Old 02-25-2009, 05:55 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Default Blade for clutch fan wanted
Hey guys - the radiator fan blade on my latest acquisition is badly bent.
Needed - correct 1974 455SD T/A fan blade. MPC sez PN 480035, 7-blade, 18 3/4" diameter. Shows to fit '70-'76 all V8 'birds with A/C. This is for use with a fan clutch.
I'll pay a fair price for a fan in VERY GOOD condition. Nothing bent, no loose rivets, no corrosion, etc.
Thanks!
Regards,
"455HO" Lloyd
Old 02-25-2009, 06:17 PM
Will ck my boxes of fans.
Old 02-25-2009, 07:39 PM
Lloyd-TX's Avatar
Thanks Roger, I appreciate that. You know the quality I'm looking for.
Regards,
"455HO" Lloyd
Old 02-25-2009, 07:57 PM
74 SD455 Formula 74 SD455 Formula is offline
Hey Lloyd,
Are you looking for one of these ?????
ID:	159479   Click image for larger version
Old 02-25-2009, 09:10 PM
Lloyd-TX's Avatar
Question
Originally Posted by 74 SD455 Formula View Post
Hey Lloyd,
The one on the right in your post might be correct. Could you look closely at the steel center section for any numbers? You may need to remove the fan clutch.
Thanks!
Regards,
"455HO" Lloyd
Old 02-25-2009, 11:05 PM
Lloyd,
Sorry I took it apart and do not see any part #'s.There is a stamping that say's " FRONT " and another that has " OCT " that is it.By the way the picture's I post are of the same Fan,just showing both side's. I also have a 6 bladed fan. I have no idea were that came from. Do the 72 455HO GTO's with air use the same fan ?I have that car here in the garage and could compare the 2.Let me know,
Jim
Old 02-25-2009, 11:43 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Mine has a Pat. No., Month and Year stamped.
