What headers for a 67 Lemans with Edelbrocks??
What headers will fit a 67 Lemans convertible with a 4 speed and Edelbrock heads?
Both Hedman and Doug Thorley said they don't have anything. |
I have Doug's headers on mine....NOT Doug Thorley....Doug's .. Same guy, different company...(I believe a court decision allowed this to happen) Most headers you find for Pontiacs will need some sort of tweaking to get them to fit perfectly, especially if you're using E-Heads like you and I. The only issues I had were the rag joint bolt was hitting the #1 cylinder tube. I believe I had a replacement rag joint in there which was replaced with the one with long bolts. Cutting those bolts down a bit cured the problem.. Also, I don't know if you have a 4 speed or not but the installation guide says the 1965 Z-bar MUST be used in place of the 67' due to the grease fitting location. I used my own Z-bar and relocated the grease fitting. I also had to move the Zbar up a little bit in its mount for clearance... Here's some pics of the issues before I cured them..
Jeff Last edited by jeffhhs76; 04-26-2008 at 05:35 PM. |
Thanks for the pics and info. I do have a 4 speed. I am using a super t-10 out of a later TA. Would you happen to have the part number for the Doug's headers?
Thanks for all the help Jason |
Jegs part number for these headers is 776-D567 see this link below: http://www.jegs.com/i/Doug's%20Headers/776/D567/10002/-1
Jeff |
i have hedmann husler on my 66 there 2inch tubes and i also have super t 10 from a ta. and edelbrock heads and they are the best fitting headers ive had only thing is you do have to make a hole in the fenderwell for the rear pipes to go over and under the frame
http://performerrpm.myphotoalbum.com/view_album.php? |
