Old 06-21-2008, 03:48 PM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
Default Which Roller Rockers?
Hi Guys:
I going with roller rockers when I do the roller cam. I had considered stainless Crowers because I'll be using Crower springs and lifters. But they are very pricey. Scorpions have been recommended and I may go that way. (I've got GM (Crane) aluminum roller rockers on my LT1 SS Impala and they work well.) I see that KRE has PRW stainless roller rockers that look a lot like the Crowers and they are only $5 more than the Scorpion aluminum rockers. I don't know this brand. Anyone used them or have any feedback on them?
Thanx, Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 06-21-2008, 04:44 PM
TransAm525 TransAm525 is offline
I have the Scorpions on my 78 Trans Am and am very happy with them. They are very high quality and the price is perfect. So far they have over a year of daily driving use on them with no problems. A lot of people also like the Harland Sharps, but they don't have a lot of material on the top, which to me is just asking for a failure at some point, but to each his own. Unless you're going to run very high spring pressures, any cast aluminum roller rocker will work. The only difference between the Crane and Scorpion rockers is the Cranes are forged aluminum (and overpriced) and the Scorpions are cast aluminum. Whatever you do, don't purchase the Comp Cams roller tip rockers. They are junk and most of the friction is at the fulcrum point, not the tip, so they will give you virtually no gain.
Old 06-21-2008, 04:52 PM
Murf'sDad's Avatar
I'll be running about 450# - 500# OTN pressure. That is why I was looking at the stainless rockers rather than the aluminum ones.
Any one used the PRW stainless rockers?
Stewart
Old 06-21-2008, 05:21 PM
GTOLou GTOLou is offline
Anyone used these?:
http://store.summitracing.com/partde...6&autoview=sku
I've used Scorpions - happy with those.
Actually I have a set of the 1.6 ratio rockers from butler in use for about 1 1/2 to 2 years. Working fine - they are at the bottom of the page. Very cheap.
http://www.jbp-pontiac.com/products/...rms&Comp..html
I've used both with HR cams - no SRoller use...
Old 06-21-2008, 09:02 PM
440GP69's Avatar
440GP69 440GP69 is offline
The PRW are good, my favorite all time chromoly rocker is Crower stainless steel enduro rockers 1.65 ratio, get them from ACE at PPR
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 06-21-2008, 09:35 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I would definately stick with the stainless steel rockers. I have seen aluminum rockers break at those spring pressures. Also, most SS rockers are lighter on the valve end than aluminum rockers so there is a weight savings also on the valve end of the program.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 06-21-2008, 10:52 PM
440GP69's Avatar
SS also is more ridged, is rebuildable and the crowers on my paps 1600hp blown alchohol engine have been going for 6 seasons with 300lbs seat pressure and 1,050lbs open pressure! pretty much will last forever on a street engine IMO
Old 06-21-2008, 11:28 PM
Bite the bullet and buy the Crower stainless rockers.
I feel that it's always better to buy the best and never have to worry.
Got mine from Ace at PPR, he was even kind enough to swap a set of 1.5s for some 1.65s a couple years later after I changed my mind (still new in the box).
Many years before that I bought a set of Norris stainless 1.65s from Ken Crocie (H-O Racing), they're still going strong on my street 455 after a decade of bracket racing.
Old 06-22-2008, 12:45 AM
Old Man Taylor's Avatar
I run the Crower Stainless roller rockers on my streetcar.
Old 06-22-2008, 07:37 AM
Geoff Geoff is offline
Two things you can be sure of:
[1] Steel or s/steel rockers will NOT fail unless stressed beyond their safe working load.
[2] Alum rockers WILL fail from constant flexing, but it is impossible to predict when or how long it will take.
Old 06-22-2008, 11:46 AM
There are differances in types of aluminium and construction methods. This from Crane Cams....
For many years, it was thought that aluminum roller rocker arms could not be used on a daily driven street car. The major reasons were that the aluminum would eventually become brittle and break and that a roller tip would not allow the valve(s) to rotate, causing excessive/premature wear of said valve. While these may have been legitimate concerns at the time, both have since been disproven. Contemporary aluminum roller rocker arms are made from various alloys, which have dramatically improved their strength and longevity, making them more than adequate for continuous use.
( You will find a similar message from all the major rocker arm manufactures )
Old 06-22-2008, 01:13 PM
gtofreek's Avatar
I've seen aluminum rockers break more than once with only 350 lbs. open pressure. And with very few miles to boot. T&D's and Jesel's are good for high spring pressures, but most stud mount aluminum rockers are iffy when using spring pressures over 350 lbs. Especially cast aluminum rockers. They are only good for bone stock applications as far as I'm concerned.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 06-22-2008, 03:52 PM
1971GTO's Avatar
1971GTO 1971GTO is offline
On this subject, I want to put 1.6 roller Scorpions on my stock 455HO. Will they go under stock valve covers?
1971 GTO: Quezal Gold, non-R/A 455HO, TH400, 3.55 Safe-T-Track, 1 of 412.
turns in 13.4@101 miles per, "Hey these 'ol GTO's haul ass"!
Old 06-22-2008, 04:18 PM
With some thicker valve cover gaskets they'll fit.
Butler performance sells a gasket that is 5/16" thick. You'll need some longer bolts to hold the cover down with the thicker gaskets.
Old 06-22-2008, 05:28 PM
Murf'sDad's Avatar
Would it be a safe assumption that PRW's are made "off-shore". I found their website and they don't mention specifically where their products are made.
I did notice that the PRW rockers are made of 15-5 stainless and the Crower rockers are made of 17-4. That would would make the Crowers better because of the slightly higher yield strength and slightly less elongation %.
Notwithstanding all of the suggestions and comments about going with Crower (my first choice), are the PRW's inherently inferior? After all there is a $200 difference in price.
Stewart
Old 06-22-2008, 06:37 PM
jusjay's Avatar
jusjay jusjay is offline
PRW have had quality issues in the past. Soft rollers, rollers position too high allowing the rocker to ride on the spring caps, weak fulcrum and the supplied polylocks are prone to back out or just break. They are "off shore". The company has had to sent back or get credit for 100's of sets.
Old 06-22-2008, 07:40 PM
Murf'sDad's Avatar
OK, this is relevant info. I hadn't heard of problems because I wasn't familiar with PRW products. Have these problems been corrected or are PRW SS rockers still having QC problems?
Thanx jusjay.
Stewart
Old 06-22-2008, 08:15 PM
71firebird400's Avatar
71firebird400 71firebird400 is offline
If Dave B is selling them I'd personally have no problem using them. Like you, I have yet to see any real feedback on those rockers.
Mark
Old 06-22-2008, 08:29 PM
jusjay's Avatar
They have had a year or so to correct their problems, some have been corrected, some haven't. The main problem with these imports (PRW,CAT ect) is problems will go away for a shippment or two then return on the next. For my money if I was building a motor and putting 7 to 10 k in it and was going to run it hard. I would stick with the name brands. A daily driver with a stock rebuild, maybe.
Old 06-22-2008, 11:46 PM
440GP69's Avatar
ive talked in length with SD Perf and they really like the PRW but when you want piece of mind that you have the strongest and best only crower ss will do for stud mount IMHO
