Old 01-30-2008, 12:26 PM
JDSTRIPES JDSTRIPES is offline
Question WHAT IS THIS FOR
I just found some sort of thermostatic valve that passes thru the passenger side exh. manifold just above the flange. It has some type of heat actuated coil and a lever on the other side. There is no spring tension so I dont think it is connected properly
Old 01-30-2008, 12:33 PM
runningbwdog's Avatar
runningbwdog runningbwdog is offline
I think it is for faster warm-up of the engine. Remember there is a exhaust crossover under the carb on the intake manifold. This valve restricts the flow of exhaust out that side and forces it to go through the crossover. The spring relaxs like the cookstove spring for the choke when it get hot and opens up the valve plate. High exhaust pressure is also able to overcome the spring when driving.
Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels
Old 01-30-2008, 12:39 PM
This one seems to be shot. Are there replacements available? Or is there some sort of retainer for the spring ?
Thanks for the quick reply Dawg
Old 01-31-2008, 08:17 AM
BLKBRD BLKBRD is offline
Most guys just pull it out and either weld up the holes, or tap them out and plug them. These things are notorious for freezing up. That's probably why they dropped them in '69 (if I remember correctly).
Old 01-31-2008, 10:25 AM
firetruker1's Avatar
firetruker1 firetruker1 is offline
It is to divert hot exhaust to open the choke more quickly. if removed the choke will stay closed longer and may cause the car to load up. It does make the hot exhaust go through the intake manifold.
Old 01-31-2008, 11:39 AM
Question
Anyone have a detailed pic or digram of how the coil mounts? Looks like a slit in the end where the coil mounts near a small stud that it may hook on. Does the coil need to be preloaded and, if so, how many turns ? Also found a small retainer.
Old 01-31-2008, 12:16 PM
surfnuke9's Avatar
surfnuke9 surfnuke9 is offline
the flapper valves were used much longer than up to 69.
The 77 engine I just got has one.
- Tim
68 Tempest Custom Convertible
71 Dodge W200 3/4 ton 4X4 4 speed
Old 01-31-2008, 07:04 PM
gto4evr gto4evr is offline
67 was the last year. 68-74 didn't use them, must have brought it back by 77. The spring was tensioned against a pressed in pin on the side of the manifold that rusts off. I think they're making repro pins if you don't want to use a nail.
Old 01-31-2008, 09:54 PM
surfnuke9's Avatar
must have, since it is there and is original and has a vacuum actuator.
- Tim
Old 02-01-2008, 02:11 AM
The ones they are talking about from the '60s had no vacuum actuators. It was strictly a bi-metal or similar spring with a counterweight. When the spring got hot enough, it expanded to open the valve and allow the gasses to pass out of the exhaust rather than up through the intake crossover.
They were kind of bothersome and everybody just hoped when it froze, it would be in the open position.
Old 02-02-2008, 09:48 AM
AMH555's Avatar
AMH555 AMH555 is offline
Isn't that thing called a heat riser valve? They are notorious for rusting shut, at the station I worked at in the 70's the mechanic would weld them open or take them off and put in hand operated choke kits.
Old 02-02-2008, 10:06 AM
quicksilver97ta's Avatar
My 70 Lemans has the one without the vacuum actuator and it's all stock.
Old 02-02-2008, 04:20 PM
Flowjoe's Avatar
Flowjoe Flowjoe is offline
That's what I've always called them. I've had to replace a few over the years, usually the muffler shop has them in stock.
