Is this a normal thing? I have a high output 135amp three wire alt. The lights pulse only when engine is idling, give it gas and every light ie. dash lights and headlights get bright.
Thanks, |
not normal, alt is not putting out enough amps at idle, change pulley size, increase idle, adjust voltage reg. etc.
Engr.
How do I adjust voltage regulator? The alt. pulley measures 2.640 inches O.D.. What is the size I should try? The Idle is Ok as it is. I don't want it to race. Thanks for your help. |
Sounds like a bad ground even check where the ground connects to body.
Check this link, George just went thru it,
http://forums.maxperformanceinc.com/...21#post2927021 |
Old Goat 67,
Whick way to move the tang for my condition up or down? |
