Old 08-22-2007, 12:43 PM
Mark W's Avatar
Mark W Mark W is offline
Default 4 speed ???
I have a 428 th400 in my car now and was wondering how hard it would be to convert to a 4 speed ? Clutch pedal / linkage / pilot bearing are all problems i need to solve.
I feel the need to shift gears like i did in the sixtys
What would be a good (o.e.m.) tranny, and what should i stay away from?
car was a AT car as well was the 428. thanks Mark
Old 08-22-2007, 08:43 PM
SD421's Avatar
SD421 SD421 is offline
I think http://www.fabcraftmetalworks.com/ has conversion kits.
-Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 08-22-2007, 11:29 PM
tom s tom s is offline
easy way is with a hyd throw out gearing,that way you only need to find a pedal assm.Tom
Old 08-23-2007, 01:58 PM
Mark W's Avatar
Did factory 4 speeds use a z bar? (clutch in front)
or a cable (clutch in rear)
Anyone have any pics. of clutch linkage? (both stock and aftermarket)
looks like hyd. bearing is the way to go but i dont know how to run a MC to run it.
Old 08-23-2007, 05:19 PM
get a engine manual and it will show all the factory linkage.The M/C can be put out of the way,check McLeod for the setup.Tom
