Old 08-15-2008, 03:16 PM
peppergreen's Avatar
peppergreen peppergreen is offline
My 70 Judge has "TAC" scribbled across the sheet as well.
Would like to know more about the laquer thinner restoration......soak it for an hour or so? Hate to destroy the thing.
"Drive a GTO".......Iggy Pop-Lust for Life
Old 08-15-2008, 03:21 PM
UPC-WU2's Avatar
UPC-WU2 UPC-WU2 is offline
I got a glass cake pan and put about an inch of lacquer thinner in it and gently put my build sheet in there for a soak. It was completely black and saturated with sound deadener. I kept agitating the pan and swishing the thinner around gently. Eventually the build sheet came to life, like a Polaroid. Then I pulled it out gently and let it air dry. The photo earlier in this thread shows what's left. It got fairly mangled trying to get it free from the tar sound deadener. I wish it was all there, but it's better than nothing. I never found one in my Arlington-built Judge.
1971 GT-37 - 350/M38, Rosewood Metallic/Black
www.GT-37.org
Old 08-18-2008, 08:59 PM
Leonard Welch's Avatar
Leonard Welch Leonard Welch is offline
Interesting - here's mine from a 71 convert...gotta be the same person as pictured in PonchV8's post...same distinctive 'A'...
Old 08-19-2008, 08:12 PM
How about it being T A Z ?
Old 08-21-2008, 02:37 PM
Keith Seymore's Avatar
Keith Seymore Keith Seymore is online now
Very cool, HFR. Between the vintage photo and the build sheet - I'm convinced.
By the way, I am asking around here at work about the "+AC" or "TAC" or "TAG" notation. There are a couple guys here that worked at Pontiac back then that might know.
I'll let you all know if I come up with anything.
K
'63 LeMans Convertible
'63 Grand Prix
Old 08-21-2008, 02:48 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
K
It will be VERY interesting to hear what you discover, Keith.
Back "in the day", would there have been anyone on the assy line who had the responsibility of checking to see if a car was being built as ordered?
Just a thought . . .
Regards,
"455HO" Lloyd
Old 08-21-2008, 03:33 PM
tripower's Avatar
tripower tripower is offline
K
It has to be "TAC" correct? The "T" seems distintive. It almost looks like the "T" is seperate from "AC". But could just be the handwritting style.
Here are three more Pontiac, MI build sheets with the "TAC".
The first one is a 71 convert I used to own.
ID:	140544   Click image for larger version
ID:	140545   Click image for larger version
Name:	71 GTO BS A.jpg
Norm J
Old 08-25-2008, 12:45 AM
68pongto's Avatar
68pongto 68pongto is offline
I have a few build sheets from 68 Pontiac built cars and they have the "TAC" written on them. Deffinately a TAC, who knows what it means though? Scott
ID:	140971Click image for larger version
ID:	140972Click image for larger version
Name:	build sheet.JPG
Old 08-25-2008, 12:15 PM
A couple clarifying questions, guys:
a) Do all the cars that say "TAC" have air conditioning on them?
b) Does anyone have a Pontiac build sheet (during this same timeframe) that does not have "TAC" written on it?
Thanks -
K
'63 Grand Prix
Old 08-25-2008, 03:52 PM
Thanks -
K
I believe I answered my own question:
I see the "Less Stripes" car says "TAC" but is apparently less A/C.
Still interested in a Pontiac build sheet that doesn't say "TAC", if anyone has one.
K
'63 Grand Prix
Old 08-25-2008, 04:35 PM
Lloyd-TX's Avatar
Here are a couple Keith . . .
First one is a RA IV GTO with quite a few handwritten comments. Has a typed "TAG", but no handwritten "TAC".
Second is from my '72 GTO, 455HO M22 w/ A/C. No "TAC", but has a handwritten "MA" near the bottom. Sorry for the blurry scan.
Name:	70 GTO RA IV build sheet.jpg
ID:	141022   Click image for larger version
Name:	72 HO GTO Sundance manifest LG.jpg
Regards,
"455HO" Lloyd
Old 08-25-2008, 06:40 PM
Lloyd-TX's Avatar
Found another Pontiac Plant build sheet w/o the "TAC" notation.
Black '71 M40 Judge w/ the G60 tire option. Just what appears to be a check mark on this one.
Name:	71 Black Judge w-G60x15 tires build sheet.JPG
Regards,
"455HO" Lloyd
Old 05-04-2009, 07:54 AM
Bringing this back to the top -
Our local bookstore/collectibles shop has a cruise every Saturday morning.
I stopped by this week and noticed they had this nice 71 GTO model for sale:
On the box, prominently displayed, is this build sheet:
I had to laugh when I saw that big "TAC" on there!
K
'63 Grand Prix
Old 09-07-2011, 10:49 AM
Back to the top!
Have some interesting buildsheets I've found on the net.
One has what appears is just the T A and no C.
One looks like it has a 'check' or a partial V
One of the T A has a printed TAG at the bottom
And a blank 1970 sheet
ID:	255865   Click image for larger version
ID:	255866   Click image for larger version
ID:	255867   Click image for larger version
ID:	255869   Click image for larger version
Old 09-09-2011, 07:11 AM
Jason67's Avatar
Jason67 Jason67 is offline
My 70 Judge I'm in the process of restoring had 2 build sheets. I found one under the passenger side carpet, it is in beautiful shape other than stained brown. It has no TAC on it. The second sheet was on the drivers side top of the gas tank, and it has TAC on it. It also has another cars partial build sheet attached to the bottom of it. So, one had TAC, one didn't.
Jason
Old 09-09-2011, 07:34 AM
Makes sense, as the two sheets originated from separate areas of the plant: the one in the seat from the "cushion room", usually in some remote corner of the plant; the one on top of the gas tank from the main assembly line.
Good input; thanks for posting that!
K
'63 Grand Prix
Old 09-09-2011, 08:03 AM
Jason67's Avatar
Hi Keith, just to clarify, one was under the carpet sound deadener, not in the the seat. Carpet would be installed on the main assembly line, correct?
Jason
  #38
Old 09-09-2011, 08:07 AM
Ah - yes. That is correct; carpet would be installed on the main line, in the Trim area.
My point is still valid, though (build sheets originated from different areas, hence a different operator handling them).
K
'63 Grand Prix
  #39
Old 09-09-2011, 09:26 AM
Jason67's Avatar
It would be interesting if others knew where their sheets were located on the car with TAC on them. Most of those posted look like they were in the interior, where mine was on the gas tank (early 70 build Judge).
Jason
  #40
Old 09-09-2011, 09:36 AM
Jason67's Avatar
After looking at the sheets posted again, looks like most of the ones with TAC have the gas tank straps imprinted in them.
Jason
