Does anyone know where or if the plastic inserts that fit into the T/Top frame are available? (where the flat tabs on the roof fit into the T/Top frame)
Thanks in advance, Larry
I Bleed Arrowhead Red, 64 GTO 389 Tri Power 4spd Nocturne Blue Poly 70 GTO 400 4spd Palladium Silver 75 T/A 400 4spd Buccaneer Red 71 T/A 455 4spd Cameo White 01 T/A Bright Red 4L60E Ram Air WS6 02 TA Navy Blue Metallic 6 spd Ram Air WS6 |
Those plastic inserts were still available from your local Pontiac (GM) dealer not so long ago. You may want to give them a try?
Are these what your looking for?
http://www.fbodywarehouse.com/fbw/pr...cat=222&page=1 OR http://npd.dirxion.com/WebProject.as...Code=fir08pfp# C-12810-10 on page 131 OR http://www.classicindustries.com/con...artNumber=k817 Last edited by TWF79; 05-03-2009 at 09:13 AM. |
Thanks Again, Larry
Do you happen to know the part #. I need to replace them on my car as well. Thanks.
1979 Trans Am SE Black & Gold, T-tops, 400/4spd!!! I don't know whether I need a frontal lobotomy or a bottle in front of me?! ![]() "A Camaro looks like it could kick your ass. A Trans Am looks like it's coming over to do it!" |
I am sure some guys on this board have that number maybe they can get it quicker for you. Larry
GM part# is 20066276 Good Luck
Thxs for the part#. Checking locally.
Great!!! Thanks.
