The thermostat housing used on the 1970 Firebird V-8 engines is a carryover from the previous years. From 1971 foward, a new housing was used with a different angle.
A while back somebody posted pics from "back in the day" of thier Blue 70 1/2, I have serched for them but can't seem to find them. Anybody else rememberr these pic, and maybe be able to find the thread.
Ray |
As I understand it,the red PMD's were what came on ALL 70-72 T/A's,but I'm sure that a few slipped out with the black ones.
Also,those caps are about as easy to change out as 4 speed shift knobs. In MY opinion the black PMD's look BETTER on some colors: red,brown,green,gold,etc. Haven't looked myself but is there any reference to them on the build sheet? |
mr. ray, why did you put the nose bird on? techniclly, it is incorrect.
Maybe I'm confused, but I believe the missing nose bird on my original car was supposed to be corrected by having the dealer put one on - there was a dealer bulletin regarding missing nose birds for a specific production run on the 70 TA. I've always thought all 70 TAs came with a nose bird (or at least were supposed to). Truth is I never noticed that it was missing back in 1970 - didn't come up until looking at the old picture during the 1996 restoration.
Well, This is what I got so far correct me if something is wrong.
01 stainless roof drip edge moldings 02 stainless door edge guards screw in type 03 Washer bottle cap 04 brackets that hold seat belts in. 05 covers for front seat bolts 06 black plastic deflectors at the base of the windshield corners 07 Alternator/power steering/air conditioning brackets 08 core support 09 evap cannister and bracket if it had EES (California car) 10 Hood hinges 11 Low back buckets with headrests 12 Quarter panel dimples (in door jamb) 13 Trunk extensions (with two drain plugs) 14 package / speaker shelf (blower defroster cutout different) 15 Exhaust extensions 16 EES system (I think every component is 70 only!) 17 12 bolt rear 18 Formula hoods don't have metal bracing on sides. 19 Formula Ram Air cleaners are one year only (Pins and dimples for holley) 20 Very early 70 cars have pot metal rear filler panels 21 Early 70 cars have 4 trunk pan drain plugs 22 chrome dash gauge bezels (TA) 23 Water pump pulleys 24 power steering pump (only sec gen) 25 Power brake proportioning valve, bracket lines ect. 26 Carpet hold down clips 27 Window blow out clips 28 JW Wheels 29 Thin lip Shaker single snorkel (TA) 30 Headlight Bezels 31 Front seat belt retractors 32 Last year High Compression 33 Blue Trunk release button 34 different firebird fender script 35 A pillar molding extra screw hole 36 Stainless side window weatherstrip channel 37 trunk floor in back different non EES 38 Plastic wire standoffs 39 sunvisor center tabs 40 Outboard front seat belts 41 code 10 polar white 42 Chrome package on engines 43 Manual trans shift knob 44 Angle cut on chrome exhaust tips 45 Three piece rear view mirror 46 Glove box door 4 rivets (not six) 47 Thermostat housing 48 Round vac can in firewall (non RA) 49 dash wiring 50 Plastic filler on core support (VN A/C cars) 51 door glass weatherstips (shorter in door jam) 52 Lighter woodgrain tone on dash 53 rear quarter trim no ashtray 54 rear seat back frame
68 Firebird Coupe 350/Auto/Air 70 RA III Formula/Auto/Air 71 T/A 455HO/Standard/Air 73 T/A 455/Auto/Air Last edited by wwilder9; 11-19-2008 at 12:10 AM. |
And what about seat back locks with power locks? Is that one year only?
68 Firebird Coupe 350/Auto/Air 70 RA III Formula/Auto/Air 71 T/A 455HO/Standard/Air 73 T/A 455/Auto/Air |
Yep.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
Thanks Ray, Thats it.... I wanted to se if it had Red or Black centers .. Red it is, Mine always had red.
What about the covers for the front seat bolts? Were they only on 70 or did 72 have ones also?
Those seat belt washers I made are 70 only..
![]() Full ratcheting hood latch ![]() Carpet Clip ![]() ![]() Rear Alt Brakt ![]() Window blw out clip
Nice Pictures
Im glad this list getting done and glad a couple of mine made the list.
![]() I admit my mention of the black PMD caps had no real basis or research. I just heard somewhere that very early 70 F body had black centers. I think that the GTO guys have narrowed the change from black to red on 70 cars with build dates around Dec 69 Jan 70.(dont quote me on that!)On the blue trunk release button... Ive only seen two 70s with pwr trunk. The buttons were blue or a bluish green.Some might call it green.... Someone mentioned the smaller size sway bars on some 70 TAs , but it didnt make the list. There was an old thread about it, several 70 owners agreed that for whatever reason, a few 70 TAs actually got smaller sway bars. The dot fade pattern on early white stripes (for blue cars) I didnt see it on the list although someone mentioned it. It is another good one that should make the list. Last edited by tajunkman; 11-19-2008 at 01:26 AM. |
On some '70 Trans Ams having smaller, Formula sway bars,....I recall Giles had done some research on this, & at the time, IIRC, he'd found that only some Van Nuys TA's got built with the smaller bars. The belief here, is that for whatever reason, the larger bars did not get sent to Van Nuys in time for some of the TA's production. So rather than hold up the orders, the smaller bars were installed. My 0L106374 has these Formula bars. Interesting to notice that the Build Sheets did not make a distinction whether the TA was built with large or smaller bars. All that I've seen so far just have the same F41 suspension code.
Hows it going transamric?
Mine is a norwood 4 speed. n120xxx It has formula bars and I think that they came on it from the factory. Found old thread ... http://forums.maxperformanceinc.com/...d.php?t=440599 |
One of them belongs to another forum member & is quite an EARLY build,as I recall it was initially shipped to a Zone Office rather than a selling dealer. The other 2 were about mid-term production if memory serves. |
