Old 03-19-2008, 04:16 AM
screamingchief's Avatar
Most of the good ones have been mentioned already.
I agree with PTC,Neal Chance,and continental as very good choices.
Also would consider ATI,and coan at times as well.
For budget "street/strip" stuff,I would look into a redneck,hughes,or possibly a BTE converter or such.
I always avoid TCI,B&M,and such "high volume" brands as SOP.
This space for rent...
Old 03-19-2008, 10:27 AM
http://www.transmission-specialties.com/ These guys are good to work with I have had good to excellent results with a street convertor that did exactly as promised. A close friend has been using one of there spragueless convertors behind his 540 BBC trans brake combo that runs in the eights. He too has been very pleased going on 6 years with no indication of needing refresh. It has worked as promised also. FWIW they also manufacture components for other convertor companies.
I have also had Turbo Action convertor that flashed 5200 rpm on a 4400 rating but was well coupled through the lights, A POS B+M and an old Fairbanks generic 10" back in the 70's that left a lot to be desired.
Old 03-19-2008, 11:52 AM
BILL BOWMAN1's Avatar
ATI
Old 03-19-2008, 05:50 PM
bigchief468's Avatar
bigchief468 bigchief468 is offline
Default NSS CF/X
I have used ATI for years with good results running 9.6 to 9.9 in a 3400 lbs car. I like their service shipping times.
Old 03-19-2008, 05:51 PM
Probird's Avatar
Probird Probird is offline
BTE
Old 03-19-2008, 06:18 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
TCI - 9"
See sig below.
But I am going to try a PTC 8" later in the year.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 03-19-2008, 09:46 PM
Marty Palbykin Marty Palbykin is offline
Marty's at Chance converters is first class for big power stuff.
Never had any luck with ATI or Coan.
Marty P
Old 03-19-2008, 09:50 PM
67'7F6'Bird's Avatar
67'7F6'Bird 67'7F6'Bird is online now
I went with "PTC" - Just received it today. I can't wait to get it in.
ID:	126337   Click image for larger version
Old 03-19-2008, 10:34 PM
ONEFASTLEMANS ONEFASTLEMANS is offline
TCI, when i got my converter last year, they did miss alittle on the stall,but it was a brand new motor, so i wasnt even a 100% sure,ran it alittle to see what it needed , sent it back no problems and they nailed it perfect when it came back,the service was great,i did try a coan a few years back... sold it at a swapmeet for half of what i had into that pos
Old 03-19-2008, 10:46 PM
02Hawk's Avatar
02Hawk 02Hawk is offline
TCS out of Vancouver builds a great converter. Even custom race ones come with a two year warranty. I have never waited more than two weeks to get one shipped to me and they have taken them back and repaired them no questions asked
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
Old 03-19-2008, 10:50 PM
Jesse N.'s Avatar
Jesse N. Jesse N. is offline
My vote is for PTC. Oops Pontiacdude already said that, my bad
Seriously, I have had good luck with PTC and their customer service is really good. I had an issue pushing through the 9.5" so they upgraded me to a 10" pro-mod style for no charge. No complaints at all from me.
Brand X A-body, twin turbo 540 running e-85, 1455rwhp @ 25psi, 8.66@166 on 20psi, 4000+lbs, 3.25 gears, thru tailpipes and on radials.
Wifes car: 70 gto, waiting for me to build a single turbo 467
Dad's car: 68 gto conv. 12 to 1 455 on e-85
Old 03-20-2008, 12:36 AM
Tim Corcoran's Avatar
I know the question was relasted to high end race motors but I have to give a plug for Contental. I got a 10" continental from Chris years ago, back then it was street strip use. Over 13 years later I am still running the same converter running 10.50's in my 3550lb 65 LeMans. Sent it back once about 5 years ago to get it loosened up as I upgraded my performance combo. Now stalls at 4400 and the car 60's very consitently in the low 1.4's foot braking. I did run it one full season using a brake but went back to foot braking because I couldn't cut a light with the brake. I couldn't tell you how many 100's of trips this converter has gone down the 1/4 mile. Just my .02.
Tim C
Tim Corcoran
Old 03-20-2008, 01:15 AM
cooke's Avatar
cooke cooke is offline
Originally Posted by Jack Ferris
My guess is whoever you pay the most money to develope the best one for your application. Mike Munsinger is probably one of the best specialty builders in the industry. Continental works for me.
Ditto for Munsinger. We had him build us an 8" for our D-port 400 back in 95'. In 02' we sent it off for refreshening and loosening( we were putting it with another car/motor combination). When I called him before shipping; and gave him the serial #, he immediately pulled up his records he had taken back then and still had all the specs on it. He had it about 3 weeks and returned it back and it was dead nuts on the money. Against alot of advise; we sprayed this particular combination with 350 HP shot (TH400,3680 lbs 800HP N/A) and the converter was going to 5200 rpm on the brake. Probably wasn't a good idea; but we never did "drive" through the converter. It did was it was supposed to and ran the heck out of the MPH.
Good guy and stays in touch with the customer.
Old 03-20-2008, 10:57 AM
A fresh tranny and an 8" A-1 picked up my car 0.75 seconds!
I tried to order a Munsinger years ago when doing the NMCA racing as alot of the "stockers" used them. 6 months later he was stil too backed up to get one made for me. But heard good things about them.
Old 03-20-2008, 11:36 AM
Indian Uprising Indian Uprising is offline
I have a JW Sportsman.... I like the customer service and John Winters seemed to a have a good understanding of pontiac engines and their torque profiles.
Old 03-20-2008, 11:37 AM
imposter's Avatar
imposter imposter is offline
Default converter
http://www.coanracing.com/
Old 03-21-2008, 07:36 PM
XSIVPWR's Avatar
XSIVPWR XSIVPWR is offline
I've had a TCI in my car for 8 years now with zero problems. The best? probley not, but it works for me.
  #38
Old 03-21-2008, 10:52 PM
PONTIAC DUDE's Avatar
Cool
Glad you got a decent product had good customer service.
Just throwing it out there.
Nothing like sending them a t-400 splined converter for a PG and stated so with the supplied sheet to change the stall. Wait 2 weeks. Get it back with a PG spline fighting for and hour to get it in the tranny. And admit it on the phone after they located the paperwork. Then pay BOTH ways and another 2 WEEKS before getting it back. That a 2 customers and few years ago with Pontiacs and new fubar'd T-400's out of the box.
JW doesn't get my vote.
  #39
Old 03-22-2008, 01:42 AM
I have heard good and bad about them ... I guess I got lucky
