Yeah, loved the '70s Saturday morning cartoon lineup. Don't know what happened to that.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
So I am starting to get myself a little confused....
So Parkerizing is the same as black oxide for a black finish. Is phosphate magnesium also the same? The images I saw in the video above do not look like black oxide to me. more of a gray slate color? they look close to the correct color for our hood hinges & maybe they are? Palmetto sells both Manganese & Zinc. the whole thing seemed simple to me until I dug a little too deep ![]() Here's an image from 5 minutes into the video.
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA Last edited by 68ragtop; 11-29-2016 at 03:03 PM. |
Manganese Phosphate is the black plating - bolts brackets Black oxide is a different finish. It was oily and not very durable. On some of the brackets that didn't plate well, I used the Eastwood Zinc Phosphate paint. It looks perfect. Great for hinges. If you need it a bit blacker, dust it with flat black from a distance. it will darken and still retain the sparkly look.
If you want to see some gray phosphate and black (magnesium) phosphated bolts I did a couple of years ago with the Palmetto solutions, you can stop by and see for yourself since I live just outside of Green Bay. I will also show you my setup that I made with a cheapo temperature controller, hotplate and some pvc tubing that holds the sensor in the solution. If you pm me with your email address, I'll send you a write up on it. Old Joe
68 Firebird Convertible 68 GTO Clone (Tempest) Wagon |
After getting your responses and a healthy dose of online searching, I'd say a "best phosphating oil" thread would make "best cam" and "best motor oil" threads seem tame.
I decided to use WD-40 Specialist Rust Inhibitor (Link to Datasheet) on phosphated parts. After seeing Cortec's vapor inhibitor technology and line of products I was impressed. I asked one of their sales reps for a recommendation for phosphated steel and he promoted their VpCI-369 (oily/thin) and VpCI-368 (waxy/thick) products, both containing proprietary VCI inhibitors. He suggested buying through "The Rust Store" (Link to The Rust Store), which carries a lot of reputable products. Cortec backs up their products with this "motherload" of credible test results: Link to Cortec Competitive Test Report Library I also believe that WD-40 Specialist Rust Inhibitor is actually Cortec 369. So these were on my short list. I then stumbled across this online summary of a gun hobbyist's corrosion test. It was done well enought to clearly differentiate the performance of a VERY LARGE number of products: https://dayattherange.com/?page_id=3667 Here's an image showing the range of performance in that summary: In this test, the WD-40 Specialist Rust Inhibitor finished in the top 3, beating out Boeshield T9, CRC 3-36, CorrosionX, and many other good products. I was going to order Cortec 369 but when I found the WD-40 product in stock at Home Depot for about $10, I was done. There are obviously lots of products available to us that would work well as a phosphating oil but this WD-40 Specialist Corrosion Inhibitor seems a good value to me. Mike |
68bird, I bet that's Pat?
How about a "bluing" that I have seen on bolts. There are crank dampener bolts that almost look like gun bluing, was that common in the early 60's?
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
Yup, its Pat.
Yep, the Manganese Phosphate is typically used to imitate the black oxide ... which is impractical to do in a home shop environment ... and the Manganese Phosphate is probably superior to black oxide anyway.
I'll often use the zinc phosphate on parts that are supposed to be natural metal in color, but would otherwise rust immediately without paint or some kind of treatment. |
I noticed the manganese phosphate appears to have sparkles in it too. Is this picture a fair assessment of what the two look like? I'm thinking I might try the manganese phosphate methods, then lightly paint the parts to look more like black oxide. maybe the best of both worlds that way? looks & protection?
So which is parkerizing? I thought somebody said that was the same as black oxide? Sorry to beat this to death, I just don't want to move on spreading bad information ![]() I am thinking the Zinc would be great on the hood hinges? I have a really nice set of rust/pit free hinges I plan to use. They do have some grim & overspray on them so they need to be restored with some method, I just haven't gotten that far yet. This picture is supposed to be manganese phosphate (left) next to black oxide (right).
Black oxide is a different animal. The left is black (manganese) phosphate. The right looks like black zinc which you see on newer hardware but dont think they used on our cars back then. Dont confuse black zinc with zinc phosphate. Two completely different things. Zinc phosphate is like manganese phosphate except it is grey instead of black.
For natural parts, i just hit it with a good satin clear. I like VHT spray paint for this.
Just found out Scott is no longer in business with Palmetto Enterprises.
Hhmmmmmmm. Is there another source?
The bolt on the left .... the sparkles are salts that come out of solution as the parts dry. Parts should immediately be rinsed in oil after plating ... I think some people rinse in water then oil .... then I let them soak in oil over night at least. They look darker and shinier when properly handled after plating.
Bolt on right is ether oily black oxide or something else. Manganese Phosphate leaves a somewhat rougher finish than Black Oxide. You MUST rinse and oil the bolts thoroughly after cooking them or they will rust, turn gray and salty almost immediately. Do a search on Manganese Phosphate and a bunch of sources will show up, mostly kits for firearms ...which will work fine for bolts. I'm sure Caswell also sells the kits. |
In this post is a picture of some control arm bolts I treated with Manganese Phosphate, and then rinsed in WD40 and soaked in oil.
http://forums.maxperformanceinc.com/...9&postcount=17 Here is a site that might offer some info that would be helpful. http://www.nulltime.com/zincplating/index.html |
Thanks again, part of what what was initially confusing me is some people were combining different minerals & chemicals to get to the same end process. What I realize now is people were basically making their own manganese phosphate, when others just buy it in a bottle. I would rather not make it myself and add another variable it it. Doesn't seem expensive anyway pre made, just need a source to get it. I will look into Caswell.
Also, about 6 months ago I bought a bunch of fasteners from AMK. I thought these were all black oxide, but now looking in the book I ordered from it says they are finish S2 which is referenced as "phosphate". I would assume that is manganese phosphate even though it does't say that in the book? Here's a picture of a few of the fasteners. They are very black. not oily at all. If I could get mine to turn out like this I would be ecstatic Here I had examples right under my nose.
ESS-M3P20-A
(S2) Zn Phosphate 72 S2 is a Zinc Phosphate and Oil treatment. Found this paragraph in on a metal coating website which seems to indicate they can color zinc phosphate for a nice black finish. ____________________________ Zinc phosphating can extend the shelf life of your products in corrosive environments. By combining our zinc phosphate treatment with rust-inhibiting oils, wax, and other organic coatings, we can help your product withstand harsh conditions and up to 168 hours of continued salt spray. Jackson Tumble Finish has the ability to coat heavy, medium, and fine grain zinc phosphate, along with black phosphate and other color options. __________________________________________________ ______________ Unfortunately at this point Caswell may be the only reliable source .... next time I buy some manganese or "Parkerizing" solution I'm going to try a gun smith supply store. Typical firearm Parkerizing is usually very close to black. |
Here's a screen shot from the parts book for finish references:
According to your chart, S2 is phosphate & oil (gray - black). Zinc phosphate is the gray, manganese phosphate is the black (aka black phosphate). The latter is correct for your hardware. As Dataway said, when you oil them, they don't look as dry. Depending on what is used for the "oil", it seems that it can evaporate out, esp if it is something like WD40 (which is really not a good protector). Then the protection won't be very good and they will rust. That is why I used Boeshield. That is supposed to penetrate and protect bare metal, so I figured it would be great for this.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue Last edited by 68bird400HO; 12-03-2016 at 03:21 PM. |
What I was trying to point out is that some S2 zinc phosphate coatings my very well have been "colored" to be more black than zinc would normally be. Without coloring or other treatments manganese is going to be more black than zinc.
Black Oxide is more black than either ... but from what I have gathered it is beyond the capability of the average restorer to do "real" black oxide, which require some high temps and more exotic chemicals. |
I only posted the chart because of the S2 meaning possibly being something other than what AMK listed them as. I didn't think they where something other than what I ordered, but I never say never to anything
I like everything we are all adding to this thread. Lots of good info. Seeing palmetto is no longer an option, I see there are phosphate kits on ebay that are calling their product black phosphate. not sure how its better than manganese, unless they are adding something to it? Were our cars originally supplied with black oxide? I used to think so but was reading somewhere that they where in fact manganese. But, that was on a ford website. While I think I have a plan of attack now, I still enjoy learning more about anything car related. We used to use cheap black oxide self tapping ground screws at a shop I worked at in the early 90's. those things would rust so fast, they might have well had been bare steel
