| Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
I have a 67 bird project conv and I've been doing some research on drivetrain options. I was looking at LS1/T56 out of newer f-body but I think it's more work than I want to do. What I want is efi, overdrive MT, hei. Looking for dependability, drivability and fun to drive but not looking to take it to the track. It's a convert so I think thats just asking for trouble. I think I can get what I want with a tremec 5spd and maybe a poncho or sbc with efi conversion kit. It's a lot less work with mounts, wiring, shifter location, cooling, clutch, rear gears, basically everything.
I'm open to suggestions on motor/trans combos and efi set-ups. My other cars are 67 gto, 69 vette both #'s cars and I like the original look of these. I want the looks of classic but better performance. This will be my first project that doesn't have points or carb and with all of the body and suspension work needed I just want the drivetrain to b e easier.
I'll try not to show my bias too much, but I think a traditional Pontiac, w/efi and whatever transmission that you want to use, would be the easiest combo to install in your car. There was an article, in High Performance Pontiac, about putting efi on a Pontiac. I can't tell you what issue that it was in, but I'm sure someone on here will know. Good luck!
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. [email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
I vote for traditional Pontiac power just for thhe look, however by the time you build one that is good with the injection system, tuning and what not The cost is more or equals that of the LS1 install. just on a good low mile used setup.
PLus you will get mid 20's MPG versus 12-14 MPG. There are a few companies making the swap very easy. If you dont have AC then it will be a breeze with the adaptor plates and Edelbrock headers. You will jsut have to slightly modify the trans tunnel for clearance for the T56 I think. I picked up a 38k LS1 and 4L60E last summer for just a slip over 2k with harness so they are out there. Good luck with what ever you decide.
Eric CURRENT CARS 68 Firbird 400ci convertible |
I found 98 LS!/T56 with 40k for $2300 locally. I was leaning that way hard for awhile but I keep coming back to the efi poncho. I just like the look of originality. Fitting the LS1 is just the beginning of that change over. I know I won't save any money with poncho, actually I suspect it will cost more. It should be alot less headaches though.
It's getting hard to find poncho motors and they're expensive plus shipping costs. If anyone knows where to find a 400 close to maryland let me know. Also if anyone has experience with a poncho efi or fitting a tremec 5 speed.Thanks |
Yes, there are quite a few of us out there who are installing EFI on the traditional Pontiac motor. Do a search for EFI, you will be suprised what comes up.
My project is a 455 with the megaSquirt ECM and the Edelbrock manifold. I have included several links to help you get started. http://www.msefi.com/index.php http://www.pro-touring.com/ http://www.pontiaczone.com/forum/ http://www.nastyz28.com/forum/index.php
Its ok to giggle and snicker, Dont laugh and point |
What is so particularly difficult with the LS1 swap? Everything is available to make it a drop in. Mounts are available, headers are available, fuel tanks are available... Besides the motor mounts, what do you have to change with the LS conversion that you wouldn't have to with the Pontiac?
'73 Formula 400 Cammed LS1/T56/3.73's [email protected] 2.03 60 ft. <~~ Bone stock LS1 with 4L60E/3.08's Went 12's in pure daily driver trim! A/C, leather power seats, power steering, full stereo, sound deadening, power windows, full suspension, true street tires, power 4 wheel discs, and 25MPG! |
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
My goal is to have efi benefits and an overdrive for cruising speeds. All of these LS1 issues are surmountable but I think I can get these in an easier way with an efi kit and tremec TKO600 trans on a poncho 400. And then I have the benefit of having a close to stock appearance under the hood and what I believe would be better value to the car. Or hell maybe I'm just lazy. |
Gauges? You can adapt your stock temp and oil pressure gauges, your tach will work with simply telling the computer to change pulse counts to a traditional V8 and your speedo will work with a converter box. I have nothing against an EFI'd Pontiac, I think it would be cool. But, the LS conversion is likely to run harder, longer, be trouble free, and get better mileage while saving several hundred pounds on the front end.
As soon as EFI is part of the requirement, nothing beats an LSx swap.
Andrew |
