Old 05-22-2008, 06:13 AM
shoeman68 shoeman68 is offline
Default Exhaust manifold gaskets?
Any advise when replacing exhaust manifold gaskets on a 1968 400 non-R/A non-H/O?
It seems there are only 4 bolts holding on the manifold. Do four bolts create enough of a seal?
Are paper/cork gaskets better than metal?
Thanks for any input
Old 05-22-2008, 07:02 AM
goatless's Avatar
goatless goatless is offline
My advice- Don't use the steel or the paper. Get a set of the good composite gaskets from Fel-Pro or Mr. Gasket. I've never had any leaks using them. They have a steel core and a material on both sides that compress' to seal up minor imperfctions.
Last time a did a set of exhaust gaskets I used the original style steel gaskets based on someone's advice and they leaked right from the get-go.
1966 GTO
Old 05-22-2008, 09:27 AM
Mr. P-Body Mr. P-Body is offline
If the manifold surfaces are "flat", the shims are the way to go. Have the manifolds resurfaced if they're not flat (within .003"). The 4-bolt retention seemed to work well in stock engines. The factory used NO gaskets.
Jim
Old 05-22-2008, 12:03 PM
Steveski Steveski is offline
Agree that the manifold surfaces must be absolutely flat and level or resurfaced to achieve same. Over time the center cylinder manifold tubes warp outward from the heat. I used a set of thin steel gaskets as (I was told) they would dissipate heat.
Old 05-22-2008, 03:11 PM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
resurface to make sure you are not warped this is common
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored)
1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505
1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS
AC Cobra Kit Car 521 670 HP/715 Trq
LOOKING FOR V PARTS !!!!!!!!!!!!
Old 05-22-2008, 07:24 PM
Default Gasket Reply
Thanks for answers. I'm not going to resurface, I think I'll go with the Mr. Gasket type as suggested. I have 108,000 original miles.
Does anyone think the bolts will snap based on experience. I did the right side and the bolts came out fine.
Old 05-28-2008, 03:42 PM
68pl's Avatar
68pl 68pl is offline
Default Gasket mat'l.
On my 68 Lemans I have 6 bolts per side.
Old 05-28-2008, 10:06 PM
motorcitymusclecar motorcitymusclecar is offline
The original cars had the metal gaskets - and they have a crush ring to seal good - i would think that anything that was not metal would burn up pretty fast since they get so hot. All the gaskets are available at the local autoparts store - may have to wait for a day for them to come in.
Old 05-28-2008, 10:10 PM
if you are going to replace the bolts make sure they are grade 8 because after they heat cycle a bunch of times and rust over the years you will still be able to get them out - the cheap grade 5 or three can rust over time and when you go to take them out break off then the fun begins.
Old 05-29-2008, 02:41 AM
engineer engineer is offline
anti seize on new bolts and proper torque.
