Old 11-09-2008, 06:31 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Default 78-87 A/G cooling
I will be using a CSR electric water pump. What are you guys running for radiators and fans/controllers? I was looking at the Modine 951 radiator? I also want to run an electric fan. Thanks -Jim
Old 11-10-2008, 09:07 AM
DiamondJim's Avatar
Anyone here using the Modine with an electric fan? Or maybe a Summit generic aluminum and electric? I was thinking of maybe using a Mark VII, that is what I have on my GTO and it is VERY powerful. -jim
Old 11-10-2008, 10:24 AM
shotgun shotgun is offline
PY Staff -Tech
I grabbed a set from GM fwd. It just about bolted up. the bottom bolt holes line right up.
It places the bottom of the fan to close to the rad, so I installed some old end link bushings I had laying around. The bushing look almost exaclty like the "factory" ones on the top.
It works great, if I hit them both, you can watch the temp guage drop.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date [email protected] mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
Old 11-10-2008, 10:41 AM
PY Staff -Tech
Old 11-10-2008, 01:09 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
The Modine 951 radiator is that the one they list for the mid80s early 90s Iroc Camaro? Mines not a Pontiac (87 Turbo Regal). I have a radiator from a 87 Iroc with the stock factory fan and a 160 thermostat, runs around 160 - 170 even in high heat and humidity.
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 11-10-2008, 02:14 PM
DiamondJim's Avatar
Yes the Z28 radiator is the one the Buick guys say to use. I am wondering what electric fan would fit it nicely? -Jim
