Old 09-01-2007, 06:25 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Talking
x-bird
The correct color is the slate blue that you currently say you have.
SD
0on't forget to paint those throttle return springs bright yellow. That would be the correct color.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #382
Old 09-01-2007, 08:24 PM
SD73's Avatar
SD73 SD73 is offline
I'm bringing this to this page so I don't suffer bottom-of-the-previous-page syndrome.
Okay fellas, the SD is in the shop for paint. This is the second paint job this old war dog has been given. I want to be sure it's correct. I've heard that some of these measurements may not be correct, and I don't see anything for the fender measurements at all.
Can one of you original paint job gurus confirm what I have here and let me know what the correct measurement are for the fender decals? Mine also only has the baby bird on the nose.
Greatly Appreciated!
ID:	103480   Click image for larger version
  #383
Old 09-01-2007, 11:36 PM
x-bird2 x-bird2 is offline
you've got the 73 assembly manual sheets for the decals. the nose bird gets centered on the "bump" with the wingtips .32-in. from the rear edge of the bumper. the fender decal goes .82 inch below the fender crease as measured from the top edge of the "T" and 3 inches from the back edge of the "M" to the rear edge of the fender. on the other side of the car, it's from the edge of the top bar of the "T" to the fender edge.
  #384
Old 09-02-2007, 11:53 AM
SD73's Avatar
Thanks X! What was your source for the fender decals?
  #385
Old 09-02-2007, 06:04 PM
same as yours, sheet 1a2f 4, the "view B" is the fender decal, nose bird measurement is on sheet 3. read sheet three carefully and you'll see a footnote that the fender decal measurements and install directions are on sheet 4. ;~)
  #386
Old 09-02-2007, 07:06 PM
schneidsd455's Avatar
schneidsd455 schneidsd455 is offline
I'll reply with a little info regarding the engine March, 73-74 engine paint color. I've seen and had the slate blue paint made by OEM, part #62230, which is advertised as correct for these cars. Seeing it, I always felt it was too dark, so I went with OEM 62220, which is advertised for early 73. In my mind, but only from memory, I felt that it was closer to what I'd seen on other original TAs. However, discussions on this site made me question my choice more. Now, after talking with Steve Schappaugh, and having him send me some paint that he had matched off of a very low mile car and a 2-week-old intake, I now see that I was off in my memory also. In the pictures below, the light blue is OEM 62220, the dark is OEM 62230, and the middle is Steve's paint. I am very pleased with the results and feel that it is probably the most correct color paint for these cars. The pictures were taken in daylight with no flash.
ID:	103585   Click image for larger version
Jeff Schneider
Alliance, NE
  #387
Old 09-02-2007, 07:24 PM
i think our last "conversation" here is why i brought this up, i have exactly the same feeling about the 62230 and 62220 paint, having had them both on the engine and having seen the original paint on my oil pan when i stripped the car down back in 1998. my engine had been overpainted with the silver blue metallic, but the pan had some original on it yet. neither of the rattle can paints matches what i found under the grime, but the 62230 is probably the closest on the market in a spray can. i spoke with oem about that paint and they said it was developed off the formula, but i could imagine that differences in the paints/pigments used across 30 years could lead to some variation.
  #388
Old 09-02-2007, 08:13 PM
SD73's Avatar
Thanks. I ASSumed that was a blow up of the spoiler decal!
  #389
Old 09-02-2007, 10:08 PM
Brewster's Avatar
Brewster Brewster is offline
Hey Jeff,
Try the PPG DP #74 since its correct for 1973-1974 sd cars right out of the can.
Also did that timing decal work out OK?
  #390
Old 09-03-2007, 05:56 AM
Brew,
DP #74? That number doesn't make sense to me. Just go to the paint shop and ask for PPG DP #74? I see from a paint chip website a PPG 14580 that's supposed to be the 73-74 engine blue. I've ordered a quart to compare to what Steve sent me.
I sent a picture of the valve cover decal to you to get your opinion, but haven't heard back. Did you get it? Oh hell, I'll just attach a picture.
Jeff Schneider
Alliance, NE
  #391
Old 09-03-2007, 08:07 AM
Brewster's Avatar
Morning Jeff,
SD engine paint is: Dupont Centari #31026 AM Medium Blue the PPG number is for the Red Oxide. Opps!
The sticker looks ok for now but we need to make a couple adjustments for it to be correct. Hope to get my printer thing fixed here this month and will send you a updated one soon.
Have a great Labor Day!
Brewster
  #392
Old 09-03-2007, 11:42 AM
SD Formula's Avatar
SD Formula SD Formula is offline
My 2 cents worth. The 62230, the color to the left in your photo, gets my vote. Several years ago before the correct (???) rattle can color was available, I picked up a quart of the 73-74 Pontiac engine paint from Scott Tieman at his (mostly Pontiac) restoration shop in Portland, Michigan. I compared his color to an original paint 1974 Firebird 400 engine, in both the exposed & more secluded areas of the engine. The color was right on. I don't know if he still sells the paint, but if he does here is another source for engine paint.
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
  #393
Old 09-04-2007, 04:03 PM
Pictures can play tricks with color and, as I showed with my experience, memory isn't always the best to go by.
SDFormula, did you actually compare Tieman's paint with 62230? The reason I say is that it could be the variance in color in the pictures and memory that make it look like the darker blue is correct.
All I know is that, in my experience and opinion, having seen 62230 on cars at the same show with original cars, it is definitely too dark. And, when I've got a guy who owns 9 super dutys, including low mile originals, and had the color matched off of a 14000 mile valve cover and a 1 week old intake, I tend to lend quite a bit of credibility to his opinion in color.
Jeff Schneider
Alliance, NE
  #394
Old 09-05-2007, 10:09 AM
SD Formula's Avatar
My comments were reguarding the three engine paint colors you displayed earlier in this thread. Taking into account the various ways that colors can change when reproduced via computers, the one on the left (62230) looked, to me, to be the closest to what I have. I have not compared the Tieman paint to any other paints, only an original paint engine. I would be happy to send you a sample of the actual paint color dabbed onto a piece of paper. PM me if interested.
  #395
Old 09-08-2007, 10:03 AM
njsteve's Avatar
njsteve njsteve is offline
another Scam 74 SD auction??? Nice single photo of a steering wheel and driver's seat.
http://cgi.ebay.com/ebaymotors/Ponti...QQcmdZViewItem
I emailed through ebay asking for more photos and this was the response I got:
"Hello,
I'm glad that you're interested in my 1974 Pontiac Trans Am 455 SD The car is street legal and accurate. It comes with all the documents needed for registration, it has a clear title and it can be registred into your name at any time. I am willing to sell it for $4800 This buy now price does include the shipping and insurance fees.
I'm located in Medina NY and the car is here as well and so this is where the car will be shipped from. I've done some research and the best and fastest way I can ship it is using Hemisphere cargo Shipping Ltd which takes between 4 to 6 days to arrive at your door (door to door handling and shipping insurance fee included).
I am affiliated with Yahoo! Finance where I have a purchase protection account for $ 6,000.00. This service allows us to complete this transaction in a manner that is quick and safe for both of us. It acts as a third party between seller and buyer to insure that both parties comply to transaction requirements and provides dispute resolution and mediation between parties. Yahoo! Finance is responsible to insure that both parties comply to transaction requirements.
If this is ok with you please reply with your complete name, address and shipping address in your next email and let me know if you are interested in knowing more details about this purchase so that I can open a transaction case at Yahoo! Finance and move forward with this deal.
Thank you,
Richard Smith
PS: Let me know if you want to see pictures!"
  #396
Old 09-08-2007, 10:20 AM
"Hello,
Thank you,
Richard Smith
Theres no SD Trans ams in Medina NY . I can just about gaurantee that .
  #397
Old 09-08-2007, 03:30 PM
Father&Son73T/A Father&Son73T/A is offline
Looks some "lucky" fellow got an "export" SD for 28k,,.yeah right
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
  #398
Old 09-08-2007, 08:38 PM
njsteve's Avatar
Here's a nice white/red interior 73 in reasonable shape for $69,000. It has a 74 SD motor. Too bad he tossed the original cracked block.
  #399
Old 09-09-2007, 07:54 AM
Brewster's Avatar
The only thing original on this car is the vin!
Notice that LS2 intake which appears to be a 74 LS2X or a very late production 73?
  #400
Old 09-09-2007, 03:26 PM
toomanybirds toomanybirds is offline
The white 73 SD on ebay does have a number of missing or incorrect parts under the hood. The intake manifold does appear to be a correct 73 SD. Can't be certain without seeing the number in front of the carburetor.
