Old 04-18-2008, 06:24 PM
David Jones's Avatar
Default Electric Fuel Pump Install Pic's.......
Those of you that frequent these pages might know that I've been having issues getting enough fuel to the carb during my infrequent trips to the drag strip. Maybe you didn't know that. Now you do. Anyway.....
After some soul searching and after having an actual idea, I decided I would install an electric fuel pump and a better filter. I decided on a Carter P4070 for the pump because it seemed like to me that 72gph would be more than enough and I went with the Fram HPG-1 because it was capable of filtering more fuel than my engine could use and waaaaay more than the inline canister filter I was using.
My idea was on how to mount everything. I didn't really want to drill any holes in the car to make this work. While rolled up under the car one evening it came to me. Mount a piece of angle (aluminum) from tank strap bolt to tank strap bolt and put everything on that. If it will fit. I turned to Google and after a little searching came back with the exact measurements of both the Carter and the Fram filter. Mocking up a piece of angle and doing a little further measuring confirmed that both pieces would fit. I used a piece of 1" X 1" aluminum angle, .125" thick. I settled on 22" long. I put the Carter on the passenger side and the Fram on the driver. Fuel comes out of the tank pickup line, turns and goes under the Fram, straight through it and straight to the Carter, out of the Carter and under it and straight up the original fuel line. Maybe 3 to 3.5 feet of additional fuel line were added? The differential slides neatly up in between the fuel system parts with room to spare.
And you can't see any of it unless you are laying on the ground.
Name:	fuel2 (Medium).jpg
ID:	129655   Click image for larger version
Name:	fuel1 (Medium).jpg
Old 04-18-2008, 07:49 PM
grandville455's Avatar
Thumbs up
David !! That looks AWESOME!!!! NICE JOB!!
Darby
M/T 275/60 ET SS Drag Radial
Old 04-19-2008, 08:06 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
David,
Looks Awesome!!
How much did it cost for the set up? Did you wire up direct with the key? Can you hear it inside the car??
Sorry for all of the questions.. I'm planning on adding an electric pump to my 71 and I'll be using your install as a reference...
Can't wait to see how your car does at the track!!
Old 04-19-2008, 01:38 PM
KS circutguy's Avatar
David get a different filter, that is one of the least flowing units around.
Otherwise nice job.
Old 04-19-2008, 01:58 PM
Rugratman's Avatar
Rugratman Rugratman is offline
sound?
........I'm just learning as I go.......
Old 04-19-2008, 02:54 PM
66bonne's Avatar
66bonne 66bonne is offline
Very clever. Necessity is indeed the mother of invention.
Jim
Old 04-19-2008, 07:14 PM
Fram HPG-1 supposedly is supposedly capable of flowing 90gph. Assuming it does half that it will still flow more than my engine can use at WOT.
How much do I need?
I can hear the electric pump as the car is cranking and then it goes away. Not because the engine is loud, more like you took the load off. I really haven't had much time to evaluate the whole deal though. I ordered the 1st mechanical pump and it turned out to be bad. So I put my stock mechanical pump on and ran the car once with it and the electric pump. Then the replacement M6122 mechanical pump came in and I just put it on. It's bad also!!!!! This one leaks like a sieve at the joint. Cascades of gas out the side. So I ordered another brand (Bosch) and won't get it until Tuesday. It doesn't seem to loud, but I want to have time to see what it does with the latest mechanical pump and its return etc. I like to lay under the car and see what, if anything might be vibrating, what I could rubber mount.
Holeshot, the electric pump was $71 and the filter was $34, the aluminum angle was $6 the relay was $20 and I needed a little extra wire for a few dollars. A couple of fittings for $6. Some wire ties. I'm sure any pump or filter would work with some slight changes.
Old 04-19-2008, 08:45 PM
Default 86 the mechnical pump.
These suckers are killer and last.
I will take some pics. of my home made isolator setup Sunday and post late afternoon, it works great .
http://www.jegs.com/p/Edelbrock/752943/10002/-1/10307
Old 04-19-2008, 08:54 PM
Overkillphil's Avatar
Overkillphil Overkillphil is offline
We used to mount them like that on the Firebirds but instead of the tank straps we used the mounting points for the old crossflow mufflers.
It is a nice neat installation the way you have it rather than others I see hanging down behind the rear bumper begging for something to hit it!
___________________________________
"Objects in mirror are closer than they appear"
Old 04-19-2008, 10:02 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
How much do I need?
Those Fram canister style filters are restrictive. I question the validity the Frams flow 90 gph, here's what I found. My car was having a lean popping out the exhaust in 3rd gear at the track. I tried many different suggestions to track down the cause. As a last ditch effort to find the problem, I removed the filter element from the Canister and ran it without a pre-filter to see what happened. Holy moly, it dropped .10 and picked up 2.51 MPH on the first run! Did I mention all signs of the lean popping was gone?
Yes, your engine will need more than 45 gph capacity to operate effectively. It's easily researched, do a search and read the many many posts/threads discussing the required pump/line capacities required for performance. The 72 gph you posted will be marginal fighting against g-forces during a timed acceleration test, if the filter doesn't hurt the situation. I was running a Mallory Comp 110 which yields 90 gph @ 7.0 psi and the Fram was a restriction of the suction side of the fuel system.
The installation looks good but I'm concerned you haven't corrected your fuel delivery issue. IMHO JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 04-19-2008, 10:42 PM
Brandi Kay's Avatar
Brandi Kay Brandi Kay is offline
show off
Keepin it real in 2025.
'just another time traveler...
:range r:
Old 04-20-2008, 07:39 AM
Guys, I appreciate your opinions and judging by your cars you have way more experience with drag racing than I do. But I don't think you're comparing apples to apples here.
The calculations I went by (for a 400 hp engine) put the fuel requirements at just less than 30gph @ WOT. Factor in acceleration forces generated by my engine in concert with my 255/60-15 Radial T/A's and 3.55 gears and I think my 72gph pump and 90gph filter will be more than enough unless I have a restriction somewhere in my stock fuel line.
I'll know for sure in a few weeks.
KS Circuitguy, I'd love to see pictures of your setup.
Old 04-20-2008, 08:11 AM
Geoff Geoff is offline
Carter elec pumps, best there are. Quiet, run forever. I'd like a dollar for every car running some exotic, billet, mega$ alum 250GPH elec pump, when a 72 or 100 gph Carter would do the job.
Old 04-20-2008, 09:45 AM
gto1967's Avatar
gto1967 gto1967 is offline
Talking
Border line genious! I love it!!!
"An over torqued bolt is already half broken"
Old 04-20-2008, 01:32 PM
mchell's Avatar
mchell mchell is offline
I never run a filter on the suction side.....any increase in suction head will DECREASE flow dramatically.....In my mind the suction side is the most critical part of a fuel system....I only use filters on the discharge side.......the maunufacturer will tell you to run a pre-filter to protect his warranty....in a perfect world you could....but
..most of us are also mounting the pump above or midline to the tank when they should be mounted BELOW the tank to minimize suction head loss......so right out of the box we are decreasing flow by increasing suction head...no easy way
I am close to sumping my tank and adding one of those ROBMC 1/2 pickups.....this should minimize suction head loss and hopefully keep the fuel flowing!!!
good luck...post the results!
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Default here are a couple David
Rubber mount the pump bracket with strips like this.
Old 04-20-2008, 01:50 PM
Default More Pics.
The pump now mounts inside the bumper with 2 threw bolts.
Like this;
No where near as noisy as a solid mounted pump.
BTW; The Edelbrock pump is the next one I will buy.
My Aeromotive has lasted 5yrs. of street - strip duty and a nice product with great service-support.
I have to send mine in for them to OH it cause the shaft seal is dripping, $80.00 for them to do it is fine by me.
Old 04-20-2008, 03:28 PM
67cruiser 67cruiser is offline
David, just my thoughts, i still fill you are still going to have problems until you sump that tank and move everything right behind the bumper, Cliff Ruggles gave me some idea,s about sumping the tank, works absolutely perfect, remember when the car takes off ,all the fuel heads towards the back of the car so sumping the tank with 2 outlets really gets the fuel to the carb. bare none!!
Old 04-20-2008, 03:39 PM
That he said!
Old 04-20-2008, 04:28 PM
briann briann is offline
This was the easiest placer to mount mine that was below and near the tank. Yea its gets dirty but I don't care cause dirt doesn't affect performance of it. I'm putting a different pump in same place but forming a alum plate around it to keep muffler heat off it and to channel cooler air to it from the front along the frame rail.
I might look under there when replacing it and see if I can drop a bracket way down in front of the tank so the pump is at bottom of tank level but closer but for 25 years I never had any fuel pressure problems mounted where it is now.
