Old 01-22-2009, 01:24 AM
richmas5 richmas5 is offline
Default 70 rear spoiler
does anyone know how to spot a factory rear spoiler from a repro,are there part numbers on the spoiler ,any info or pics would be very helpful
Old 01-23-2009, 12:15 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
I have two factory 70 GTO/Judge wings and both have seams on the bottom side of the wing.I have also boughten a couple of aftermarket wings and they didn't have the seams on the bottom side of wing.Leading me to believe they were molded as one piece. I don't know if that holds true for all the aftermarket spoilers or not.Also I've seen used factory spoilers that someone had used a filler to hide the seams,hope this helps you more than confuses you.Mike
Old 01-23-2009, 12:36 AM
it makes sense to me ,thats what I thought,the seams are correct,now to find one,thanks for the info
Old 01-23-2009, 12:40 PM
70judgeconv 70judgeconv is offline
Also factory wings have studs. The repo wings require bolts
Old 01-24-2009, 03:31 PM
The Boss's Avatar
The Boss The Boss is offline
Here's an NOS one I sold last year - hope it helps.
Name:	Spoiler full box.JPG
ID:	155608   Click image for larger version
Name:	Spoiler in the box.JPG
ID:	155609   Click image for larger version
ID:	155610   Click image for larger version
ID:	155611   Click image for larger version
And go racin' in the street.
Old 01-28-2009, 04:39 PM
peppergreen's Avatar
peppergreen peppergreen is offline
I also heard the originals have a drain hole.
Checked mine, dead middle on the underside, there is a tiny hole
Not sure if the repros have it.
"Drive a GTO".......Iggy Pop-Lust for Life
