaust, it ran 13.1@103.
I know there is more to be found in this set-up. This is a great thread!
  #49
Old 07-03-2007, 08:27 PM
kookykrispy's Avatar
kookykrispy kookykrispy is offline
Talking
Here's the engine that was previously in my gto
Block: '77 400 bored .30 over 2 bolt mains with ARP studs
TRW forged pistons
Speed-pro moly rings
Stock rods, ARP bolts
Stock crank, .020/.020 under
fully balanced assembly
high volume oil pump
homemade crank scraper
Heads: '67 670's bone stock
stock rockers
crane dual valve springs
Cam/lifters: Summit 2802 224/234 @.050 .465/.488 lift 114 LSA
dynomax headers (didn't fit the gto very well)
3" full exhaust
Summit fully welded mufflers
HEI with accel supercoil, taylor wires
MSD 6al
milodon water pump
MT covers
Holley 750 vac. secondaries
With the timing dialed in, it ran good on super unleaded. Tough, rowdy sounding idle, but very streetable. Strong idle with plenty of vacuum, lots of low-end torque and it really started to scream above 2500.
I never ran this engine at the dragstrip... but I can say it was a very fun street engine in my 4 speed 67 GTO with 4.10 rear gears. My guess is it would be capable of somewhere in the 14's or maybe 13's in the quarter.
"Keep your foot hard on that pedal
Son, never mind them brakes
Let it all hang out 'cause we got a run to make!"
  #50
Old 07-03-2007, 08:55 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
1969 GTO
3965 #
455 +.030 bore +.024 stroke
9.8:1 comp ratio
Factory cast crank
factory cast rods
TRW forged pistons
Stock oiling system
6X-4 heads ported by me 250 intake 200 ex
Ultadyne 239/247 hyd cam w/rhodes lifters and comp magnum rockers
port matched torker 2
Holley 850 DP
Hedmen 1 3/4 headers w/3"exhaust. dynomax muffs
Stock HEI
TH 400 w/continental 10" that stalls around 2500-3000
12 bolt rear w/3.73 gears
Best ET in Phoenix (around 2000 ft DA at the time)
60 ft 1.675
ET 12.162
MPH 110.508
I have won a LOT of money with this car (legally)
2003 Div 7 Summit Street champion
2003 Speedworld track champion (street)
Currently the car is retired from racing and is only driven on the street
Name:	Pontica Pictures of GTO Lemans Firebird Transam Catalina Bonneville.jpg
  #51
Old 07-05-2007, 01:18 PM
runningbwdog's Avatar
runningbwdog runningbwdog is offline
Hi,
1968 GTO
Mine is strictly a street car.
1970 YH 455 bored +0.030" = 462 cid
Cast #15 heads with 1.96" intakes and 1.77" exhausts and hardened seats, screw in studs, elongated pushrod holes, gasket matched on the intake ports, teflon valve seals.
Stock crank turned 0.020"
Stock reconditioned rods
Rotating mass balanced.
Pistons to give 9.34:1 compression
Comp Cam XE-268 cam, 995-16 dual valve springs, 852-16 hydraulic lifters, polylocks.
Cam degreed at 107 degrees.
Stock rockers (1.5:1)
Stock cast iron intake 68 GTO
Reworked Q-Jet by Cliff R.
Stock single snorkle air cleaner.
Reworked points distributor by Sun Tuned.
Stock log exhaust manifolds
Pypes 2.5" X-Pipe exhaust system
McLeod Street Twin Pressure Plate and Clutch disk.
Stock M20 4 Speed
3.55:1 open differential
Run it on Shell 93 Octane gas.
No idea on 1/4 mile time or speed.
Chassis dyno said 464 ft/lbs of torque.
Mike
Name:	GTO on Grn Mt low res 2.jpg
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels
  #52
Old 07-05-2007, 02:58 PM
tom s tom s is offline
new motor for the 69 T/A
4.155 bore 3.375 stroke,366CI,10-1CR
303 RA V heads 328-221 @28 @600 2.19I 1.78E
303 RA V block short fill roller bearing cam
BME alu rods 1.84R/S
forged crank 2 1/2 mains 2.100 rods
factory dual plane intake 780 Holley
236-242@50HR cam 110LC
1.65 H&S rockers with 572-594 lift
448HP@5850 427TQ@5200
  #53
Old 07-09-2007, 06:16 PM
mrtonegto's Avatar
mrtonegto mrtonegto is offline
Talking My new 455 Build
Recently (should read: "Finally!") got the 455 up and running in my '65 GTO post car. Only has about 250 miles on it right now - due to change the oil tomorrow before putting any more miles on it. So far I'm extremely pleased with the Rhoads lifters, I'm running cast alum. valve covers and the noise is not excessive to me at all (like someone else said: sounds like a sewing machine). Waiting for Dave's small-body to arrive and my completion of the '66 TriPower before I can say "it's done" (powertrain).
1975 455 (heavy webbed) .060 to 467 cu. in.:
- 9.3:1 compression ratio
- zero decked, plate-honed, balanced motor
- ground off all interior flashing, smoothed exterior block surfaces
- 1972 "N" reconditioned crankshaft
- TRW L2359F forged pistons
- Sealed Power rings
- Clevite 77 bearings throughout
- Fel-Pro Gaskets
- Brass freeze plugs
- Melling M54D oil pump, welded 5/8" pick-up
- Cloyes Street/Strip timing chain set
- SCAT rods 6.625", press fit
- PowerForce harmonic balancer
- BOP rear main seal
- Stock HEI with adjustable VA and rev-limiter (awaiting a Dave's small-body)
5C heads:
- Self ported/polished/relieved
- ground for potential use of 1.65 rockers
- R.E.V. stainless 2.11/1.77 valves
- 3-angle valve cut
- Viton valve seals
- Comp Cams 995 valve springs (120 seat/310 open)
- Chrome moly retainers and locks
- Comp Cams chrome moly pushrods
- 7/16" Comp Cams rocker studs
Valve Train:
- Crower 60243 camshaft:
- 228*Intake 235* Exh @ .050"
- 112* LSA
- 108* ICL
- .479/.494 w/1.5 rockers
- Rhoads V-Max all 16 @ .020"
Carburetion: (temporary until '66 TriPower is completed)
- Edelbrock Performer RPM
- Holley 780 DP, #74 primaries
- HD Jegs fuel pump
Exhaust:
- Ram Air coated exhaust manifolds
- 2.5" mandrel bent with X-pipe
- TurboMax 17749 mufflers
- custom stainless splitters, exiting @ stock location
Transmission:
- totally rebuilt Muncie M20
- Super Case w/cast iron midplate
- Orig. Hurst Comp+ linkage
Rearend:
- totally rebuilt '67 GM 12-bolt
- bearing-retainer-ends welded on
- 3.31 positraction
- Tom's Kick-Ass axles
- boxed lowers
- rear frame supports
- polygraphite bushings all around
- rear sway bar (1.25" sway bar up front)
"Listen to her why-ee-eye-ine......... Listen to her why-ee-eye-ine"
1965 GTO Post Coupe, Burgundy w/Parchment, 467, Crower 60243, Rhoads V-Max, Ported 5C's, JB Roller Rockers, Original '66 Tripower, Dave's Small-body HEI, RA Exh Manifolds, 2.5" Exh X-pipe w/Super Turbo's and SS Splitters, Dual Camaro Fans, Tremec TKO 600, 3.91 12-Bolt Posi w/Bearing Retainers, Complete Frame-off, Boxed Frame, 4X Discs with Hydro-boost and Volvo Pump, EPAS Conversion
  #54
Old 07-14-2007, 05:38 PM
80transam565's Avatar
80transam565 80transam565 is offline
mid 70's 400
stock bottom half
March serpentine belt kit
summit 2802 cam 224/234 .465/.488
edelbrock torker 2 intake
750cfm carter afb carb
unworked 6x - 8 heads
RAM AIR 3 exhuast manifold
turbo 350 with B&M shift kit
2400 stall
B&M mega shifter
4:10 in the rear
3 inch side pipes
In my 1980 trans am She runs great don't have any numbers but she seems pretty quick.Great off the line and pulls hard thru all the gears !!!
  #55
Old 07-21-2007, 02:36 PM
Arrow 350 HO 'clone'
Here's a mild 350 combo I put together for a '69 Firebird that my brother owns, a heavily optioned car (A/C, power discs/steering/windows/drivers seat, deluxe interior) that weighs over 3700# without the driver.
1968 350 (354) bored +.030 so it now dispaces 360 cubes.The lower-end was rebuilt with cast pistons and stock cast rods by a previous owner and was still fairly fresh, I added the rest of the parts listed.
1969 400/428 #46 heads, cheap valve job/used stock springs, stock press-in bottle-neck studs, not milled for added compression, ports untouched.
Crane blueprint 068 cam (212/[email protected],.407"lift) advanced 4 degrees running stock 1.5 rockers and adjusting nuts torqued to the stock 20# spec, Cloyes Tru-Roller timing chain set.
Stock 1969 iron intake, exhaust crossover still functional, 1972 400 750 Q-jet rebuilt with no mods, stock 1974 B-body aircleaner 'donated' by a 455 engine.
Stock points distributor.
Stock log exhaust manifolds, cheap 2-1/4" dual exhaust
TH400 trans with shift kit added, TCI Saturday Night Special converter, approx 2500 stall.
1980 T/A 10-bolt 8.5 rear with original factory 3.42 posi, 235/60-15 street radials, no traction devices.
This car ran a 15.21 ET at a 2800 ft. altitude track, launching easy so as not to spin the 235/60-15 street radials. Using the standard correction factor for this track the ET at sea-level would be in the 14.80s. With good traction tires and a harder launch low-14s are easily there.
Pretty much all stock or stock-replacement type parts were used for this engine build. The 068 cam was chosen with .407" lift because of the press-in studs. I didn't want to overstress the valve train and I wanted the simplicity of using the stock 20# valve adjustment procedure (actually no adjustment, stock non-adjustable valvetrain).
A no-frills 350 built on the CHEAP and a decent runner.
ID:	117198   Click image for larger version
ID:	117199   Click image for larger version
  #56
Old 07-22-2007, 11:18 PM
azbirds's Avatar
azbirds azbirds is offline
my combo. 68 .030 400 with stock crank and zero decked
KB dished pistons with Eagle rods, assembly balanced
9.4 comp with E- RPM heads
Comp Cams XR276HR-10 cam (lift 552 and 561 with HS 1.65 rockers 224 and 230 at .050 Ls 110 cam set at 106)
RPM intake with 750 E-carb, MSD 6A box with factory dist and composite gear
Summit 80 GPH mechanical pump, and 11" DF centerforce clutch
Richmond 5 speed with 8.5 and 2:56.1 gears
Factory long branch manifolds with Pypes 2.5 with X-pipe and race pro transverse muffler
Chassis dyno showed 292 HP and 350 TQ at the wheels with out of the box 750. I tried the 800 and it woke it up pretty good so I tried a 950HP and the gain was noticable. I wish that the funds were there to dyno this thing again( this time with someone who is willing to mess with the carb to fine tune it. I took it in and the 800 E-carb was not running right and they just pulled it off and installed the 750. From 2600 to 4600 it showed an A/F of 12.5 steadily going down to 11.1
  #57
Old 08-10-2007, 08:45 PM
Exclamation Quality posts only!
Please make a sincere effort to detail your combo if you want to post in this thread.
If I don't see a sincere effort in your post and you don't spend the time to try to put down everything you know about your combo, I will delete your post.
If you don't know anything about your combo, then you really can't make a meaningful contribution to this thread. If you don't want to play by the rules, then you can expect to be tossed out of the game.
Look at all of the previous contributions to see how others have taken the time to put their setup here for all to see, then make your own post accordingly.
This thread is an archive for all PY members to use for future reference, let's keep it useful.
I would like to thank all of the PY members who have posted detailed car and engine combos for their contributions.
  #58
Old 08-11-2007, 02:07 PM
uneasyrider's Avatar
uneasyrider uneasyrider is offline
E-heads, 72cc (out of the box)
467cid ('70 RAIII 400 block 0.060 over)
11.5:1 compression (approx.)
RPM manifold
Crower # 60243
1.5:1 rockers
Eagle crank (4.25") and H-beam rods
Pistons, SRP
Hooker Super Comp. headers (2" primary, 3.5" collector)
750cfm Q-jet (RAIII 7040273, wouldn't recommend it, a little small and needed some "Cliff" type mods to work right but no real problems as far as that goes)
Stock pan and windage tray (wouldn't recommend that either, upgrade to a deep sump with baffles and for extra warm fuzzy an oil accumulator too)
I don't know what else to say, hope this was what you were looking for.
Uneasyrider
“To find yourself, think for yourself.”
― Socrates
“The unexamined life is not worth living.”
― Socrates
“Wise men speak because they have something to say; fools because they have to say something.”
― Plato
  #59
Old 08-13-2007, 11:02 PM
BigChief_65 BigChief_65 is offline
Here are the specs for the engine I am about to drop into my '65 LeMans:
'68 400 block, .030 overbore and stock stroke
'68 #16 heads, stock valves with new Comp Cams springs, locks, retainers, pushrods
Comp Cams 1.65 ratio roller tip magnum rockers
Approximately 10.75:1 compression
Stock reconditioned rods, stock crank, and forged .030 over pistons
Comp Cams Xtreme Energy 284/296 adv. duration, 240/246 @ .050" lift
Edelbrock Torker II intake
Big cap HEI distributor and Summit 8mm ignition wires
Factory water pump
Holley 4160 750 cfm dual feed carb
Holley 80 gph mechanical fuel pump
Hooker Competition long tubes with 3" Hooker aerochamber mufflers
No performance numbers yet as it's still new and not in the car yet, plus I still have the original open differential so I'm not about to drag until I get a locker.
If you shove a rocket up a donkey's ass, that doesn't make it a race horse.
'65 LeMans post 2-door
'68 400 block currently undergoing rebuild, looking at roots-supercharged 9 second street/strip fun car
Early project phase, lots more to come...
  #60
Old 08-14-2007, 01:50 PM
BILTIT's Avatar
BILTIT BILTIT is offline
1974 ventura
'74 455(+0.030), 4bolt (ARP studs), zero decked, 9.5:1 compression.
stock crank turned 0.010
SCAT h-beams, ROSS pistons (30cc dish)
670 heads 260cfm/chamber mod (SDperformance) 72cc chambers (exactly)
*(New cam)* UD S (288/302) 255/[email protected]/.585 112LSA 106ICL (after lash)
9-way billet roller timing set (JPPerf.)
ERPM intake-port matched
Holley 850DP (shaker455) 80/88 jets.
Mark8 electric fan with controller.
Mallory 140 electric pump, mallory filter, sumped tank, 1/2'' S.S. hardline (supply and return)
Mallory bypass reg. set at 6psi, 1/2'' braided to carb.
Hooker ceramic supercomps.
Pypes 3'' with magnaflow muffs.
TH350, continental ''tight 10'' 3200 stall
3.73 gear (stock 10 bolt)
275/60-15 MTDR's on TTD 15x8.5 3.75BS
Race weight: 3750#'s
Best to date: 11.97 at 110 1.65 60ft.
Launch at 15-1800rpm, shift 1-2 at 45-4800, 2-3 at 5-5500
Thru the traps at 54-5500rpm.
Vid of a 11.98 (old cam) run: http://media.putfile.com/MOV01856
Vids and pics: www.putfile.com/biltit
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
