#241
wondered if someone might have headlight ring layin around for a 69 firebird...i imagine all the dual headlights would be the same...this is the part with the 3 clips that retain the headlight from falling on the ground...
69 bird, 428 custom solid roller, rpm intake, #62 heads sd ported 260 cfm, 850 holley dp. arias pistons.scat rods redneck tranny, continental 3200 stall |
#242
Hey Compadres:
I can offer up a full set of new-in-the box Clevite 77 .030 under rod bearings PN #CB-758-P30. Can anyone spare any of these?: -a decent V8 timing cover (pref studs and/or w/good water pump in it) -cam thrust plate w/bolts and fuel pump eccentric w/bolts -non-chrome dipstick with tube and/or stock windage tray lower tube -tall valve covers or some means of raising stock covers above roller rockers -a throttle cable/bracket that will work on '70 GTO (no need for # correctness) -a set of straight pushrods between 9.5" and 9.6" length Keep up the good work! |
#243
Where is the block at and is it rebuildable? I'm in Allentown, PA or about 1.5 hours north of Philladelphia, PA I would be willing to drive about 3 or so hours to get it. Thanks, Jason
Jason Rackawack 1975 455 Trans Am - 1975 Firebird 400 |
#244
I'll offer up a Bug Shield thats off my 1996 S-10 Truck
Its in OK shape a few small scratches will work great for a driver. if anyone needs or wants it it's theirs for free just pay the shipping. Jason
#245
original GM 13/16" front sway bar up for grabs. Must pick up in Lodi NJ, I'm not dealing with shipping this thing.
#246
is the 66 fender the same as the 67 gto fender? im also looking for a 70-72 gto deck lid. Anyone have one?
#247
Are these the mounts that bolt to the block? if so i need them for my 455 going in a 71 gto.
is a 66 fender the same as 67, if so i'll take it off your hands!
jim Quote:
#249
Tired of holding onto this and thought somebody might want it, Free for the taking was mounted still last summer and holding air. Like brand new.
Original Goodyear Spare FR78-15 from 75 Formula. Pickup only
74 Formula Below motor destroyed fall of 2023 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet 75 Formula 400 / 4-SPD matching numbers |
#250
Sorry about the Fender. It is gone.. They are ALMOST the same but a minor difference at the front near the grill.
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
#251
I have a 69 lemans front bench seat for pick up if anyone needs it.
#252
I need a single pushrod for my 74 455 (change from stock 4x to 6x heads) w/ RaIV cam and Rhoads variable duration hydraulic lifters. If I am correct that I can use my set from the 74 455 / 4x set up with 6x heads, then I only need to replace 1 pushrod. Anybody care to confirm size match and donate 1 pushrod? Thanks, obviously I would pay for the shipping or even pay you something for the pushrod. Alternatively, I would commit to posting some part(s) for free /shipping for small part.
Nathan Dougal 1234 N. Kedzie Ave. Chicago, IL 60651 |
#253
hey nate i got a bunch of pushrods... call me at home 2058708835
#254
Firebird - need old body bushings hardware.
I was supposed to reuse some of the old steel parts from the factory bushings (I went with solids), but not having the directions, didn't realize it. If anyone has replaced theirs and the old steel parts aren't completely rusted away please let me know.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
#255
have some 66-7 lemans 4 door headliner trim" over the doors" thats to nice to throw away even if it is for a 4 door car. hopefully someone can use it here.
#256
Free and very cheap.
I have a BUNCH of Pontiac part I wish to give away. HEI distributor Running 350 motor Not running 455 block P/S Pumps Heads Long Shaft Turbo 400 Shifter brackets Lots of STUFF going out the door LOL Tons of stuff I will try to list most of it over the weekend |
#257
DS.. PM sent.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
#258
First I would like to thank Performerrpm for the trim pieces.
I have a few things to offer for free, come pick them up. Parts are located in central Indiana. 82-92 Firebird rear hatch, no wing holes, great shape 82-92 Firebird door glass, both sides 70-81 Firebird door glass, both sides 75-81 Firebird back window glass, have 2 avaliable Hood off of a 81 Camaro, should be the same as Firebird, minor surface rust, no holes, no dents Trunk lid off of a 81 Camaro, should be the same as Firebird, no rust, no dents, has holes for factory spoiler Hood off of a 74 Trans Am, shaker style, minor surface rust, no holes, hood only no shaker If anyone is interested, let me know. |
#259
72 Firebird Std Interior seat covers white
If someone needs seat covers, they are welcome to these. Drivers is very well worn - no rips Passenger is worn, no rips Rear needs cleaning and would be presentable, particularly if yours in trashed. As understand, these are repops put on by the 2nd owner at some point. I took them off my car as it should (does now) have 71 Custom interior. Ask for pics, I have them already. You pay shipping and take them all (or maybe ditch the driver's). Please. Regards PS I'm always looking for the rear window interior trim for 70-74 Firebird
71 Firebird Esprit 94 TA - 396 LT1 powered - Bought new in 1993. Total money pit Cars gone by - 76 Formula, 73 Esprit, 75 Esprit. 87 Buick WE4 |
#260
I have a Th350 and Th350/ 4 speed crossmember out of a 79 T/A. It also has the driveshaft too. I have not used the trans other than in my driveway. They are free you pick up , I will be going to the Pontiac Nat's too.
I am looking for a 68 Lemans or Tempest nose if anyone has one. Last edited by Trans-Formula II; 06-15-2009 at 08:46 AM. |
