Old 11-26-2007, 01:58 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Ditto, you could call it a ''special tool' i suppose!
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 11-26-2007, 02:04 PM
fdowdy fdowdy is offline
Default Using Grease to Force Out Bushing
That's what I did with my '64 389. Worked like a charm.
Hmmm.. Now WHERE did this part go???
Old 11-26-2007, 02:18 PM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
Originally Posted by zbuickman
I've always used a rod and filled the cavity with grease. smack the rod with a hammer and it pushes the bushing out.
This is the technique I've used and attempted to use. Once it worked well and the next time I got hit with a facefull of grease when the hammer hit the rod. Just a little too much clearance in the bushing ID I guess.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 11-26-2007, 02:46 PM
TheMonkey's Avatar
TheMonkey TheMonkey is offline
seems that there is a trade-off between bearing or bushing. the downside of the bearing is that when it fails, it really frickin fails. seems that others feel that a bushing can be tough on the needle bearings in the trans.
but... i think people lose sight of it's function and what makes a bushing/bearing work hard.... bellhousing alignment is so important. remarkable that some people don't even check it. i suspect that bushings get blamed for needle bearing failure when it was actually the fault of bad bellhousing alignment.
my vote is proper bellhousing alignment & bushing, but IMO bushing/bearing choice is far less important than proper alignment.
_____________________________________
www.malunacoolers.com
Old 11-27-2007, 01:18 AM
goathead455 goathead455 is offline
The 7109 bearing is only sealed on one side.
The 6202-2rs bearing is sealed on both sides.
It has the same ID and OD as the 7109 but is a little deeper.
Old 11-27-2007, 07:48 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Is the 6202-2rs bearing a better choice??? Will it hurt anything because it is a little deeper??? Where can I get these bearings??? Local parts stores carry these????
Thanks again, Dave
PS Boy, I really like reading all the replies about this...Lets have more, I am learning a lot of stuff.
Old 11-27-2007, 09:49 PM
I have never had a problem running the 6202.
Your local bearing supplier should have both of them.
