Old 09-01-2008, 08:22 PM
78savette's Avatar
78savette 78savette is offline
Default Cleaning oil off headers.
My TA has had a leaking rear oil pan gasket and as it got worse, the oil got sprayed all over my headers (Doug's) and exhaust (Rare's), I removed the oil pan this weekend, and after spraying brake cleaner on everything, thus removing alot of the paint on the undercarriage, I painted everything and removed the oil, except from the headers/exhaust.
I read the many have used Nevrdull, but that just seems like a polisher, anybody have any luck removing burnt oil stains off coated headers, if so, what works. It just seams to me that a product that may be strong enough to remove the stains may not be good for the coating, or am I just stuck with the stains.
Old 09-01-2008, 10:46 PM
paint guy paint guy is offline
I would be inclined to try lacquer thinner(make sure everything is cool)with a terry cloth rag and lots of elbow grease.Just did that today to get oil off my pipes on my bike.They are chrome,so we're comparing apples to oranges,but it's worth a shot.Definitely won't hurt the pipes,but could soften the paint on the headers,try in an indiscriminate spot first.
Old 09-01-2008, 11:11 PM
Using an aluminum polish on aluminum/ceramic coated headers is the accepted cleaning method for removing burnt-on oil stains. Nothing else is really going to do a good cleaning.
Old 09-02-2008, 12:42 AM
AGTO8U's Avatar
AGTO8U AGTO8U is offline
I use Brasso metal polish which seems to take it off like magic.
Old 09-02-2008, 01:32 AM
78savette's Avatar
Cool, thanks for the help, I knew there had to be something.
Old 09-02-2008, 06:45 AM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
I use LT to clean carbon off of old piston tops, if it works for that it should work for headers, IMO. -Jim
Old 09-03-2008, 12:42 AM
health services health services is offline
I use some brake clean to wash off and thin out the oil then I use a propane torch, don't get the coating too hot (don't get it red) This will burn off the oil and many times stain will will go away too. This works with aluminum coating I don't know with some of the others but the coating is suppose to take the heat anyways.
Old 09-03-2008, 08:40 AM
John Haley's Avatar
John Haley John Haley is offline
Easy-off oven cleaner or WD-40 and steel wool or scotch brite pads, both work well for me.
Old 09-03-2008, 05:04 PM
rompn63's Avatar
rompn63 rompn63 is offline
I tried Fast Orange, carb clean,brake clean, WD 40 and every other chemical I have in the shop nothing worked. The guy at the motorcycle shop said aluminum polish is the only safe way to take off burnt on oil on ceramic coated headers. Don't use anything abrasive like scotch brite. It will scratch the coating. I used a dremel tool with a felt bob and it made quick work of the oil stain removal.
Old 09-04-2008, 12:16 PM
John Haley's Avatar
Plating on headers will not be hurt from steel wool or scotch brite.
Old 09-04-2008, 09:28 PM
78savette's Avatar
Thx guys, I am glad to see yall are having some god luck getting the oil off, think I am going to do the aluminum polish first, it that doesn't do the job (I really have some bad stains on them), I'll go with some of the stronger recomendations, Thx again.
Old 09-22-2008, 06:56 PM
COMP COMP is offline
did it work ??
Old 09-28-2008, 07:46 AM
78savette's Avatar
It worked, I used neverdull last night and it did not take as much elbow grease as I was anticipating, I worked on both sides, headers and exhaust down to my mufflers, took me about 2 hours, but I need to put another coat today with some buffing and finish the exhaust, it does take the oil off with some effort.
I took a couple of before and after pics, I can not get them to load right now, but here's my photobucket link with the oily headers.
http://s118.photobucket.com/albums/o113/dacocr250/
thx for all the advice guys.
Old 10-02-2008, 11:21 PM
Colin Frolick's Avatar
Colin Frolick Colin Frolick is offline
2nd the easy-off oven cleaner.
Old 10-02-2008, 11:26 PM
the low tox (odor) work ???
Old 10-02-2008, 11:58 PM
original heavy-duty formula... the one that says "caution: contains sodium hydroxide". i used this a few years ago when a leaky remote filter oiled my headers badly, it worked pretty well, the headers were coated and i don't think it hurt them.
Old 10-03-2008, 12:22 AM
thanks
