Just a start... lets add all the "known" differences in the 1970 cars.
01 stainless roof drip edge moldings 02 stainless door edge guards screw in type 03 Washer bottle cap 04 brackets that hold seat belts in. 05 covers for front seat bolts 06 black plastic deflectors at the base of the windshield corners 07 Alternator/power steering/air conditioning brackets 08 core support 09 evap cannister and bracket if it had EES (California car) 10 Hood hinges 11 Low back buckets with headrests 12 Quarter panel dimples (in door jamb) 13 Trunk extensions (with two drain plugs) 14 package / speaker shelf (blower defroster cutout different) 15 Exhaust extensions 16 EES system (I think every component is 70 only!) 17 12 bolt rear 18 Formula hoods don't have metal bracing on sides. 19 Formula Ram Air cleaners are one year only (Pins and dimples for holley) 20 Very early 70 cars have pot metal rear filler panels 21 Early 70 cars have 4 trunk pan drain plugs
Steve 1970 Formula 400 (YS) M40 (67-Castillian Bronze / 215-Deluxe Medium Saddle)
1970 Formula 400 (WT) M20 (67-Castillian Bronze / 213-Deluxe Dark Brown) 1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 201-Standard Medium Bright Blue) 1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 211-Deluxe Medium Bright Blue) *SOLD* |
How about thin dash gauge bezels ?
What is different on the roof drip moldings?
72 Bird |
I'm getting a bit rusty on this stuff,but as I recall,
- waterpump pulleys are specific to 70 Firebird V8 (both A/C & non) -Also power steering pump? (one year in second gen.anyways) -power brake proportioning valves,brackets,lines,etc. (one year in second gen only) |
Carpet hold down clips
Window blow out clips JW wheels Thin lip Shaker Single snorkle air breather |
great thread...........
Headlight Bezels
Front Seat Belt Retractors The thin dash bezel rings (and accomodating dash bezel) were used through '72.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
Last year for high compression
![]() Blue trunk release button ?? 70 only ?? Different Firebird fender script. Early inside A pillar moldings have that extra screw hole. Black center PMD caps. 70s are the coolest Good thread.
Stainless side window weatherstrip channel
Trunk floor different above rear axle for EES clearance. |
Substituting plastic for steel plug wire standoffs
removing the sunvisor center tabs outboard front seat belts (retractors in 70, flat in 71) eliminating the chrome engine dress for 71 |
ONLY year for code 10 Polar White (69 + 71 - 81 are code 11 Cameo White)
Angle cut on chrome exhaust tips is '70 only
Radiator support is different than '71/'72, correct? |
Don't the 71 and up cars have a seat belt light in the dash as to where the 70's do not? That might be another one but I am not near my car to look.
1970 Formula 400 4 speed 2006 Gto. Ls2/m6 1972 Gto 455ho/th400 post coupe 1973 Grand Am 400 4 speed |
Another one is the manual trans shift knobs (black ball for standard interior, red insert w/shift pattern for deluxe interior/4 spd and red insert w/arrowhead for 3 spd) big matt: I believe that started in late '72 and went into the '73 model year... |
If I new that the 70 bird was so special I woundn't have bought one! I think that photos of these parts would be benificial for all firebird owners.
Mustn't forget the early 1970 3 piece rear-view mirror that uses a round ball and two-piece screw-together arms that holds the mirror to the ball on the windshield. If that makes any sense.
I'm bummed. Checked my 70 T/A project and found the the LH hood hinge is correct, but the right hand is not, although it still is using the same small-diameter spring. One more piece to hunt down. |
Oh Jees! How could I forget!! The glove box door!! Uses 4 rivets instead of six and has a different pattern stamped in the steel.
Wow thats alot of differences, I do like the idea of taking and showing pictures of all the differences. At least after we have identified all of them, that way if someone does not understand a difference, it makes things more understandable. Great thread.....
68 Firebird Coupe 350/Auto/Air 70 RA III Formula/Auto/Air 71 T/A 455HO/Standard/Air 73 T/A 455/Auto/Air |
Some early Lucerne Blue Trans Ams came with the faded dot black border on the white stripes. Also, black center lugnuts on the Rally II's.
I just thought of one more. Some early '70 Firebirds were produced with the rare metal outside rear body panel instead of the fiberglass type that was used from '70 through '73.
