Old 09-14-2007, 12:31 PM
dda72's Avatar
dda72 dda72 is offline
Default KRE Aluminum block vs. IA2
Trying to weigh the advantages to justify the cost of purchasing an aluminum block vs IA 2. Current weight is rather heavy at 3580 lbs. with driver and taking 100 plus lbs. off to nose of a 72 Firebird would definetely be going in the right direction. Anyone running the KRE aluminum block? Did it spec out OK?
Thanks,
Dwight
Old 09-14-2007, 12:51 PM
BVR421's Avatar
BVR421 BVR421 is offline
there is also a IA11 aluminum block so you have choices.
Old 09-14-2007, 01:31 PM
PONTIAC DUDE's Avatar
Thumbs up FWIW:
Ditto.
Just covering bases. Remember if you buy any K&M block according to their ad (read the webpage) you have Just 10 days to find any issues for a return.
Old 09-14-2007, 01:34 PM
Region Warrior's Avatar
Originally Posted by PONTIAC DUDE
Ditto.
Sounds like buy at your own risk.
Old 09-14-2007, 01:46 PM
dda72's Avatar
Very good points. Who sells the aluminum IAII block?
Old 09-14-2007, 02:00 PM
Post
I know i won't get a commission on this. Wink, wink.
But you can buy it direct from AllPontiac.
http://allpontiac.com/contact.html
If your wanting an engine built, then I can do it assembled.
Old 09-14-2007, 02:02 PM
Brian Baker's Avatar
www.allpontiac.com
Old 09-14-2007, 02:13 PM
Dwight, you really need to check the archives to review what went down with KRE/K&M and the MR1 blocks. Given their poor track record of customer service, I think a person would have to be nuts to even consider spending money with them now, but that's just me. There are KRE loyalists out there (who have yet to be screwed) that feel otherwise. Talk to everyone and decide for yourself, but remember, just because it's cheaper doesn't mean it's better..."penny wise - pound foolish".
Old 09-14-2007, 02:20 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
What was the final diagnosis of Cooper's IAII aluminum block that grenaded a year ago? There are pages and pages on the KRE blocks destruction, but I never read the cause of that particular IAII to come apart. TIA
Old 09-14-2007, 02:24 PM
Only failure I'm aware of from Cooper in 2006 was at Norwalk, when he broke the front of the crank snout off the crankshaft. That's not the fault of the block, that's from overdriving a large roots blower. Hemi and BBC crank snouts are bigger than a Pontiac's and can handle it better.
Old 09-14-2007, 02:26 PM
Larry Cooper, NA bird, hear the mains fell out of the block but you know how rumors go.
Old 09-14-2007, 02:33 PM
OK, wrong Cooper (LOL). Actually, that failure was discussed on the board. The consensus was it being a result of standing it on the rear bumper too many times and starving the mains without pulling it apart for inspection. Tom Vaught weighed in on that one as well, do a search and you'll find it.
Old 09-14-2007, 02:45 PM
BILL BOWMAN1's Avatar
I'd use the one that is track proven, reliable, and backed with customer service.
Old 09-14-2007, 03:00 PM
Like this one?
Special Orders: All special orders are non-returnable and non-refundable. Special orders may also include prepayment. Special orders include, but are not limited to the following: any CNC package, assemblies, valve train components, engine blocks, special machining and/or labor operations.
Warranty Returns: All merchandise returned for warranty consideration, inspection, repair, etc. must be sent prepaid and insured. Included with this return must be the sender's name, address, phone number, and explanation of the problem and work to be done. A return authorization number must also accompany the return: this can be obtained by contacting AllPontiac.com/ Indian Adventures LLC., at 804-794-6777. AllPontiac.com/ Indian Adventures LLC., will ship warranties back in the most cost effective way. Any additional cost for freight upgrade will be at the customer's expense. This warranty covers replacement or repair of the product only and does not cover the cost of removal and/or installation. There is absolutely no warranty on the following:
A) Any products used in racing applications.
B) Any product that has been physically altered, or improperly installed or maintained.
C) Any product used in improper applications, abused or not used in conjunction with the proper parts.
Old 09-14-2007, 03:02 PM
Question
Before conjecture and such sets in what are your goals and hp/torque levels you want? What are your plans.
Old 09-14-2007, 03:07 PM
Talking
Originally Posted by johnta1
Like this one?
A, B, C are normal aftermarket performance parts statements. But I don't see a 10 day return policy.
Old 09-14-2007, 03:15 PM
Overkillphil's Avatar
Overkillphil Overkillphil is offline
Hmmm, according to those terms, no coverage whatsover if used for racing.
I suppose the bulk of their business is little old ladies and traveling salesman who want a wee bit more power to get out on the freeway!
___________________________________
"Objects in mirror are closer than they appear"
Old 09-14-2007, 03:32 PM
dda72's Avatar
Pontiac-dude, the goal is 5.80-5.90 in the 1/8 mile with a 72 Firebird weighing 3580 lbs on 10.5 tire naturally aspirated. Current set up runs 6.35 @ 105 MPH with RamAir IV heads so hopefully 925-950 hp would get very close. The thought was an aluminum block would save weight on the nose along with aftermarket strength compared to a stock block. After reading some of the posts I need to do more homework for sure!
Thanks,
Dwight
Old 09-14-2007, 03:55 PM
Name one, just one vendor, regardless of what vehicle make it's intended for, that warranties a part for use in racing applications.
Old 09-14-2007, 04:04 PM
Thanks,
Dwight
Unless money isn't an object, it can be done with the Aluminum block and under 1000 hp.
But for long term throw anything to it live forever. I would use the Iron IA II block and live with the nose weight. There are things you can get away with to make a front heavy car hook. Just ask those SS and stock racers. And some illegal stuff too. LOL.
