speedshopmike,
You have PM. |
jim, replied, thanks.
2many - no way - purple wires are for squares - i gots me some lime green action! and triple gold chrome plated anodized ceramic-coated air cleaner element, too. all THREE monster tachs are doule-sided taped to the back of my hood and are plated and coated like the air cleaner element is to match. combined with a polished, wrinkle-painted chrome satin Corvair water pump on a custom, engine-turned stainless powdercoated timing cover and i'm UNTOUCHABLE at car shows! i bring a cot so all the chicks lining up have a place to jump me; i gotta eat like 23 viagras as the show goes on just to keep up. so to speak. banter aside, no, i don't at all NEED iron roundports, nor did i call them junk; it's no mystery or secret they work, and i didn't fall off the truck yesterday; quite the opposite - i was brought up into pontiacs by three very significant guys - truman fields, chuck roberts and ronnie johnson, so i got a serious head start in this, very luckily for me. i do believe you took offense at a generalized comment that explains my own, personal feelings, and cast nothing negative at the resto guys. in addition, if you think pontiacs got as strong as they did by virtue of anything but hot rodders taking stuff and modifying it so it worked better you're mistaken - and same for any other brand - racing improves parts and engineering, period. further, as i clearly stated, the car IS a clone. this is same as phony or fake. it's not ever going to be worth what a real one is, and because of that and that by nature of being a clone, it's already been very substantially altered from stock - so why shouldn't i make it fast? what if i wanna paint it pink and glue blue dildos all over it? it's my car and i can screw it up any way i please. we have a 67 'vette; believe me, you think poncho guys are bad when it comes to indignation when modding a stocker comes up, the vette guys make you all look like pygmy kittens - they're freakin' RABID. bottom line, to each their own - who am i (or you) to judge someone else's choices? i've seen, in my years owning the shop, people do the absolute stupidest, most pointless sh!t i've ever seen in my life to their vehicles - but it made them happy, so it works for them no matter what i or anyone else thinks.
is this thing on? |
i'm still looking for someone to run one cylinder's compression check for me - dont even pull any other plugs, just the one.
please. thank you.
is this thing on? |
How about calling Nunzi? He has probebly has seen more of these round port motors than any one, he probely has the specs memorized. I know I know - your a speed shop & he's a speed shop maybe he could help though. If Nunzi cant help ya then your going to have to go to the real expert - call Rock & Roll Engineering PS Chocka Rules! Jason
Jason Rackawack 1975 455 Trans Am - 1975 Firebird 400 |
Items of Interest on ePay
$10,000 for a 72 T/A Clone With 350 power - Statred out as a 73 Bird. http://cgi.ebay.com/ebaymotors/Ponti...spagenameZWDVW NOS 7F6 Heads! who knew there were any left untouched. http://cgi.ebay.com/ebaymotors/1972-...spagenameZWDVW Have fun with these, Jason ![]()
You keep wanting a cylinder compression number?I assume you are having some problems .. Why don't you just run a leak down test, that will tell you if everything is sealed up correctly or not.. Last compression I ran was in the high 180's, that was a motor I had just rebuild, using SpeedPros' gapless rings , which will produce a bit more pressure.. Still, if I though I was having problems, I would run the leak down test, will give you a more accurate diagnosis...
lloyd, it is indeed gutless in the extreme; doesnt start rolling till 3500 rpm and even then it's not strong.
i did a quick leakdown on 2 holes; very acceptable 13% leakage. the motor's mechanically sound; it's all in the cam in my opinion which is why i'm trying to see what a stocker HO or SD does prior to diving in to it - am trying to figure out in advance if it's stabbed in wrong or just too big; nunzi's small stick is only 230ish @ 050 and 10 degrees more on exhaust, but i can't find LSA or intake opening points published anywhere. yes, throttle at WOT for test with battery charger on while cranking. still looking for actual results from someone please, and thanks for the replies so far.
is this thing on? |
Gregg V. |
Not mine, but I thought you guys might enjoy. Looks like a reasonable deal, but what do I know???
http://cgi.ebay.com/ebaymotors/1971-...em330219935810 |
I think the seller needs a better camera,especially if he's fishing for a $60,000 dollar customer. It's fun watching the vids. Just LOVE listening to that M22! I've never been a fan/advocate of revving the engine like that (unloaded). You can see how WRONG the color is on the repro seat covers & carpet. Looks like they painted the dash/doorpanels,etc.(which look closer to correct color) Wonder if there will be any bidders. Market seems real soft right now to me. |
yup, juice flat cam.
i use rhoads in nearly everything i build, my 81 TA 455 has them; i didnt do this motor, though; bought it as it is. just hung up with nunzi; he tells me the cam's on 113 LSA...but also mentioned there's two different grinds he uses with the same part # (odd...)and i don't know what the cam is regardless; it might not even be his small one. crapspackle! i got me some tearing down to do, it seems. still want a compression test result from someone please.
is this thing on? |
That's pretty cool!
Was this BEFORE they had area codes??? |
must be loacl from the area where the was car found. when was the last time we saw an old T/A just parked someplace with a For Sale sign on it?
Just make sure you call after 6pm!
[QUOTE= when was the last time we saw an old T/A just parked someplace with a For Sale sign on it?[/QUOTE]
Yesterday! (in my driveway)
thought I'd bring this post back to the top.. Any word on the work Mark Weymouth was doing on the maximum performance stock 455SD motor they were going to build and dyno? I hadn't thought about it in a while but would love to get an update.
'72 Formula 455HO TH400, Revere Silver, black deluxe '74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe |
Haven't heard anything from Mark in a while.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
How do you know how thick your head gasket will be after you torque it? Should I have asked for a specific thickness, cc's, volume, etc? I just wanted to calculate my C.R. I cc'd my heads and they are 105 (originally 111cc's, cut .030"). Just guessing that my gasket squeezed to .035" I calculated my C.R. to be 8.9:1 based on the following: 4.18" bore, 4.21" stroke, 105 cc's heads, .001" deck (almost zero deck), 6 cc's (estimate) valve reliefs and head gasket at .035".Thanks, Eddie
Ol' man Smith Pigeon Forge, Tn. Grand Rod Run Spring 2012 https://www.youtube.com/watch?v=DUIuGvWWthA http://s223.photobucket.com/user/fas...d%20Run%202012 Son video'd this... http://s223.photobucket.com/user/fas...a.mp4.html?o=0 |
Gregg V. |
Thanks a lot Mike and Gregg for the responses. I really felt dumb after seeing what Gregg was talking about with the nooks and crannies where you can put a feeler or a wire gauge between the head and the block. Why didn't I think of that? I went back out to the garage and checked it.....040"...not .035", back to the drawing board. Thanks a lot Gregg, I learned something. That's always a plus. Thanks again to both of you. Mike, I'll PM ya just to see what it should be according to part number.
