Old 04-13-2009, 08:06 PM
budda's Avatar
budda budda is offline
Unhappy stuck harmonic balancer
hello all. i just got a 1996 firebird. with a 3.8 V6 t-tops and alot of problems. i ran a code test and it said i need a crank sensor and a MAF sensor. both easy jobs. or i thought. i got the crank sensor but the harmonic balancer wont come off. i took the center bolt out but it wont move. i tryed auto zone for a puller but they had nothing to help... any lil trick to pop it off??????
Old 04-13-2009, 08:20 PM
TransAmboy455's Avatar
TransAmboy455 TransAmboy455 is offline
Clean the corrosion terminals plugs where the senors plug in and re-run code test.
1976 Sterling Silver Trans Am Retro Fit 455 WIP
http://www.youtube.com/user/transamboy462
Old 04-13-2009, 09:02 PM
budda's Avatar
up date. i just tryed to start it and its dead. it turns over but no fire. so i think the crank sensor just took a dump. any clue how to get the balancer off.
Old 04-13-2009, 09:16 PM
budda's Avatar
anyone??? HELP
Old 04-14-2009, 10:42 AM
budda's Avatar
ok i got a gear pull from napa and i hope that will work. bout to got try it now
Old 04-14-2009, 10:58 AM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
If the 3.8 is anything like the LT1 the balancer bolts onto a hub. It is the hub that comes off in a different manner.
There is some info to be gained in the 82 - 02 Firebird and TA Tech area.
You might have a bit more luck with this question on a site for late models and V6's. This Forum is primarily aimed at traditional Pontiac motors and older vehicles.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 04-15-2009, 06:36 AM
budda's Avatar
Stewart
got ya. i'm new. i'm sure it shows. but i got the bastard off. i needed a gear puller to get it off. not a harmonic balancer puller. it came right off. now theres a lil ticking noise. but i'm bout to pull it one more time and figure it out..couldnt be anything big.
Old 04-16-2009, 08:03 PM
Squidward's Avatar
Fun... My 99 Chev with 3.1 threw the crank sensor codes after a replaced balancer (outer ring slipped 3/4", throwing belt). Knowing balancer was new, eventually replaced both crank sensors, cam sensor, balancer a 2nd time (still warrantied), and timing gears/chain. End result after taking it to a shop in frustration was that the slotted ring on the balancer had been pressed in too far, causing the crank sensor to occasionally lose the trigger signal.
Autozone parts - it sucks to buy new parts that were manufactured incorrectly.
Old 04-16-2009, 09:17 PM
budda's Avatar
ya. i had win that happens.. i hve got cv axels from autozone that made more noise than the old ones..... but i got it together.. it was the lil plastic cover. it was rubbing the balancer. i trimmed it and now its working great. starts every time i hit the key.
