Old 02-03-2009, 11:48 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I know this is nit picking but I even cleaned and cleared the dimmer switch for re-use.
It has a little pitting but is functional
ID:	156783   Click image for larger version
ID:	156784   Click image for larger version
ID:	156785   Click image for larger version
  #262
Old 02-04-2009, 12:12 AM
That's looking sharp Phil!
Old 02-04-2009, 01:18 AM
saltman 1965's Avatar
saltman 1965 saltman 1965 is offline
Not nit picking but attention to the details. Maybe obsession that's what my EX called it. On the pedal pads Bleche-Wite tire cleaner & a stiff brush should clean out that red GA clay & some Mothers polish & #000 steel wool on the trim. Can not wait to see when its done. Saltman
1965 Lemans Vert
1968 Shelby GT 500 KR
  #264
Old 02-08-2009, 09:43 PM
fyrffytr1's Avatar
I went to the Moultrie swap meet yesterday and came home empty handed. For a show as big as this is there are never any Pontiac parts or vendors.
But, even though participation was down there were still about 1,500-2,000 cars in the corral and I looked at most all of them.
My buddy and I got there at 8am and walked until 4pm with only a 15 minute sit-down to eat a bite.
He bought 4 tires from Coker for his 57 Chevy resto and I pulled them,on a wagon, about 3/4s of a mile to his truck.That may not sound like much but when you are dodging thousands of spectators it can be a chore.
I didn't get anything done on mine. I did push it out of the shop. Then, I went through all my parts and sorted them out. I also cleaned up the shop so I have some room now.
All the totals remain as last week.
  #265
Old 02-08-2009, 10:33 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
I went out and bought a new one,my old one had a little sand still in it.I got it from the parts store.
  #266
Old 02-12-2009, 11:48 PM
fyrffytr1's Avatar
Just a quick note. I ordered a few small parts from our host and they arrived today. So, after supper, I ran(Well, I walked kinda fast) out to the shop and put them on. Seven minutes later I was finished. I installed the heater hose nipple, stuck the molded heater hose on temporarily and put the throttle return spring on. I hope to get some work done tomorrow afternoon and maybe Saturday, but since it is Valentine's day I hope to get mushy with Momma
  #267
Old 02-13-2009, 12:07 AM
Just a quick note. I ordered a few small parts from our host and they arrived today. So, after supper, I ran(Well, I walked kinda fast) out to the shop and put them on. Seven minutes later I was finished. I installed the heater hose nipple, stuck the molded heater hose on temporarily and put the throttle return spring on. I hope to get some work done tomorrow afternoon and maybe Saturday, but since it is Valentine's day I hope to get mushy with Momma:whoo:
You mean she's gonna help you in the garage??
  #268
Old 02-13-2009, 12:26 AM
fyrffytr1's Avatar
She hasn't set foot in the shop since asked her to sit on the frame in place of the motor so I could install the front springs.
That and I think she is allergic to grease.( I keep an open tub of it right inside the door).
  #269
Old 02-13-2009, 09:46 AM
GT182's Avatar
GT182 GT182 is offline
Nice job on the dimmer switch Fyrffytr1.
I look at it this way.... new isn't always better. If you can restore or clean up an original part, that's way better then a repo. IMO. And cheaper too. LOL
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #270
Old 02-14-2009, 12:15 AM
fyrffytr1's Avatar
Thanks GT. Did you look at the pics on page 13? I am trying to reuse as many parts as possible, unless safety is an issue.
  #271
Old 02-15-2009, 04:24 PM
fyrffytr1's Avatar
Well, getting mushy took a lot longer than I expected! I did take some trim pieces off a spare door and buffed them out. But, they are to sell. I did finish installing the gas tank plus the 7 minutes I spent on it the other night gave me 1 1/2 hrs more labor.
I bought $142.09 worth of parts and supplies last week. I got the heater hose fitting, molded heater hose,throttle spring, A/C expansion valve, 7.5" parking brake hook, two 32oz bottles of synthetic brake fluid(buy one, get one free), some hose clamps, grease,and stainless steel bolts and washers.
So here are the latest totals.
My Labor at 289hrs...........$5,780.00
Parts..............................$7,857.09
Outside Labor..................$3,300.00
Gifts.................................$716.52
Total...........................$17,653.61
  #272
Old 02-15-2009, 11:25 PM
GT182's Avatar
Parts on Page 13 look good too Fyrffytr1.
BTW... what was the original color of the parking brake assembly? I see you painted yours... is that Spray Gray or Detail Gray? looks nice no matter what color you painted it. I've got to do mine now, as it looks like yours before you painted it. LOL
Gary
  #273
Old 02-15-2009, 11:40 PM
fyrffytr1's Avatar
I used Cast Blast because it was all I had. It is the same paint I used on my Master cylinder and exhaust manifolds. May not be correct but it looks fine to me.
  #274
Old 02-16-2009, 05:22 AM
From the look of Phil's pics and going by my '68 PB assy, I'd say it was unpainted bare metal with the lower portion dipped in black paint....runs included.
The Cast Blast looks good because it does mimic that unpainted look.
Old 02-16-2009, 09:33 PM
GT182's Avatar
Thanks for the info on Cast Blast guys. The pk brake assembly in mine was never painted and the one to replace it wasn't either, except for the bottom leg. Both are pretty rusty too. I've started with the wire brush disc in my drill to clean up the replacement. I thought of just using the spray rust converter and leaving it at that. Looks like the Cast Blast is the way to go.
Gary
  #276
Old 02-16-2009, 10:58 PM
fyrffytr1's Avatar
Mine was badly corroded and the mechanism was stuck so I media blasted it then soaked it in my parts cleaner. After working the pedal back and forth to loosen it up I sprayed it with brake parts cleaner. Then I wiped it good with Acetone before painting it grey. A day later I taped it off and sprayed the black.
When the paint cured I put a couple drops of oil on the pivots and gears then worked the pedal several times. Now, it is good as new.
  #277
Old 02-16-2009, 11:48 PM
fyrffytr1's Avatar
Either I just made a mistake or I got a pretty good deal. I bought a 67 A/C dash bezel on e-bay for $60 plus $18 shipping. I hope it is as described.
http://cgi.ebay.com/ebaymotors/ws/eB...m=320341779506
  #278
Old 02-17-2009, 02:08 AM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Looks like you got a good deal, if I remember right your radio hole was all hacked up wasn't it?
  #279
Old 02-17-2009, 05:57 AM
I'd say you lucked up on that. It's hard to get anything on eBay like that any more.
Old 02-17-2009, 09:14 AM
GT182's Avatar
If it's as good as he says, then yer one lucky chit. And it comes with ignition and wiper switches too.... nice added bonus if they work.
Gary
