Old 01-24-2008, 09:08 AM
66rag 66rag is offline
Default Gear Shift
Is the 4-speed gear shifter the same as a 3-speed gear shifter for a 64 Catalina? My 4-speed shifter needs to be replaced and I have located a 3-speed shifter. Help!! Thank you.
Old 01-24-2008, 11:00 AM
Bill Hanlon's Avatar
Default No such luck
4 speed shifter controls three arms on the side of the tranny. 3 speed shifter controls two.
Old 01-24-2008, 11:04 AM
65WJ's Avatar
65WJ 65WJ is offline
Send it to Hurst to get rebuilt or contact Peter Serio (sp). I believe he post here. He wrote a very nice and informative book on the Hurst shifters.
patrick
Old 01-24-2008, 12:38 PM
have tried contacting hurst [mr gasket] directly? iirc, the competition plus unit will replace the oem shifter on those cars.
either of the rebuild options above are good choices also.
mike
former." --Albert Einstein
- Winston Churchill
Old 01-24-2008, 02:26 PM
Stuart's Avatar
Stuart Stuart is offline
You are talking about a floor shifter for a manual transmission? Depending on whether you had a Catalina or a Bonneville, there were three and four speed automatic transmissions that year with column shifters...the column shift components for the autos are the same, but there are probably some differences in linkage underneath the car that connects to the transmission.
Old 01-24-2008, 04:36 PM
wfbarto's Avatar
wfbarto wfbarto is offline
patrick
Peter Serio did one for me years ago....nice job...nice guy...good deal!
1966 Bonneville Convertible, 421, 4spd. (in progress)
1966 Bonneville 4 Dr. Hdtp. (survivor)
1999 Trans Am Hatchback, red, 6 spd.
Old 01-24-2008, 06:54 PM
stevep's Avatar
stevep stevep is offline
If it is the original (not Hurst) shifter, it may be the same or similar as a 63 Vette.
I have a 64 2+2 4 speed with the original shifter in my shop right now and Pete Serio could not rebuild it.
Old 01-24-2008, 09:23 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Fabcraft has the 4 speeds w/ Hurst components.
If I remember right there are a couple of different 3 speeds. There is an HD and a regular. The shop manual shows a Pic of one that has a feature in the linkage that mine does not have. I posted here trying to find out what the difference was. Archives might have some Pics.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
