Old 03-10-2008, 05:31 PM
andrewb70's Avatar
andrewb70 andrewb70 is offline
Default 1970 GTO Version 2.0
As many of you know and many don't, my 1970 GTO was done in October of 2002.
http://www.popularhotrodding.com/fea...gto/index.html
Since then it has lived a rather quiet life. Mostly in storage. Due to some issues in my personal life and a lack of interest, the GTO was a bit neglected over the last 4-5 years. Well that changed this past weekend. I finally sold my fuel injected 502 big block. The engine will have a happy home in a Chevelle, where it belongs.
Stay tuned for more details and future upgrades.
Andrew
ID:	125196   Click image for larger version
ID:	125197   Click image for larger version
ID:	125198   Click image for larger version
ID:	125199   Click image for larger version
Old 03-10-2008, 05:45 PM
Silver Judge's Avatar
You did a great job on that '70 Andrew and I remember that some folks on this board were up in arms about the chevy power thing. I still think that your '70 is a mighty nicely done car ! I almost did some of the same modifications that you have done.
Are you thinking of going with a pontiac engine now ?
501 HP, 554 ft lbs TQ
Old 03-10-2008, 06:40 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I clearly remember that project, it was ahead of the curve for sure.
Old 03-10-2008, 07:58 PM
andrewb70's Avatar
Thank you for the kind words guys. No doubt many of you would like to see traditional Pontiac power under the hood. The goals of the project are to reduce the overall weight of the car, improve the weight distribution, increase fuel economy, retain low to mid 12 second drag strip performance, improve serviceability through the use of as many OEM parts as possible, improve overall dependability, make adjustments to the suspension to improve handling, lower the stance slightly, and have FUN!
Andrew
Old 03-10-2008, 08:43 PM
Overkillphil's Avatar
Overkillphil Overkillphil is offline
Looks like a perfect candidate for that sweet aluminum Pontiac block...
___________________________________
"Objects in mirror are closer than they appear"
Old 03-10-2008, 09:37 PM
andrewb70's Avatar
Unfortunately that is way out of the budget :/
Andrew
Old 03-10-2008, 11:14 PM
Stuckinda60s Stuckinda60s is offline
A 455 is lighter than a Big Block!!
Rich
Old 03-10-2008, 11:59 PM
andrewb70's Avatar
Rich
Not 300 pounds lighter.
Andrew
Old 03-11-2008, 06:22 AM
boater bill's Avatar
boater bill boater bill is offline
A 455 w/ aluminum heads might be though!
With your performance and driveablity goals, are you going fuel injection or forced induction?
Old 03-11-2008, 06:45 AM
ponjohn's Avatar
psssst.....LSx?
Old 03-11-2008, 10:35 AM
andrewb70's Avatar
Cool
Originally Posted by ponjohn
psssst.....LSx?
Yes Sir!
Andrew
Old 03-11-2008, 12:16 PM
Are LS9s available over the counter yet?
Old 03-11-2008, 04:45 PM
andrewb70's Avatar
Not yet. Its going to stay NA.
Andrew
Old 03-12-2008, 07:05 PM
1972 Formula 400's Avatar
1972 Formula 400 1972 Formula 400 is offline
Looks great, should have went with a Pontiac power plant though
Old 03-12-2008, 08:58 PM
andrewb70's Avatar
Yea yea....LOL
Today I dropped off the big block at its new home and picked up an L92 truck engine. The big ugly truck intake will need to go, as will the water pump and balancer. I also picked up a take out LS7 cam, LS7 valve springs with retainers. I will post pictures of the new engine tomorrow.
Andrew
Old 03-12-2008, 10:17 PM
wrenchmen's Avatar
wrenchmen wrenchmen is offline
Considering the quality of your GTO and your choice of components, that is a very interesting statement....especialy to someone like me who is currently in the begining stages of a restification.
With all the aftermarket components avalable, particuarily suspension and brake and from someone who has "been there, done that" is there any words of advice or thoughts you can give based on your experience?
1970 Lemans Sport, PPR 383/4spd.
Old 03-13-2008, 12:34 PM
andrewb70's Avatar
When starting a project I think it is very important to have a goal in mind of what you envision your final build to be. How often will it be driven? Will it be raced? Drag? Road race? How often? All those things play an important role in determining what product to use on the car.
Take for instance the brakes. In retrospect I went way overboard. I wasn't realistic with myself about the use of the car and I made the brakes more complicated and more expensive than necessary. When I built the car it was very common to upgrade to the b-body spindles and custom upper control arms. This addressed the suspension geometry issues and allowed the use of some large OEM brakes. The b-body swap also has a bit of a dark side, with increased bump steer and a reduced turning radius due to the longer steering arm . In the last few years the ATS spindle has emerged as the best of both world solutions. It fixes the geometry issues without inducing other negative effects, and it allows the use of the c5/c6 brakes, that are relatively inexpensive and very well engineered. With the introduction of the C6 ZO6, you can now get an OEM quality 6 piston caliper with a 14" rotor. That is the way to go in my opinion if the car seem mostly street driving with an occasional romp on the road course or auto cross.
There are other systems, such as aftermarket EFI in comparison to the latest OEM hardware and software that GM uses to run their modern engines. The amount of effort that the OEMs spend on IDLE would easily surpass the combined engineering efforts of many, if not all aftermarket EFI companies, combined.
Andrew
Old 03-14-2008, 07:06 PM
andrewb70's Avatar
Here is a picture of the starting point for the engine. It is a L92 that is used in various GM SUVs. 6.2L in displacement.
Andrew
Old 03-14-2008, 07:19 PM
Wow, a GM truck engine ?
I guess it is too late to suggest a Pontiac power plant ? Either way, this will be interesting !
Old 03-15-2008, 07:48 AM
ponjohn's Avatar
Andrew- that is an iron block--correct?
Are you planning on boosting it?
What trans?
John
