Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 04-10-2008, 04:35 PM
TA-71 TA-71 is offline
Scott,
I will be in the market for a kit soon. Just waiting to see if I need a standard or shorter kit if the block needs alignment honing.
Chris
1971 Trans Am - Sold
1977 Can Am - Sold
2002 Trans Am Firehawk - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
1972 Trans Am - Sold
1970 Trans Am - Current Project
  #202
Old 04-11-2008, 09:09 PM
greyno3's Avatar
greyno3 greyno3 is offline
Originally Posted by TA-71
Scott,
Chris
Same here! I'll need 2.
10C 1972 Formula 461 non A/C
08B 1969 GP J/428 non A/C
  #203
Old 05-05-2008, 07:51 AM
simsb52 simsb52 is offline
I will have a standard length and a .004" length timing set ready in a few days.
I have been asked several times what I think of the bronze bushing timing sets that are on the market now. Well here is my 2cts....The bronze bushing is a great idea, but the bronze that is suppose to reduce the wear and friction is on the wrong side of the cam plate. At wide open throttle, the cam is trying to push foward under the load from the oil pump drive shaft and the distributors helical gear. Using a roller cam increases this foward motion because the cam lobe is ground parallel to the cam C/L and on center to the lifter bore for the roller lifter contact. The standard flat tappet cam has a slight offset to it to do 2 things, spin the lifter and to keep the camshaft in position. With a roller cam this is lost and the cam is able to move more freely that the flat tappet style. When we dyno tested the roller cam plate, we were shocked to see that the new cam plate had a .004" step in it after only 13 pulls. Some thing else to consider.... Have you ever put a timing light to the engine while running at 1500 rpm and noticed that the "mark" is moving around a little? That is the camshaft endplay at work. The cam is moving back and forth and changing the timing ever so slightly. With the roller cam plate installed, I set the end play at .004 to .007" to control the cam endplay. Controlling this variable is on of the reasons for the increased HP and torque on the dyno test. The timing stayed where we set it and the friction reduction from the bearings came together to make the extra grunt. The roller bearing camplate has bearings on both sides to hold the cam in place and to greatly reduce the friction.
In other words, the bronze bushing only works when you let off the throttle. The roller bearing camplate also works when you let off the throttle, but it really shines when you are at w.o.t. and that is what counts!
thanks...Scott
Scott Sims
Sims Performance Machining LLC
P.O. Box 184
Elizabethtown, Indiana
47232
phone... 812-350-8637
[email protected]
  #204
Old 05-05-2008, 08:53 PM
440GP69's Avatar
440GP69 440GP69 is offline
i will be needing one as well, as soon as i get mine align honed, Thank you Scott Sims for making a much needed product to the pontiac market!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
  #205
Old 05-20-2008, 08:21 PM
guidos's Avatar
guidos guidos is offline
Just recieved another set, excellent quality, excellent product, and Scott is great to do business with, worth every penny!!
Rich
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017!
  #206
Old 06-12-2008, 09:01 AM
I will have a .004 ready to ship next week. Thanks for all the great comments.
Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #207
Old 06-28-2008, 10:22 PM
Rusty4cyl's Avatar
Rusty4cyl Rusty4cyl is offline
Hey Scott. Your timing set is the greatest. I really like the ability to degree the cam in without offset keyway's to deal with. Your product rock's Thank's again for developing a great product for us Pontiac guy's. Thank's Rusty
  #208
Old 06-30-2008, 05:04 PM
riceslayer's Avatar
riceslayer riceslayer is offline
hear that rusty. thanks scott for the awesome product. i wonder if you could do a gear drive if i send you one. every roller cam needs one of these.
  #209
Old 07-14-2008, 08:46 AM
It can be done. A little more costly though!
I have a .004 and a .010 ready to go if anyone needs one.
Thanks...Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #210
Old 08-13-2008, 12:53 PM
I have a .010" rollmaster ready to go if anyone might need one.
Have a nice day! and thanks for the business....
Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #211
Old 08-25-2008, 07:45 AM
Smile
I have a .010 set ready to go
Thanks for the great comments.
Scott Sims
P.O. Box 184
47232
[email protected]
  #212
Old 09-16-2008, 12:36 PM
riceslayer's Avatar
hey scott, could you do a pete jackson if i send it to you?
  #213
Old 09-16-2008, 09:52 PM
440GP69's Avatar
Hi scott, I have a 535 i am building, Should i start with a standard since its a brand new IA2 or should i go .005 under, or wait and measure?
  #214
Old 09-18-2008, 12:35 PM
riceslayer's Avatar
great product, scott. you must be a busy man.
  #215
Old 09-22-2008, 07:42 AM
440gp69, I would start with a standard length. New block, It should be right on the money as far as length goes.
Riceslayer, I could/would, but I am in the busy part of the season as far as the shop goes. It would take some time and considerable money for the gear drive. Just trying to be honest about the time frame. Heck, I still owe a couple of drive shafts to one guy that has been patiently wait on me (will get to them in 2 weeks). Really!
Anybody need a .010" set? Still have one ready to go!
Thanks for all the great comments....
Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #216
Old 09-29-2008, 12:28 AM
riceslayer's Avatar
man no rush, and i have the gear drive. just curious but remember i can sell some down south for ya when you get spares. thanks scott, rs
  #217
Old 10-17-2008, 07:50 AM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
Scott:
Considering how busy you are, what the time frame for a standard length setup shipped to 04730?
Thanx, Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
  #218
Old 10-17-2008, 09:31 PM
440GP69's Avatar
And how long befor a Standard 9-key Billit RollMaster set could be made for me? Thanks
  #219
Old 10-23-2008, 01:00 PM
Turn around time is usually around 10 days from date of payment ($265). Payment includes shipping to the lower 48.
Thanks....
Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #220
Old 10-26-2008, 03:31 AM
riceslayer's Avatar
scott
my first unit is running on a motor... no problems. easy install and great product.
i just turned a guy on to your chain named ben here on the forum, so there is a good customer for ya.
thanks man
rs
