Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 03-02-2008, 04:43 PM
hungry69bird hungry69bird is offline
Default looking for headlight rings
wondered if someone might have headlight ring layin around for a 69 firebird...i imagine all the dual headlights would be the same...this is the part with the 3 clips that retain the headlight from falling on the ground...
69 bird, 428 custom solid roller, rpm intake, #62 heads sd ported 260 cfm, 850 holley dp. arias pistons.scat rods redneck tranny, continental 3200 stall
  #242
Old 03-02-2008, 09:07 PM
mechanic17 mechanic17 is offline
Hey Compadres:
I can offer up a full set of new-in-the box Clevite 77 .030 under rod bearings PN #CB-758-P30.
Can anyone spare any of these?:
-a decent V8 timing cover (pref studs and/or w/good water pump in it)
-cam thrust plate w/bolts and fuel pump eccentric w/bolts
-non-chrome dipstick with tube and/or stock windage tray lower tube
-tall valve covers or some means of raising stock covers above roller rockers
-a throttle cable/bracket that will work on '70 GTO (no need for # correctness)
-a set of straight pushrods between 9.5" and 9.6" length
Keep up the good work!
  #243
Old 03-18-2008, 12:15 PM
Rack776's Avatar
Rack776 Rack776 is offline
Originally Posted by cruze69gto
I have a YB code 350 bare block, standard bore. If anyone is interasted. I will be going to Norwalk can bring if someone needs it.
Mike
I am interested in the block, but I cannot go to Norwalk this year.
Where is the block at and is it rebuildable?
I'm in Allentown, PA or about 1.5 hours north of Philladelphia, PA
I would be willing to drive about 3 or so hours to get it.
Thanks, Jason
Jason Rackawack
1975 455 Trans Am - 1975 Firebird 400
  #244
Old 03-18-2008, 12:26 PM
Rack776's Avatar
Default 1996 - ? S-10 Front Bug Hood Guard
I'll offer up a Bug Shield thats off my 1996 S-10 Truck
Its in OK shape a few small scratches will work great for a driver.
if anyone needs or wants it it's theirs for free just pay the shipping.
Jason
Jason Rackawack
  #245
Old 03-31-2008, 09:55 PM
FrankieFeenixx FrankieFeenixx is offline
Default stock front sway bar from a '66 Tempest
original GM 13/16" front sway bar up for grabs. Must pick up in Lodi NJ, I'm not dealing with shipping this thing.
  #246
Old 04-15-2008, 03:56 PM
gto_30_1967 gto_30_1967 is offline
is the 66 fender the same as the 67 gto fender? im also looking for a 70-72 gto deck lid. Anyone have one?
  #247
Old 04-15-2008, 04:13 PM
Default Mounts
Are these the mounts that bolt to the block? if so i need them for my 455 going in a 71 gto.
Originally Posted by mashedfinger67
Brand: Anchor (Korea)
Part#: 2335 (R), 2336 (L)
I got em' at checkerautoparts for $7.79 each when I had a hair brained idea that I could move my new 462 back in my '67 by using these mounts. They are just sitting around collecting dust and I am sure someone could use them. New owner to pay shipping. PM me if interested.
This is what Checker's web page say's the mounts will fit;
1970 - 1971 GTO
1973 GTO
1970 LEMANS
1972 - 1974 LEMANS
1969 - 1979 FIREBIRD
1970 - 1973 GRAND PRIX
1973 - 1975 GRAND AM
1971 - 1972 BONNEVILLE, GRANDVILLE
1971 - 1978 CATALINA, GRAND SAFARI
  #248
Old 04-15-2008, 04:41 PM
Default fender
is a 66 fender the same as 67, if so i'll take it off your hands!
jim
Originally Posted by vidguy
The 66 GTO Passenger Fender I have For Sale... IT's free if you pay for shipping or pick it up!
  #249
Old 04-26-2008, 10:49 PM
form74's Avatar
form74 form74 is offline
Default Original Goodyear Spare FR78-15
Tired of holding onto this and thought somebody might want it, Free for the taking was mounted still last summer and holding air. Like brand new.
Original Goodyear Spare FR78-15 from 75 Formula. Pickup only
ID:	130648   Click image for larger version
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
  #250
Old 05-19-2008, 11:20 PM
vidguy's Avatar
vidguy vidguy is offline
Sorry about the Fender. It is gone.. They are ALMOST the same but a minor difference at the front near the grill.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
  #251
Old 05-24-2008, 06:02 PM
70KGOLD's Avatar
70KGOLD 70KGOLD is offline
I have a 69 lemans front bench seat for pick up if anyone needs it.
  #252
Old 06-17-2008, 02:31 AM
Nathaniel1234's Avatar
Nathaniel1234 Nathaniel1234 is offline
I need a single pushrod for my 74 455 (change from stock 4x to 6x heads) w/ RaIV cam and Rhoads variable duration hydraulic lifters. If I am correct that I can use my set from the 74 455 / 4x set up with 6x heads, then I only need to replace 1 pushrod. Anybody care to confirm size match and donate 1 pushrod? Thanks, obviously I would pay for the shipping or even pay you something for the pushrod. Alternatively, I would commit to posting some part(s) for free /shipping for small part.
Nathan Dougal
1234 N. Kedzie Ave.
Chicago, IL 60651
  #253
Old 11-06-2008, 07:11 PM
riceslayer's Avatar
riceslayer riceslayer is offline
hey nate i got a bunch of pushrods... call me at home 2058708835
  #254
Old 03-08-2009, 09:12 AM
amcmike's Avatar
amcmike amcmike is offline
Firebird - need old body bushings hardware.
I was supposed to reuse some of the old steel parts from the factory bushings (I went with solids), but not having the directions, didn't realize it. If anyone has replaced theirs and the old steel parts aren't completely rusted away please let me know.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
  #255
Old 04-01-2009, 01:09 AM
performerrpm's Avatar
performerrpm performerrpm is online now
have some 66-7 lemans 4 door headliner trim" over the doors" thats to nice to throw away even if it is for a 4 door car. hopefully someone can use it here.
  #256
Old 04-03-2009, 03:03 PM
DScruggs's Avatar
DScruggs DScruggs is offline
Free and very cheap.
I have a BUNCH of Pontiac part I wish to give away.
HEI distributor
Running 350 motor
Not running 455 block
P/S Pumps
Heads
Long Shaft Turbo 400
Shifter
brackets
Lots of STUFF going out the door LOL
Tons of stuff
I will try to list most of it over the weekend
  #257
Old 04-11-2009, 09:30 AM
GT182's Avatar
GT182 GT182 is offline
DS.. PM sent.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #258
Old 05-11-2009, 01:55 PM
harrington harrington is offline
First I would like to thank Performerrpm for the trim pieces.
I have a few things to offer for free, come pick them up. Parts are located in central Indiana.
82-92 Firebird rear hatch, no wing holes, great shape
82-92 Firebird door glass, both sides
70-81 Firebird door glass, both sides
75-81 Firebird back window glass, have 2 avaliable
Hood off of a 81 Camaro, should be the same as Firebird, minor surface rust, no holes, no dents
Trunk lid off of a 81 Camaro, should be the same as Firebird, no rust, no dents, has holes for factory spoiler
Hood off of a 74 Trans Am, shaker style, minor surface rust, no holes, hood only no shaker
If anyone is interested, let me know.
  #259
Old 06-08-2009, 10:22 PM
KenB KenB is offline
Default 72 Firebird Std Interior seat covers white- USED
If someone needs seat covers, they are welcome to these.
Drivers is very well worn - no rips
Passenger is worn, no rips
Rear needs cleaning and would be presentable, particularly if yours in trashed.
As understand, these are repops put on by the 2nd owner at some point.
I took them off my car as it should (does now) have 71 Custom interior.
Ask for pics, I have them already.
You pay shipping and take them all (or maybe ditch the driver's). Please.
Regards
PS I'm always looking for the rear window interior trim for 70-74 Firebird
71 Firebird Esprit
94 TA - 396 LT1 powered - Bought new in 1993. Total money pit
Cars gone by - 76 Formula, 73 Esprit, 75 Esprit. 87 Buick WE4
  #260
Old 06-15-2009, 08:21 AM
Trans-Formula II's Avatar
Trans-Formula II Trans-Formula II is offline
Default Th350 and crossmember
I have a Th350 and Th350/ 4 speed crossmember out of a 79 T/A. It also has the driveshaft too. I have not used the trans other than in my driveway. They are free you pick up , I will be going to the Pontiac Nat's too.
I am looking for a 68 Lemans or Tempest nose if anyone has one.
