Hello, I am looking at a 66 Lemans. Does anyone know the overall length? I have a micro garage and want to make sure it will fit before I buy it! Also, is there a web site that I can get that kind of info. I can find many about the GTO but not the Lemans. Stuff such as options, transmissions etc. Thanks, Jeff
WELL SOME OF THE GTO SPECS ARE THE SAME AS THE LEMANS
Thanks, I do realize that in most aspects they are the same car. I understand the Lemans came with 2 different HP 326's. How can you tell the difference? What transmissions were offered. Waht options were offered. Options-Are there any differences from the GTO to the Lemans? What were the production numbers for the Lemans? Were there 3 styles like the GTO- HT, Sedan and Convert?
Things like that that I can't find just for the Lemans line. Sorry if my questions sound stupid but I am new to the Pontiac world. I am trying to get my feet wet with this stuff. Jeff |
My 66 GTO is 16 feet 10 in., I believe the Tempest /Lemans is much the same.
CT Gross---66 GTO "Its never too late to have a happy childhood"! I told my dad I was going to stop raising hell, and he called me a quitter! |
I cant answer all your questions, but the over all length is about 17 feet. Weight is around 3500 pounds.
Many of the options in the GTO (save for motor/trans) were the same. Ive seen a few LeMans with a ton of options and the PHS although its rare to see. As for production, It had to be at least 200,000 units. 66 was the best year for the GTO and I think production was about 90,000 for that year. Motors were the 326 and the in line 6 otherwise know as the Sprint motor. Was there an H.O. 326 in 66 anyone?? I pretty sure there wasn't. I m sure I'm missing a lot of info here, but this the best I could do just off the top of my head. Welcome to the board Jeff. Theres a lot of knowledgeable people here. Dont be afraid to ask any questions no matter how dumb you might think it be. Someone will give you the right answer as we've all been though it. Last edited by Old Blue 66; 03-31-2008 at 08:22 AM. |
Excellent! Thank you guys for the information. I'm sure I will have many more questions in the months to come. Jeff
Try and find a copy of the "Book of Information".
I think it's no longer being printed but may still be found here & there. It has lots of info on all models 64-70. It's just a copy of lots of Pontiac info, but a great source none the less. As far as 66' Lemans engines it was 230 OHC both standard &/or the First year Sprint option. Not all 6's were Sprints. 326 standard & HO as well. The HO had a different air cleaner then the base 326 but you would need to find the codes to tell for sure. As far as a length. My Lemans is 16' 11.5 " (+- .5") edge of rear bumper to edge of front bumper.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
yeah, but you will need close to 19 feet for clearance.
That was my project today. I took cabinets off of the back garage wall.......19 feet exactly! I'm going to pick the car up on Thursday. i can't wait! Thanks again for the info. Jeff
HEY JEFF, I RECENTLY HAD THE SAME QUESTION ON THE LEMANS 326- 326 HO QUESTION YOU ARE ASKING. I DID A LITTLE RESEARCH ON IT. WHEN YOU GET THE CAR . LIFT THE HOOD AND ON THE LEFT FRONT BLOCK THERE WILL BE ENGINE SERIAL NUMBERS THERE.( CLEAN AWAY THE GREASE) DIRECTLY BENEATH THOSE NUMBERS THERE SHOULD BE A TWO LETTER CODE. THERE ARE THREE OF THE CODES TO IDENTIFY THE HO MOTOR . WR DENOTES AN HO MOTOR IN FRONT OF A MANUAL TRANS, YP AND XG DENOTES HO MOTORS IN FRONT OF AUTOMATICS. I FOUND THIS INFO IN A 1966 TEMPEST CHASSIS SHOP MANUAL WHICH IS READILY AVAILABLE ON EBAY. IT HAS BEEN INVALUBLE TO ME. IT MIGHT SAVE YOU SOME TIME WONDERING. I HAVE A 66 CONVERTABLE WITH THE HO IN IT. THESE FOLKS RIGHT HERE HELPED ME FIGURE IT OUT. GOOD LUCK!!!, BRIAN
Brian, I was just looking at that manual on eBay. I think I will get it and the body shop manual as well. Thanks again, Jeff
Brian, I was trying to order some parts today so I have them when I bring the car home. (cap, rotor, points, plugs, wires) They asked me if it was a 2 point dist? Are most of these 2 point? Is the HO a 2 and the non-HO a 1 point? Thanks, Jeff
Wouldn't the H.O. have a 4 bbl carb??? i to recently purchase a 66 326 but have not check #'s yet.
HELLO, AN HO MOTOR WOULD HAVE A FOUR BARREL ON IT. IF YOU ARE LUCKY ENOUGH TO HAVE A CARB TAG REMAINING, LOOK FOR THE FOLLOWING: 4035 S, AUTOMATIC TRANS WITH OUT A.I.R SYSTEM, 4036S, THE 326 HO WITH MANUAL TRANS, WITHOUT A.I.R SYSTEM. AND 4031 S, AUTOMATIC WITH A.I.R SYSTEM. A.I. R( AIR INJECTION REACTOR SYSTEM) MOST LIKELY THE DEMOCRATIC PARTYS ANSWER TO GLOBAL WARMING IN 1966.HA, HA.!!( i. e. smog control).
BRIAN
