Old 08-18-2007, 05:40 PM
SergeF SergeF is offline
Default help installing pontiac into 69 c-10
I just bought a 69 c-10 long bed. Truck is all original 350/400 and a 12 bolt. I have a 400 I want to install in place of chevy 350. I heard that 70-79 firebird headers will fit. I have almost everything that I need. I need some pics of the motor mount plates. What motor mounts do I need? Anything else I will need? Thanks
Name:	chevy truck 001.jpg
ID:	101963   Click image for larger version
Name:	chevy truck 002.jpg
ID:	101964   Click image for larger version
Name:	chevy truck 003.jpg
ID:	101965   Click image for larger version
Name:	chevy truck 004.jpg
Old 08-19-2007, 04:45 AM
performerrpm's Avatar
i cant offer much help but i guess when your done you'll have a 69 p-10 i was gonna put a 455 in my 82 gmc. it seems like ive been told the mounts on trucks are the same as most cars with 350s and you will only need to find a mount to fit your motor iam thinking a t/a mount would work
Old 08-19-2007, 10:16 AM
gwhammy gwhammy is offline
It's been awhile since we have done this swap but I think we used car frame mounts and welded them to in once the motor was set. On a mid 70's truck the shroud off of the truck worked with the pontiac. I don't remember what header we used but a couple of the swaps had headers and one had big car performance manifolds on it. I haven't done a swap into a truck since the late 80's so it's kinda foggy on what was done.
Good luck
Old 01-30-2008, 11:25 PM
junkcollector junkcollector is offline
Just get you a set of frame mounts from a 73 and up to about 87 I think it is chevy truck. Then use your 3 bolt hole pontiac motor mounts and clamshells. I had to move the mounts about a half inch if that and it all lined up. I have a Pontiac 400 in a 71 C-20 with a longtail turbo 400. Was a piece of cake.
Old 01-31-2008, 01:25 AM
engineer engineer is offline
chevy frame mounts differ from Pontiac ones. can't mix and match. Later pontiacs used metal motor mounts and rubber frame mounts, chey did just the opposite. suggest you get the later pontiac frame mounts from the auto store and bolt them it onto the frame. holes should be there already.
Old 01-31-2008, 07:29 AM
I used the chevy frame mounts like I said and pontiac motor mounts and clamshells like I said, other than that the frame mounts had to be adjusted about a half inch so that the trans bolted to the crossmember and the driveshaft didn't need shortened. Worked perfect in my truck!
Old 03-16-2008, 12:02 AM
vin63's Avatar
vin63 vin63 is offline
Here's what I've been working on for my '63 Chevy truck project - 455 Pontiac with KRE D-Ports. I just finished mocking up the frame mounts using a set of Indian Adventures conversion motor mounts for a non-corporate block into a late model GM. I'm using a set of Hedman swept-back, shorty headers since my truck will be pretty low in the front.
ID:	125831   Click image for larger version
1963 Tempest Convertible
Pontiac-Powered Funny Car:
400 block, Littlefield 8-71 blower, Enderle injection,
custom blower intake, three-disc glide clutch, three-speed Lenco
