Old 08-03-2007, 04:14 PM
79TA455STROKED's Avatar
79TA455STROKED 79TA455STROKED is offline
Default TOOK TA TO THE SCALE!
Just returned from taking the 79 TA to the scale.
3360LB without me in it.1/2 tank of gas.
This car dynoed 401hp,396ftlb to the wheels which gives me anywhere from 480-525hp to the flywheel depending on what numbers i go by that im loosing on the dyno.
With the right gears/traction,What time will 500hp push a 3360lb car to?We dont have a track around here so i wont know for real for a while.I weigh 180lb.
Any guess!
9.81 at 139.89mph
3400lbs
Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS!
370cfm butler eheads
port matched victor
1095 king demon
4.30gear,th400
MICKEY THOMPSON DRAG RADIAL tire
Old 08-03-2007, 04:19 PM
David Holmberg's Avatar
When Pontiac Dude was testing one of his hyd roller motors we ran at the track and on a chassis dyno on the same day. He went a 10.5x and put down 501 RWHP, but his car works.
Old 08-03-2007, 04:27 PM
fasteddy's Avatar
fasteddy fasteddy is offline
If it hooks well, low to mid 11s.
fasteddy
Old 08-03-2007, 04:48 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Depending on the final weight, you may fill up the tank! lol
The calculator I use shows between 12.04 @113 MPH to 12.20 @112 MPH. With that said, I'll vote 12.40 @110 first time out. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 08-03-2007, 05:18 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 08-03-2007, 11:16 PM
BVR421's Avatar
BVR421 BVR421 is offline
13.8@112
Old 08-04-2007, 01:11 AM
WARPed's Avatar
WARPed WARPed is offline
Ditto, 400hp and 3550lbs will be 11.50's if your oars are all going in the right direction.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 08-04-2007, 01:21 AM
71firebird400's Avatar
71firebird400 71firebird400 is offline
How did you get it so light!?
I've got a 71 and have yet to weigh it, but from what I've seen these cars are 3700lbs and up without some major junk removal!
Old 08-04-2007, 07:52 AM
tempest455's Avatar
tempest455 tempest455 is offline
That good for that year TA. My stock 455 TA w/ AC and Honeycombs weighed 3,980.
Tempest455
Old 08-04-2007, 09:17 AM
BDHABT's Avatar
BDHABT BDHABT is offline
You dont have to take out too much.
I`m at 3590,with me.I weigh 206.
The car still retains the full interior, has an 8-point roll bar,heater,5-row brass radiator,manual steering and brakes.
Mark.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 08-04-2007, 09:28 AM
Ron H's Avatar
Ron H Ron H is offline
I ran 10.87 @ 2870 and the slide showed 500 FWHP. You need to calc your weight in so my guess would be 11.50's with it set up well.
68 Firebird
Are you running with the wind or breaking it?
Old 08-04-2007, 12:26 PM
I was thinking low to mid 11's.I dont know what the car weighed stock,reg says 3700 and change.I took ac out,alum heads,fiberglass hood,cut crash beams out of doors(27lbs each),alum intake.Car still has full interior with rug,insulation and all.I could go lighter but i like having interior and stuff.
BVR421,13.8@112 Thats rough man!
9.81 at 139.89mph
3400lbs
port matched victor
1095 king demon
4.30gear,th400
Old 08-04-2007, 01:35 PM
Mine put down 410/440 and tips the scales a 3700+ lbs. It runs 10.90's all day long in the heat, NA.
You CAN'T compare RWHP numbers from different dynos, there are too many variables.
Old 08-04-2007, 05:20 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Mid 11s
[email protected]. 3460#s
Old 08-05-2007, 05:03 PM
Well you got me interested enough to actually weigh my own car today- came up at 3450 lbs without me in it, with a half tank of gas.
Stock 71 Firebird, with AC (no compressor, brackets, pulleys, only the AC Unit), and an aluminum intake.
Old 08-05-2007, 05:32 PM
RAIV55 RAIV55 is offline
Ditto. I figured 11.50's too. But the car has to work right to get it.
Old 08-05-2007, 08:07 PM
See that 71FIREBIRD400,these cars are not as heavy as people think.
9.81 at 139.89mph
3400lbs
port matched victor
1095 king demon
4.30gear,th400
Old 08-06-2007, 12:40 AM
You called it!
It's all these GTO/LeMans/Tempest people who want us to think our cars are heavy, clearly because they're jealous!
haha, in all seriousness I'm happy its that light. I think I'll shave some more weight off with an AC delete kit, fiberglass hood, and fiberglass nose (don't ask.....apparently horses enjoy chewing on endura....)
Old 08-06-2007, 01:12 AM
mikeb mikeb is offline
That's pretty good. My 79 with a 10 point cage but stripped interior and my fat ass in it (~200 of ballast) tipped the scales at 3600 at the texas motorplex.
Old 08-06-2007, 01:22 AM
BVR421's Avatar
3360lbs is a number a lot of Pontiac owners would like to see. Most of our junk is pushing 2 tons even with lightning. When you do get to a track I bet it flies! (8-)
Bet you also find some traction issues. Thats what I found with my 63 street car. Most of us tend to think power mods before we think traction enhancement. LOL But it all works out in the end.
My 64 is only 3220 with driver thanks to twooldgoats building it with lots of fiberglass.
It is a little front heavy at 1720lbs. Someone suggested that may be due to the 320lb driver but thats hard to believe.
