Old 01-05-2008, 11:28 AM
Brewster's Avatar
Brewster Brewster is offline
Bob, I heard you like sledding? ever go up tp the U.P.?
I do hope to rip the 4-speed but after Spearfish, Norwalk and or Dayton. Otherwise I should sell both and start all over?
  #682
Old 01-05-2008, 05:11 PM
SD Formula's Avatar
SD Formula SD Formula is offline
I'm gettig ready to take my SD engine in for service, and in the interest of getting it back in a more correct state, I have a few questions for the Superdutyoligist on this site. When I bought the car in 1991 it had a fresh engine. Of course, it was painted the wrong color. Over the years, I have learned of some other areas that are not correct, mostly relating to the engine. Thus, I need your help! 1. Did the SD have a cast iron or aluminun "gooseneck" on top of the intake manifold? Mine is cast iron. 2. Does the water pump, where the fan clutch mounts, have studs with nuts & lock washers, or bolts with lock washers? 3. The Felpro gaskets (stamped 90123) I have for the intake manifold have a very large crossover heat riser opening that doesn't match the manifold. However, it has the larger size openings that do match up with the SD manifold port openings. Also these gaskets do not appear to have the protruding area near the front that matches the factory original gaskets. Are these gaskets available? If so from who? Felpro? Thanks in advance!
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
  #683
Old 01-05-2008, 09:50 PM
Brewster's Avatar
The SD engine paint is: Dupont Centari #31026 AM Medium Blue, aluminum, bolts and washers, review link below regarding gaskets.
http://forums.maxperformanceinc.com/...d.php?t=539817
  #684
Old 01-05-2008, 10:18 PM
toomanybirds toomanybirds is offline
1. Thermostat housing is aluminum
2. Fan clutch mounts on studs
3. 90123 gasket will not work on SD455, exhaust crossover opening is too large
Correct appearing gasket is not available for SD455, you can follow my suggestion in the above referenced post for how to make a correct appearing gasket from the MS15174 gasket.
The best matching engine paint I have found is sold by OEM paints. The color is called Slate Blue. It is good quality paint. One can will cover a complete engine.
  #685
Old 01-05-2008, 10:26 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Glen:
I agree with toomanybirds on this one.
If you had a fixed fan like a non A/C car then it would mount with the spacer and long bolts with lock washers. Otherwise studs with nuts and washers.
Brew: I think you are looking at fixed fans not viscous coupled fans like an A/C car would have.
I used to snowmobile in the UP all the time but more on the east end. Not much further west than Munising. I sold my sled last year due to lack of use. If I decide to go again it's cheaper to rent for the weekend than own one.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #686
Old 01-05-2008, 10:37 PM
SD Formula's Avatar
Thank you, too many birds, I appreciate the quick response. Somewhere along the line the thermostat housing must have been changed to the cast iron one, luckily I have an aluminun one in good condition. The water pump studs are an easy fix. I'm hoping the shop where I'm taking the engine will have a suitable intake manifold gasket. I got the proper color engine paint from Scott Tieman a while back. Could you clarify what you mean by "in the above referenced post"? I'm not seeing that on your post. Thanks again. There will be more questions soon.
  #687
Old 01-05-2008, 10:47 PM
SD Formula's Avatar
Originally Posted by superdutybob
Glen:
Bob, I should have been clearer in my initial question. It is an AC car thus the fan clutch. My other 74 FB also has AC & the water pump has bolts not studs. But most likely the wp has been changed.
Bob, I sold my two Arctic Cats in the late 70's & haven't had the urge since!
  #688
Old 01-05-2008, 10:48 PM
Glen:
The link was in Brewsters post, not toomanybirds post. One above his!
Bob Woodard
Brighton, MI
  #689
Old 01-05-2008, 10:51 PM
SD Formula's Avatar
Never mind, I found the reference in Brewsters post.
  #690
Old 01-06-2008, 01:16 AM
Brewster's Avatar
Yeap, your correct, I didn't read the spec WRONG!
SORRY!
  #691
Old 01-07-2008, 08:29 AM
Brewster's Avatar
I misunderstood the spec and was thinking non-A/C cars for the Fan question. Sorry !
Bob, I hear you about the selling the sled which is something I thought about as well. If your going on a trip anytime this year let me know and maybe we can meet up some where?
  #692
Old 01-09-2008, 10:33 PM
Brewster's Avatar
Here is one for under 10k!
http://cgi.ebay.com/ebaymotors/Ponti...spagenameZWDVW
  #693
Old 01-09-2008, 11:41 PM
rwinkles's Avatar
rwinkles rwinkles is offline
Yeah, sure.....only wants $9800. I like the options listed too:
Options
Sunroof Leather Seats Cassette Player 4-Wheel Drive
Anti-Lock Brakes Driver Airbag Passenger Airbag Side Airbags
I think I'd avoid this one.....
Dick Winkles
1970 RAIV GTO 4-speed
1974 Original owner Z-28 4-speed
2008 SRT10 Viper Very Orange (was SD TA!)
2015 Challenger Hellcat 6spd (was SD TA!)
  #694
Old 01-09-2008, 11:45 PM
spb350 spb350 is offline
Gee I wonder if that guy on ebay would take a little less if I sent him a Western Union wire gram real quick. LOL
73 Trans Am Red/White #'s match 4spd...... sold
69 Firebird 400 conv #'s match AT Blue wht/wht
06 Vette conv Red/Red/Blk
  #695
Old 01-10-2008, 01:09 AM
Hey guys! You snooze, you lose!
I just bought this car for $9800, it is matching nos, rust free, original paint.
I sent him the money, he is going to deliver it for free!
I know I can trust him, but his english wasn't so good.....
I thought it was strange he wanted me to wire the money to a foreign bank......
But I really got a great deal on this car!
You know what they say about me, "He's from Kansas, he trusts people!"
  #696
Old 01-10-2008, 11:28 AM
SD73's Avatar
SD73 SD73 is offline
He must have two. He made the same deal with me. I trust him. He seems like an honest chap!
  #697
Old 01-10-2008, 01:13 PM
Norwood's Avatar
Norwood Norwood is offline
What's up with that? I wired him the $$$$$$$$ already.
  #698
Old 01-10-2008, 04:32 PM
x-bird2 x-bird2 is offline
Don't worry, you will both get your car. all i need for you to do HOWEVER, is to cash a check i am sending you that will cover the shipping and taxes. I will be most generous and make said check out for an additional 5,000. all you have to do is provide me half of that sum back in the form of a direct deposit to the account number i provide and the rest is yours to keep for your troubles.... As for you mr too manyu birds, before isend car to you, you must prove yourself as man of honor. i feel a scammer does try to steal me from money. here in ubjugandaigdjuf we put on ladie's pink dress, hold propane torch between our legs pointing upand dance the mak ugh dah fertility dance to prove our manhood. if you wish car for moneys, please prove your manhood by pleasing us with a film tape of you in our ritual dance. then i send car.
  #699
Old 01-13-2008, 02:02 AM
Brewster's Avatar
Yeap, another scam!
Ok, what about the Beer? who likes EXTRA STOUT?
Now where talking!
  #700
Old 01-13-2008, 08:12 PM
Super Duty D's Avatar
Super Duty D Super Duty D is offline
I'd bring my car over the day that happens. I'll be the first one to put you on the trailer Brew! LOL
SDD: Because you don't do the TQ thing like the rest of us does that mean that you are driving all the way to Dayton? I'd like to see that! LOL
I love this talk thing. It's so affordable!
Bob, you are welcome to race Brewster and his car down my street anytime, Extra Stout vs. Miller Light, beer or no beer, 4-Speed against 4-Speed, one on one.
Will that close ratio transmission of yours send Brewster to the trailer early on or will it be up to the drop of the flag and some fancy clutching?
Yes Bob, talk is cheep.
SDD
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
72 442 W-30 auto, post coupe Bamboo. 1 of 19 total.
90 300zx TT 5spd.
