Old 01-23-2009, 09:29 PM
TEG's Avatar
TEG TEG is offline
Pics.
ID:	155552   Click image for larger version
ID:	155553   Click image for larger version
Old 01-24-2009, 01:13 AM
70RAlll 70RAlll is offline
TEG, please understand by no means was I questioning the soundness of your decision to sleeve. Yes, without a doubt new metal for the rubber gaskets to slide over will ensure leakfree operation. I was just pointing out I have never seen one bad enough to require it. A slight hone of the bore brings new clean metal to light and works as well. As many know, I am realy a TA guy and quite possibly misplaced on this thread. But, our 1970/71 Masters are identical so the diuscussion is valid. My 1970 which is a driver, is driven at least 300 miles per month, a bunch for one of these old cars. My guess is most restored cars don't get this much use in a year. I finished this car 2 years ago and I have had no leaking and/or depreaciation ov breaking ability.. But yes, without a doubt, sleeving will work. But a hone of the bore achives the same result...new smooth metal for the primary and secondary pistons' rubber "o-rings" ,really gaskets but sort of like o rings, to seal to. So please do not take my comments as questioning your decision. It wasn't meant as such..
Old 01-24-2009, 09:22 AM
TEG's Avatar
TEG TEG is offline
No offense taken at all! (Inset beer glasses clinking). I respect all approaches and if you have had good luck rebuilding these without resleeving, that is great. If its not necessary and you have had good luck, why spend the time and money. You are right. I will be honest, there are plenty of things that I did do over the last 5 years and I wish I would have questioned the necessity. Alternative views/information is important.
I will have a 69 TA in my garage someday.
Old 01-24-2009, 01:55 PM
Yes the 69 TA... I have horrible memorys of my experiences with the 69TA's.. In '91 or '92 I decided I wanted a 69 TA. Started looking. Turned down two ,one for $10,000 and one for $12,000.They were both 4 speeds numbers correct cars. Just needed full restos. At that time, I didn't have the time to restore one myself and didn't(and still don't) trust anyone else to restore one for me. So I turned them both down because of too much a project.. Man oh man... if I had only bought these two cars and put them in my barn at the farm... Yes, bad memorys of "the one(well actually 2) that got away!!
Old 01-26-2009, 11:51 AM
dr-doug's Avatar
dr-doug dr-doug is offline
Pictures of my '70 EB master cylinder, and the master that sure looked to be original on my '71 BE..has a small 22 stamped also.
DW
71 SILVER AUTO JUDGE
70 RED AUTO III JUDGE
70 GOLD AUTO III JUDGE
70 SPECIAL ORDER SABLE BLACK 4SPEED III JUDGE
70 ATOLE BLUE AUTO GTO
69 C.RED 4SPEED III JUDGE
67 WHITE 4SPEED 400 VERT FIREBIRD
65 MAIZE 4SPEED TRIPOWER VERT GTO
65 TURQ. 4SPEED TRIPOWER VERT GTO
WANTING A IV......
20 other non-pontiacs which need to be thinned down so I can buy more PONTIACS
Old 01-26-2009, 06:54 PM
motorcitymusclecar motorcitymusclecar is offline
The repop is $79.00
