Old 10-18-2007, 07:35 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
How does the weather look guys? Any CT guys going?
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 10-18-2007, 07:42 PM
GTOLIB GTOLIB is offline
next year for me ,
good luck , let us know how you make out
here is a helpful web page
http://www.racetrackweather.com/html/clublist.htm#de
have fun
Old 10-19-2007, 08:21 AM
triathlonx13's Avatar
Default Area Code 12195
Saturday, Oct 20
High: 66 °F RealFeel®: 63 °F
Mainly cloudy and breezySaturday Night, Oct 20
Low: 45 °F RealFeel®: 41 °F
Mainly clear and breezyStar-gazing conditionsForecast Details | Hourly Forecast for Saturday | Hourly Forecast for Saturday Night | AccuPOP® Precipitation Forecast
Sunday, Oct 21
High: 69 °F RealFeel®: 68 °F
Sunny and nice
Old 10-19-2007, 09:27 AM
They will be flyin Sunday
Old 10-19-2007, 07:02 PM
grnmnstr's Avatar
I'm leaving at 5am this morning. I should be ther about 7 - 7:30am. Looking to see how the new converter works.
Old 10-20-2007, 07:34 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Did the track rantal go off on Friday?
John
Old 10-21-2007, 10:09 AM
geforc geforc is offline
Default Track rental
John' I went to the track rental Friday at Lebanon it was 75 and sunny when we arrived at 9:30. We left at 2;00 and it had not rained yet but was expected. I took my Lemans and ran 12.89 with closed exhaust and MT drag radials. You could run non stop after 12:00 with no problem if you wanted to, the lanes were very short. Maybe next year we'll see you at a rental.
Gene
Old 10-21-2007, 11:31 AM
Brandi Kay's Avatar
Brandi Kay Brandi Kay is offline
Can someone let me know when theres a track rental next time, id gladly pay 70 bucks to run 12 times.
Keepin it real in 2025.
'just another time traveler...
:range r:
Old 10-21-2007, 05:03 PM
ponjohn's Avatar
Gene
Gene- thanks for the info. did you expect the lemans to run in the 12's? Did you drive up?
Next year for me as wll.
John
Old 10-21-2007, 06:14 PM
John, the Lemans always ran low 13.0? I upped the timing to 32 the rest stayed the same. The 60' was 1.74 and that was the best ever, usually 1.78-79. the 102.7 mph was also the fastest. I trailered the car as I always do, 4:10 REAR WITH 28" Drag Radials.
Gene
Old 10-22-2007, 02:45 AM
drailed drailed is offline
Triathlon, I saw your car out to the valley today, sweet runnin TA. I didnt get a chance to introduce myself because I had to head off to work early. Good to finally see some pontiac people in my neck of the woods. Brandi, heres a link to there sight with a schedule.
http://www.dragway.com/
Old 10-22-2007, 10:51 AM
Thanks. Yah - we made the last minute decision to run on Sunday to avoid a possible rainy day on Saturday. The weather was perfect. I ran a best of 11.26 @ 120 mph with a 1.56 60 ft. It's the fastest car I have ever been in. I'm still experiencing an electrical issue. The engine breaks down / or miss fires in the higher RPMs.
I don't think it's carburetor. My Dominator has # 88 jets and I put the power valves back in. Timing is at 14 and 33. I grounded the MSD box to the head (instead of the firewall). By grounding it this way it did make an improvement. The car starts easier and seems to have a smooth 900-3,000 rpm band. Since this car was a complete rotisserie/full restoration... I think I need to chase all the grounds. Most things where painted - but I did sand clean spots for grounding. I think I need to re-look at what I'm grounding to. Another thought is swap out each electrical part one at a time to see if there is a cracked distributor cap, back spark plug wire, etc. The engine just runs rough / missing... I'm frustrated to say the least.
On the positive side - I learned a lot Sunday and learning my car. The car is pretty mellow doing a 1.56 at the 60 and hitting 120 mph thru the traps. Very straight and smooth. I ran my 28x12.5s MT ET Streets at 14 psi. I haven’t put on my Cal Traks yet either. My shocks are just some old worn out shocks I found! Once I can get this engine stumbling issue resolved I'm looking for 10s.
Old 10-22-2007, 07:43 PM
grnmnstr's Avatar
I was there on Saturday. When I arrived it was cloudy, then the sun came out. They were drying the track when I got there at 8:30am. It had poured the night before. I think they started to run at 10:30am.
However, water kept seeping through the track. They kept trying to dry it up. Every once in a while a car would get out of shape. Then at about 2pm, it started to drizzle. I put the car back in the trailer. I wasn't about to risk any damage.
They did give me a full raincheck, $30. Good until 10/08. But I won't be going back. Island and Etown are much closer. Atco is just as far as Lebanon for me. I would choose Atco in a heartbeat.
Old 10-22-2007, 07:50 PM
Brandi Kay's Avatar
were you the one with the 68 lemans?
:range r:
Old 10-22-2007, 07:59 PM
grnmnstr's Avatar
No, see the sig below
Old 10-22-2007, 08:07 PM
Brandi Kay's Avatar
Ok, i musta missed you, i always introduce myself when I see Pontiacs at the track.
:range r:
Old 10-24-2007, 10:00 AM
77birdman's Avatar
77birdman 77birdman is offline
BK: do you have a blower on your PDude 455? and if you do did you or someone else installed it for you? Just asking becasue it sounds like you are in my neck of the woods and I am planning (when I have some more $) to install one of PDude's blowers next year.
Can do the talk, can't do the walk......therefore need deep pockets
Injection is nice but I rather be blown
If you got it flaunt it, if not fake it (Snoopy)
Original 1977 Firebird / Welded tube frame connectors
TH350 with shift kit / 400 bored/stroked to 455 by PDude
OCD=Waxing and polishing your oil filter
SICK=wetsanding your exhaust pipe
  #38
Old 10-24-2007, 07:16 PM
Brandi Kay's Avatar
I do NOT have a blower on my P Dude 455 YET.
I will give you a hand in installing yours because it will make my install go easier.
If everything goes well, I may have one in the spring. College and teaching has to be my focus for now.
But let me know and I'd be happy to wrench with you.
:range r:
  #39
Old 10-25-2007, 09:26 AM
Any of you guys going to ATCO November 10th????
Old 10-25-2007, 01:31 PM
grnmnstr's Avatar
I will be there
