Old 09-13-2007, 07:36 PM
81w72 81w72 is offline
Default timing chain dots.
Hi all...Im swapping out my chain with a double roller, when we get #1 on TDC the cam dot is at 12 o`clock and crank is at 12 also. What cylinder would be TDC to have the cam dot at 6 and the crank at 12? The manual shows this on how to line up marks but doesnt say what cylinder is TDC.
81 ta, w72 400ci
Old 09-13-2007, 07:44 PM
BILTIT's Avatar
BILTIT BILTIT is offline
#6 TDC
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 09-13-2007, 07:46 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
With the dots at 6 and 12 cylinder #6 will be firing. I always puts the dots at 12 and 12 and install the distributor so the rotor is pointing to #1 spark plug wire.
Old 09-13-2007, 08:00 PM
BVR421's Avatar
BVR421 BVR421 is offline
Its the same either way because the crank turns twice while the cam turns once.
The Pontiac manuals show 6/12 in some years and 12/12 in some years. Doesnt matter.
Old 09-13-2007, 08:33 PM
Cool, ty ty ty
81 ta, w72 400ci
Old 09-13-2007, 08:51 PM
If you use the cam @6 and crank @ 12, just have the rotor point to the #6 post on the cap. (180 opposite #1)
