Closed Thread
Old 03-14-2008, 02:31 PM
goatasaurus rex's Avatar
goatasaurus rex goatasaurus rex is offline
Default Pete McCarthy 476hp 400 article
this was published in HPP in the early 90's. could someone e-mail me a copy?
thanks,
bob
69 GTO 11:[email protected] all balls no bottle
406 d-port iron heads 3700lbs all steel
Old 03-14-2008, 02:54 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
I have it but I know I could never find it. Call Pete or Jane if nobody can produce it. The # is on his website.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 03-14-2008, 05:23 PM
65gto69's Avatar
65gto69 65gto69 is offline
I have it, I am scanning it in as we speak. Post your email and I will send it to you.
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 03-14-2008, 05:49 PM
mechanic17 mechanic17 is offline
Me too, please [email protected]
Old 03-14-2008, 06:33 PM
jm455ho's Avatar
jm455ho jm455ho is offline
If it's not too much trouble, I'd like to see it also.
[email protected]
www.hobracing.com
Old 03-14-2008, 07:16 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
isn't it the same as the one from SD performance that was in Car Craft ?
www.pro-touringf-body.com
Old 03-14-2008, 07:22 PM
screamingchief's Avatar
Hmmm,I checked my article collection,did'nt find it,dont seem to recall the article that well either...
All the Pete M. 400 cid articles I have are higher hp builds.
Anybody care to post the relevant specs for discussion?
I cant expect 65gto69 to send everybody a copy of the article.
Maybe post the scans for those interested in this topic.
This space for rent...
Old 03-14-2008, 07:28 PM
I have that Car Craft article,hp on that build was 459 hp @ 6000 RPM.
No mention of Pete M. in the CC article either...
Old 03-14-2008, 07:42 PM
65gto69's Avatar
Good idea but it is too big. The article is 3 pages and in order to have good clarity I scanned them in at 150 dpi 8-bit grayscale, file size is 6 megs or 4.5 megs in pdf format.
If I can post it I will, but I don't know how clear it will be if I take it down a lesser amount.
Thanks,
Mark
P.S. The article is in the April 1992 issue, under "Indian Head"
I just tried lowering the scan dpi and the article is still clear, so I will post each page separately.
Old 03-14-2008, 07:43 PM
pro-tour79's Avatar
that's the one I remember, ok
Old 03-14-2008, 07:55 PM
Yeah,I know it can be tough,I usually chop the articles up into smaller snap shots from the PDF files and convert those bits to JPEG's for posting,that usually keeps the printing clear enough to read here with the forum size limits.
Works for pics too.
Usually ends up taking a couple of posts to get a whole article posted though.
I could probably do it if need be.
Email: [email protected]
Old 03-14-2008, 08:05 PM
65gto69's Avatar
Here ya go!!!
Page 1, 2 & 3. I know it is in a microsoft word DOC file but it is the only thin I could use to get the file size down to 300k.
If you can't read a DOC file let me know and I will send it to you via email
Mark
[email protected]
Old 03-14-2008, 08:20 PM
65gto69's Avatar
OK, here they are in JPEG format
Mark
ID:	125672   Click image for larger version
ID:	125673   Click image for larger version
Old 03-14-2008, 08:38 PM
Mr Twister's Avatar
Thumbs up
Goat, I have the mag. Remind me to bring it next time we get together-GET the goat ready, I want to go to the strip! First 5 gallons of race gas is on me.
Old 03-14-2008, 09:25 PM
Motor Daddy Motor Daddy is offline
Great article!
Note the serious increase in power with the Torker II over the performer manifold. Also note the increase in power with the Holley 850 compared to the Q-jet!
A very well written article and a great test of the mighty 400. Just imagine what that 400 could do with a set of 300 CFM heads, good rods, a stout solid roller, and a good single plane manifold.
Old 03-14-2008, 09:31 PM
Originally Posted by motor-daddy
Great article!
If I remember right this motor went on to get an offset ground 400 crank, 6.800 rods, roller valvetrain, Warrior intake,1150 and the 670 heads were around the 279 cfm range. It ended up in the Verdoro Firebird that Joel Larkin now runs in Super Stock. I haven't heard where the motor ended up but it did run well.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 03-15-2008, 12:32 AM
GOAT490's Avatar
GOAT490 GOAT490 is offline
Only 400cubes and a Hydraulic cam and it really liked the 1 7/8" stepped headers. And people still think 2" headers are "Overkill" for 455plus engines?!!
PHILLYGOAT
PHILLYGOAT
1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/
3550lbs/ Full Exhaust/ Foot Braking
1.41 60ft [email protected] [email protected](Pontiac Heaven)
More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379
GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4
Old 03-15-2008, 09:16 AM
pro-tour79's Avatar
Another jab at Cliff I see!!
Old 03-15-2008, 09:53 AM
BDHABT's Avatar
BDHABT BDHABT is offline
I used the 246/253 duration cam in my 455 way back when.
That was an awesome grind.
Went 12.01 time after time.
Heres a quick breakdown:
Car weighed 3750 at the time.
455 .030 TRWs.
No 13 heads,unported.Just a valve job.
Stock T-2 intake.
Holley 850.
1.75 Heddman headers.
Comp Roller tip rockers.
Torque Tech 3" exhaust with tailpipes.
Generic TCI 3500 conveter.
3.89 gears.
Cam was also advanced 4 degrees.
Gave alot of Mustangs the whooping;as that cam was very streetable.I drove that thing everywhere.
Mark.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 03-15-2008, 10:00 AM
that's a deal twister!!! who's buying the beer??? smitty???
Closed Thread
