Old 10-18-2008, 07:00 PM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
Default ATI
Originally Posted by tempest455 View Post
ATI is 3 bolt. Just get a chevy crank pulley and open the center hole to the Pontiac dimension.
x2 My ATI blancer is 10 yrs old...no trouble
Old 10-18-2008, 08:23 PM
TTS's Avatar
TTS TTS is offline
TCI Rattler and ATI. For street-ability or wide RPM ranges the Rattler is better, ATI is better for more specific RPM ranges. IMO
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson
"If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
Right and wrong doesn't need facts all the time.
-Lighthouseman ("lawyer")
Starnes Performance Automatics
www.Starnesperformance.com
Old 10-18-2008, 08:33 PM
79TA455STROKED's Avatar
79TA455STROKED 79TA455STROKED is offline
Im using a prof products.No problems so far!
Has about 40 runs on it.
9.81 at 139.89mph
3400lbs
Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS!
370cfm butler eheads
port matched victor
1095 king demon
4.30gear,th400
MICKEY THOMPSON DRAG RADIAL tire
Old 10-18-2008, 08:34 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
This isn't the first post on this forum about the issues with the professional product dampers..
Old 10-18-2008, 09:05 PM
440GP69's Avatar
440GP69 440GP69 is offline
Originally Posted by 500plus View Post
I just pulled the piece of crap off.... so far 3 of the 6 small screws are backed out and bent..fortunately the outer ring just spins freely and moved in and out about 1/4", it only scraped up my trigger wheel a little but no damage to it and it rubbed the bottom of the timing tab area on the cover. I am not going to try to remove any of the other screws to see how it is attached...held together.I thought that the 6 #12 screws just held on the red ring with their name on it. I am going to try and get this warrantied..it is only 4 months old. If they replace it, I sure won't use it on anything but a street engine. I figured it was a decent part since our pontiac vendors are selling them....NOT!!!! I will post some pics for reference in a little bit. Bill
here's a link to ATI and it shows how this piece of crap comes apart!!
http://www.atiperformanceproducts.co...pers/index.htm
Junk Design IMHO, Look at it all apart, Why cheap out on a 15000$ + engine???
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 10-18-2008, 09:07 PM
BVR421's Avatar
BVR421 BVR421 is offline
PP is nice looking, too bad mine fell apart on the dyno. Replaced it with an 8 yr old BHJ, all is good.
Old 10-18-2008, 09:32 PM
wheelspin's Avatar
Thumbs up Pioneer SFI balancer...............
Pioneer SFI balancer, $150 from Summit, 4 bolt Pontiac bolt pattern, tight slip fit/ no honing necessary.
Les
Les Iden
Old 10-18-2008, 10:11 PM
grandville455's Avatar
I also run a pp and so far so good probably got over 100 passes on it this yr!.no problems. I loctited those little screws.. will check them tomorrow...
Darby
M/T 275/60 ET SS Drag Radial
Old 10-18-2008, 10:34 PM
If they warrantee it see what they say about covering damage it could have caused had it failed when you were racing. If they cant reassure you ask for $$ instead of replacement. They shouldnt fail like that especially if it comes with no maintenance instructions or need to be loctited. Raise heck for sure(be a gentleman though)! I had one on my shopping list looks like I'm going to look into the Summit or just buy a TCI now.
Old 10-18-2008, 11:22 PM
Ryche400's Avatar
Ryche400 Ryche400 is offline
Ive been using the "street" version for about a year now. Although, It rarely sees anything over 5K RPM. It looks just the like the one posted, except the red ring. It seems to be working fine, but like I said, not a race engine. I thought the SFI balancers arent supposed to have a rubber ring???
Old 10-18-2008, 11:41 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
The Summit SFI Balancer is made by Pro-Race (www.pro-race.com). I guess Summit buys them in bulk and has them laser etched w/ their logo. They sell for quite a bit more on the Pro-Race Website.
Old 10-19-2008, 12:02 AM
440GP69's Avatar
Yep and Jegs has them too, very nice for a steel damper, Overall the TCI and ATI are the best they really can't come apart But why can't they make em in 4- bolt pattern, it just seems it was an after thought and not designed from the ground up for poncho's
Old 10-19-2008, 07:28 AM
500plus's Avatar
500plus 500plus is offline
Well there is a 1 year warranty on this thing. I was told to send it back with a copy of their email for a free replacement...it will ship out Mon. If I get a replacement from them...I will just use it on a street engine that will not see 7k plus rpm or maybe sell it if someone is interested.LOL...Bill
Old 10-19-2008, 10:09 AM
wrench's Avatar
wrench wrench is offline
Just curious, did the bolts loosening cause all the failures? Are they failing in other ways as well?
Old 10-19-2008, 10:17 AM
I remember when Summit used to sell decent stuff. Times have changed. Yep, I know, the customer is always right. If he wants to cheap out and buy a lower quality part, so be it. In the old days the respected owner in the speed shop would stay "Keep your money, stay away from that crap, and when you have enough to buy a quality balancer, come see me."
Old 10-19-2008, 07:31 PM
LMSRACER's Avatar
LMSRACER LMSRACER is offline
Default Crap !!
I Agree with Tom V.
I've been Building Performance Engine for 20 Years...I've Learned to thoroughly inspect the Parts offered by the Various Manufacturers and Draw My Own Conclusions..
My First Experience with Professional Products was about 5 Years Ago..
I was Building a 302 Ford for a 66 Mustang and the Customer was Running Short on Funds..The Price was Attractive, so I Considered Using their Dual Plane Intake Manifold..
" What a Huge Piece of Crap ".. Out of the Box & Right Back in the Box..
What Did I Learn about Professional Products: Cost is the Primary Concern and Quality is Far down on the List of Priorities..
I've Inspected more of Their Products Since & Still Not Impressed..
As Far as Summit Products..Don't Buy any of Their Anodized Fittings..
The Swivel Fittings that I've Tried Leaked Immediately..
( No Wonder They Swivel So Easily.)
" Be Careful ".... Some on This Board will Sell Anything...
JMO..."Professional Opinion"
Larry Snyder..
( Certified Master Technician, Certified Master Machinist, Certified Advanced Engine Performance Specialist.)
Old 10-19-2008, 07:58 PM
Half-Inch Stud Half-Inch Stud is online now
I gots the "Made In Australia" PMD Balancer. It seems fine.
There is a recurring issue: the 4-bolt pulley gets red-rust at the 4-bolt holes because the 4-bolts seem to loosen every week. the 4-bolt pulley holes are now curved ovals. I stopped checking it 5 months ago.
Probably need to re-drill the 4-bolt Pulley, and use Clutch-fan studs. HIS
  #38
Old 10-19-2008, 09:04 PM
Jeff V Jeff V is offline
I had one come apart on me this season,luckily no damage.I now run the ATI I should have had on there from the beginning.I also know of 2 others that came apart on my friend's cars.If its a race engine get it off there before it lets you down.
Jeff Verdi
2016 Spring Fling Million Winner
2016 CARS Million Winner
  #39
Old 10-19-2008, 09:15 PM
blaktopr's Avatar
blaktopr blaktopr is offline
So I guess for the guys like myself, loctight and frequent inpections are in the future for those who have one but not yet used it or had no damage yet. That until money comes up for a better one. Lesson learned. Thanks LMS for making me worry about my fuel system. Duel inlets and outlets, filter and pumps. Well I guess I will cross my fingers when I fuel her up.
  #40
Old 10-19-2008, 09:46 PM
Formulas's Avatar
Formulas Formulas is offline
Anyone want to donate a used one to science thats not totally fubar.. I want to see how they are built and see if said screws could be upsized and up graded..??
