73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 07-09-2008, 04:25 PM
ehurter's Avatar
ehurter ehurter is offline
Default Interior Paint
Anyone have a recommendation for Firethorn paint for my Can Am? Looking to replace some dash / door parts and will need to paint them. Could use the Firethorn and white paint. Any suggestions would be welcome. Thanks!
Old 07-09-2008, 04:31 PM
Kbars CanAm Kbars CanAm is offline
Get SEM's brand firethorn red it comes in a spray can. It is the best match you will find. I don't know about the white. You can google SEM's and find out the part number. If I go to the where I keep my Can Am stored I will look up the number on the can I used. Maybe someone else on here has it. I had the local O'reilly's order it for me. Kbars
Old 07-10-2008, 10:10 AM
TA-71 TA-71 is offline
I am not sure of the actual brand, but The Eastwood Company carries a whole line of interior paints, including firethorn red.
1971 Trans Am - Sold
1977 Can Am - Sold
2002 Trans Am Firehawk - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
1972 Trans Am - Sold
1970 Trans Am - Current Project
Old 07-10-2008, 02:33 PM
77 Canamman's Avatar
Lightbulb
I recommend SEM interior dye, but not their aerosol dye. Have your local auto paint supplier mix up the correct color, and apply it with a spray gun. The end result is far better.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 07-10-2008, 03:31 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
While I also agree a gun is always best for getting an even match with paint, I have used the SEM aerosol cans for my interior with great success. No color match problems at all. You cant skimp though...you have to get the vinyl and plastic prep along with the paint and use them all appropriately according to their labels.
The key though is painting when there is little/no humidity. The label calls this out, but adhere to it! If its too humid youll get a lot of spots that will dull when they dry. I figured I was doing something wrong on the prep side, so I redid the pieces several times, but the same result always occurred. It wasnt until i called SEM tech support that I was set straight. Waited for the air to dry out, painted them up, and its been great for 5+ years now.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
