Old 03-15-2016, 04:51 PM
maxilo maxilo is offline
hi,
I'm looking for a 455HO engine with 197 heads plaese mail if you have some. if it must be reviewed no problem
Thanks Henk
Old 03-15-2016, 09:30 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
Hello maxilo,
I see you are new to the forum. Welcome to the all things PONTIAC world. The 1971 model 455HO engines are the ones with the 197 heads. The 1972 model 455HO engine has the 7F6 head. If you are interested in a complete 197 head engine, occasionally someone has one to sell. They are pretty scarce though and usually fairly expensive. I suspect you mean renewed (as in rebuilt) instead of reviewed. May be a little translation thing going on there. Where in the world are you?
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
Old 03-16-2016, 07:45 AM
hi yeah I'm new to the forum I'm looking for a 455ho engine in 1971 they are indeed very expensive I know a motor is above my budget but this has not yet been revised. If your know a 455ho? or heads? I'm from Holland
Old 03-16-2016, 10:22 AM
Alvin's Avatar
Alvin Alvin is offline
Lightbulb
Old 03-17-2016, 05:32 PM
1971455HO's Avatar
Hi Maxilo,
I can only surmise that you must own a '71 Pontiac Firebird that originally came with the 455HO engine. I assume you are looking for another one to put back in your car? Since it won't ever be a number matching engine for your car, do you have any preference as to whether it is for a 4-speed (WL or WC code) or an automatic (YE code)?
The best advice I can tell you is to browse right here (70-73 Firebird & TA Tech_455HO Forum) often.
Just about everybody here will copy and paste a link from eBay or wherever we see 455HO stuff for sale.
Probably not a lot of Pontiac parts available in Holland? Here's some parts on eBay here in the states. I'll PM ya if I see a complete engine for sale.
http://www.ebay.com/itm/PONTIAC-421-...dV10Mw&vxp=mtr
http://www.ebay.com/itm/1971-pontiac...tUnFP3&vxp=mtr
http://www.ebay.com/itm/1971-Pontiac...1Ww7KU&vxp=mtr
http://www.ebay.com/itm/68-74-Pontia...xUdjDG&vxp=mtr
Post a pic of your car.
Ol' man Smith
Son video'd this...
Old 03-17-2016, 05:48 PM
Originally Posted by 1971455HO View Post
Hi Maxilo,
Hi
Yes i have a trans am 1971 automatic i will find a 455ho code YE motor for this car. Can jou help me?
As originally produced as '71 455 HO engines, there are
- 3 different 2 letter block codes,
- 3 different block casting codes depending on date cast
- 2 different styles of 197 casting heads, early and late...
- very expensive 455 HO specific Quadrajets that never go with an engine
- an expensive distributor, that came in 5 production dates.
...and there's more
Consideing what factory round port engines go for in nice rebuildable shape, Maxilo, you probably ought to be more specific with what you believe you need.
Old 03-17-2016, 10:04 PM
1971455HO's Avatar
"ol Pinion head is right Maxilo,
Unless you are absolutely dead set on having everything 100% 455HO, I would consider building any complete 455 that is rebuildable. Hang a good set of forged rods and pistons on the crank. If you still want to go with a set of HO heads & intake, you could.Putting an HO engine together a piece at a time is cost prohibitive for most of us. Not having the original (born with) engine knocks the value off about 15%. But, putting in a numbers & date correct HO engine won't put you back in @ the top price either. It's not the original. NO CIGAR!
If it's just a want to thing, It's your money. You can have a neck snapping 400+ HP engine for considerably less than what you will spend on true HO parts.
The last complete used 455HO I saw for sell was more than 5 years ago and the guy wanted $9,000 US dollars for it. It was probably a pieced together engine. The date codes were all over the place on it.
You asked if I will help you find a 1971 455HO engine. I will, if that is what you really want?
Ol' man Smith
Son video'd this...
Old 03-18-2016, 07:46 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Maxilo, here is an engine I remembered seeing a few months ago on a youtube video in England, not sure if he'd sell it separately but it was an extra engine so might be available? The engine comes in at about the 5:00 minute point of the video... https://www.youtube.com/watch?v=n8cZW8jfZqM
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 03-18-2016, 09:55 AM
bird72's Avatar
bird72 bird72 is offline
Maxilo, I am doing an HO, but as Pinionhead and HO said on #'s, parts & cost..... If not hung up on matching numbers and dates, any early 70's 2 bolt 455 will be already drilled for 4 bolt, and rather than a spendy & hard to find "HO" block, 4 bolt caps can be added to a 2 bolt block (what I did) on a YC 1971 block (align bore rqd.). I spent 2000 on 71 HO heads and 700 on 71 intake. Had block and all misc parts also. I expect to have $6-8000 in build maybe when done on top of heads & intake parts cost, so 10K engine ballpark maybe. Forged psitons and rods and roller valvetrain is almost half of that cost. A "stock parts" build could be substantially less. Yes I will have a "mutt" engine but do not care, it will make equal fun as any.
72 Bird
Old 04-12-2016, 04:31 PM
[QUOTE=RicksGTO;5549394]Maxilo, here is an engine I remembered seeing a few months ago on a youtube video in England, not sure if he'd sell it separately but it was an extra engine so might be available? The engine comes in at about the 5:00 minute point of the video... https://www.youtube.com/watch?v=n8cZW8jfZqM[/QUOTE
Old 04-13-2016, 07:52 AM
Judge273's Avatar
Judge273 Judge273 is offline
Is this rare? Never seen anything like it before?
http://forums.maxperformanceinc.com/...d.php?t=789140
Mike/Illinois
Old 04-13-2016, 10:07 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Yep, rare as hen's teeth Mike. 1972 455HO fitment only. PN 487196 for the thermostat coil.
Regards,
"455HO" Lloyd
Old 04-14-2016, 11:08 AM
bird72's Avatar
A bit of bad news on HO build, after disassembly of 455 block, hard use 20 years ago showed bad spot on main on crank one location, bearing failure of some sort. Looks salvageable, will have machinist report on in a few days.... Question for y'all: for a quality build, would you have issues with using a turned down crank or would you buy a Butler (Eagle?) new one? Is 71 factory crank now...
72 Bird
Old 03-18-2016, 12:33 PM
1971455HO's Avatar
Way to go Rick, I had forgotten about that posting. It already on his side of the pond.
Ol' man Smith
Son video'd this...
Old 04-11-2016, 10:46 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
Thumbs down 1971
...lots goin on here with this one but unfortunately a good portion of it looks like it needs correcting....
http://cgi.ebay.com/ebaymotors/Ponti...JXB~Jw&vxp=mtr
Old 04-11-2016, 11:53 PM
Formulabruce's Avatar
Always fun to guess about what "type" of shop "restored" a car...
This one has MOPAR Shop all over it, just like the white paint! ( it is one step above undercoating though LOL)
" Long may we DRIVE !"
Old 04-12-2016, 01:11 AM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
I didn't know MOPAR guys painted their cloth door panels, or used the wrong year seat covers when correct ones are available. Wrong year lower door panels I sort of understand because correct ones are hard to find. I do know they like hood pins. I hate hood pins. Looking at the guage the gas tank must be really big.
Old 04-12-2016, 02:03 AM
2manyT/A'S's Avatar
The white under carriage looks bizarre.......
The mopar guys used to LOVE yellow plug wires....
Door panel uppers are 73-74 double deluxe.....
Whoever buys this car will not know ANYTHING about Pontiacs....and LOVE it.....
Eye Candy......garage band?
Go full screen & turn it UP!
Old 04-12-2016, 04:32 AM
Crap Kenny, I was still on the outside with the one body color!!
