Old 05-01-2009, 11:08 AM
FM50KW's Avatar
FM50KW FM50KW is offline
Default 65 Vent Pull Knob Color
1. Anyone know the correct factory color for the vent pull knobs? Mine appear to have been chrome at one time (worn badly) not certain if orignal from 65.
2. How do the knobs come off, twist? Don't see any set screws etc. Maybe crush them and glue on the new ones?
Old 05-01-2009, 11:18 AM
Blue '66's Avatar
Blue '66 Blue '66 is offline
The knobs were chrome plated.I have not taken mine off yet but from others use a dremel or hack saw blade and cut a line to get to the shaft.
Old 05-01-2009, 01:44 PM
Karfever's Avatar
Karfever Karfever is offline
Use a dremel cut-off tool and slice the old know, twist and it will fall apart and off the shaft. PY sells a excellent plastic chrome knob, you just have to drill it our slightly and screw if on the shaft. Worked great for me!
65 GTO
Old 05-01-2009, 03:35 PM
BOB VIDAN BOB VIDAN is offline
We use the earlier radio knobs with a setscrew as a replacement. Get the old off, file a flat, add knob, tighten setscrew, done. This way you don't have to worry about the chrome peeling again.
Old 05-01-2009, 07:17 PM
ponchoskip ponchoskip is offline
Bob,
When you say "earlier" are these Radio Knobs ones that look like the 65 dash knobs? I think I read that big pontiacs (probably 65 or earlier) had die cast vent knobs that work too. Sounds like a great idea especially if they look very similar to the originals.
Ponchoskip
Old 05-01-2009, 07:45 PM
65lemans's Avatar
65lemans 65lemans is offline
Mine are like a yellowed Plastic knob, They don't appear to have been Chromed....
65lemans
Old 05-01-2009, 10:24 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
65lemans
They were chromed when the car was new. The chrome starting going away in just a few years.
Old 05-02-2009, 01:38 AM
I think what we used were 64 knobs and are identical. They may have been heater control or AC knobs, but have a setscrew and work great.
Old 05-02-2009, 04:18 PM
eaglesan13 eaglesan13 is online now
Bob,
I think you're right about them being radio knobs, they have a flat side in the hole.
Chris
ID:	167269   Click image for larger version
Old 05-04-2009, 04:44 PM
gtopont gtopont is offline
Thumbs up 64 radio knobs
ALL knobs for the radio are chrome as is the vent knobs...the reason they look yellow is that the chrome wore off..they are CHROME ...the VENT knobs are chrome...cut them off get new ones and drill the hole slightly larger..then use weather stripping glue to secure..
Old 05-05-2009, 07:13 PM
72pontiac's Avatar
72pontiac 72pontiac is offline
mine were almost for sure silver paint some was wore off some was left on but it wasnt chrome coming off. but what do i know.
Old 07-19-2009, 11:44 AM
MIke L MIke L is offline
Guys..
Where do you find these?
I checked Ames, PY [as Karfever said they have]
and Year One and noone sells just the chrome vent knobs,
or even the radio, or a/c knobs that some of you guys use.
Mike
Old 07-19-2009, 01:43 PM
FFD FFD is offline
Originally Posted by MIke L View Post
Guys..
Mike
PY catalog page 35 they are listed. May be unavailable though like somethings did you talk to a person?
Old 07-19-2009, 04:15 PM
Found them
Thanks FFD
Mike
Old 07-29-2009, 10:35 AM
bigpop bigpop is offline
I am going to redo my knobs,I am using a plastic primer,then color them with Eastwood's Chrome paint,It should look terrific,as other parts look chrome I have done.Will post photo's soon. Larry B.
Mr. President, you can't say Dallas doesn't love you "
Old 07-29-2009, 11:39 PM
Jerry H.'s Avatar
Red face
I've tried that before Larry and I was not satisfied with the results. As cheap and easy as it is to replace them, I replaced them on my latest 65.
Old 07-30-2009, 07:45 AM
Jerry, I will try to get a friend to do a "before and after" pic,and have him post it.This is Eastwood's Chrome and I've really been impressed,it looks like chrome from 5 ft.! Good in a pinch,some guys couldn't tell. Larry B.
Old 07-30-2009, 09:52 AM
Jerry H.'s Avatar
As I posted before, I've tried it on the plastic chrome. IIRC those knobs in plastic are only about $4 each. So by the time you buy the primer and the chrome paint you've spent as much as you would for new knobs. Just a little labor and some epoxy and you've got a better job, IMHO.
Old 07-31-2009, 05:31 AM
goatman65's Avatar
I used the repop plastic knobs on my vents and on the Custom Autosound stereo of my 65.A little work with the Dremel and I made them a tight press fit so if I ever need to remove them I won't 'F'up the stereo.
