Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 07-26-2007, 06:19 PM
schlitzman's Avatar
schlitzman schlitzman is offline
Default Delighted with Tripower Restoration
I just had my tripower system completely restored by Mike Wasson (www.pontiactripower.com). I am absolutely thrilled with the results. I bought a "restored" original system last year for my '66 GTO. I paid TOP dollar for it. It looked great, but it never performed well. In looking for solutions and help, I was directed to Mike. He was extremely knowledgable, and helpful. He guided me through many telephone diagnoses to help locate and correct the problems I was having, mostly with poor idling and vacuum leaks. After many attempts to solve the problems myself, I finally asked Mike to rebuild/restore the complete tripower unit. I sent him all three carbs, and got them back in much quicker than expected. They were gorgeous. Appearance was outstanding, and all faulty components were replaced. Mike sealed the throttle blades on both end carbs so they operated correctly and sealed completely. Operation of the center carb is now now smooth and exact. The first time I fired up the new system, all functions worked normally and predicatble. This was the first time I could even get the engine to properly idle. Manifold vacuum was 17" Hg, and steady as a rock! I took the car out last night on the road for the first time, and was delighted again. The engine ran smooth and performed well in all gears. Cruising was a dream, especially on side streets in third. I haven't really gotten into it, but it raps up real fast to 4500 rpm like it wants to keep on going! Maybe this weekend I'll open it up.
So lessons learned, or things I'd do different--- If you're a first time tripower person, read and explore before you buy. I'd definately go to Mike's web site, and get his CD on tripowers. If I had done this first, I'd not only be better informed, I'd be a better customer knowing what to ask and what I was getting. If you have troubles, contact Mike early. He can provide advice, parts and if needed, restoration. Mike is a craftsman and a true gentleman. I highly recommend him and his services.
Schlitzman
Old 07-26-2007, 09:08 PM
mwritter's Avatar
mwritter mwritter is offline
Great write up - Mike is the best.
Matt
1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor
1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD
1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring|
1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners
2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD
2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles
Old 07-26-2007, 09:49 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Mike worked wonders on my tripower also, I highly recommend him. -Jim
Old 08-02-2007, 11:50 AM
TxGoat TxGoat is offline
I've exchanged some emails with Mike Wasson, sounds helpful and knowlegable. I just bought a tripower to rebuild - original carbs, mising a few linkage parts, chokes, pulloffs, but carbs are corect and in very salvageable shape - it went through a wee bit of an engine fire. If you don't mind me being rude, I am curious what he charged you to do it. I want to do it, but if I run into problems, I need to know what my $$ cost will be to get it done right. If you don't want to post it publicly, you can PM me or send it to my email ([email protected]). Appreciate the help.
Thanks!
Old 02-09-2008, 10:05 PM
Jameaux Jameaux is offline
I have done business with Mike on several occasions and I think he top shelf. I have bought parts from him and one completely restored '66 tripower. Most recently I ask him to do some work on a carburetor base and I was amazed how quickly the part was back to me -- he turned it around in a day and shipped it back priority. Mike is detail oriented and is a craftsman; I recommend him.
Old 02-10-2008, 04:56 AM
DAN DAN is offline
Web page for Mike Wasson comes up as error.
DAN
1965 GTO TRI-POWER
1970 Z28/RS M-22
1954 Corvette
Old 02-10-2008, 02:16 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
http://www.pontiactripower.com/
It's because the ). is being added in the link from above. The one I posted should be good.
Old 02-10-2008, 04:33 PM
DAN DAN is offline
Thanks........
DAN
1965 GTO TRI-POWER
1970 Z28/RS M-22
1954 Corvette
Old 02-10-2008, 08:51 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Mike is friend of mine and he's just as nice in person as he is on the phone. Truely a great guy and an asset to the pontiac fraternity. He takes great pride in his work, values his customers, always tries to exceed your expectations, and just flat out does a great job.
The restoration price is directly related to the condition of your existing tripower and what you plan on doing with it.
TxGoat- I you want your unit to lok and run as good as it did from GM then take you time, follow the advise of the folks on this board, and restore it yourself. I do suggest buying the carb kits, linkage, and fuel lines from Mike. He's very picky about the parts he uses so that's the guy to buy them from. If you run in to trouble, he'll be there for a little while longer.
However, if you want your unit to run better than it did from GM, then send it to Mike. He'll go over it with a fine tooth comb and replace/repair worn shafts (if needed), seal gaps between the throttle blades and the venturii on the front and rear carbs (The special sealent used for this is hard to get and goes bad fast), he can enlarge and radius the venturii's for better air flow, re-jet the carbs to match your engine, altitude, and fuel type and on and on.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 02-16-2008, 06:39 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
I've known Mike for probably 20 years or so, he's a great friend and very fair and nice to his customers.
He recently put together a killer '66 tripower for my 455. The end carbs have had the center sections opened up, he made me up some special fuel lines and fuel log, and even converted the center carb to an electric choke for me. All this on top of a lightweight aluminum 66 repop intake.
It looks fairly stock, but it's far from it......can't wait to try it out.
Thanks, Mike!!
"XE cam basher"
Old 04-06-2008, 12:53 AM
GTOJOE228's Avatar
GTOJOE228 GTOJOE228 is offline
Default Mike Wasson.....Awesome guy...
I had a friend who needed his Tri-Power restored. Read a lot about Mike and am happy to say that upon my advice my friends results were first rate. From the quick service to the many detailed questions my friend had, Mike was available and was also a gentleman to deal with. Tri-Power looks so perfect.....Thanks Mike for a job well done. I will continue to recommend you and your services.
GTO JOE
1966 GTO Conv't, 4-speed, Tri-Power(sold)
1967 GTO Ram Air, PHS Doc. 4sp, #'s match, 15+ options 1 of 751
(Featured on Cover plus 6 page spread in May 2006 HPP)
1970 GTO Judge, PHS Doc. 4sp, #'s match, Ram Air III
2006 GTO Spice Red. M6,18" wheels, 400 HP LS2
richmondcountypontiac.com
Need High Quality Printing fast and reasonable?
www.farbetterprinting.com
Since 1974
Quotes at: [email protected]
Old 04-06-2008, 09:39 PM
tripwr1964's Avatar
tripwr1964 tripwr1964 is offline
I agree with all above. Mike is a great guy to know and do business with. I am fortunate to live close, so I can visit his shop and talk pontiacs with him on occasion!
Smilies are Off
