Old 05-08-2009, 07:40 PM
66bonne's Avatar
66bonne 66bonne is offline
Default "B" body ring gear vs "A" body ring gear
In a related post I told of blowing out the rear end in our Catalina at the drag strip last week. Finally had a chance to pull the back cover. The spider gears were the weak link, it appears that at least one of the spider gears lost a few teeth.
The ring gear is a 12 bolt [3.42 ratio]. The question is: Is the diameter of the big body 12 bolt the same as for other GM units ? The reason I ask is that I am considering putting a 12 bolt spool in place of the posi unit.
I do have some other spider gears that can be put in but I don't want to race with a rebuilt posi unit and risk blowing it out.
I am considering a custom built rear end for the Catalina but the spool would be a less expensive alternative and a quick-fix for the immediate time being.
Any help is greatly appreciated, Jim
Old 05-08-2009, 08:08 PM
misterp266's Avatar
The ring gear is the same diameter, can use a 12 bolt spacer, but you can't use a 12 bolt spool. I had a 3.42:1 posi in my '66 GP and it ate up the rear running 12.1 @ 110 MPH. I'd put a 9 inch in it if you're looking to go faster. JMO
BTW, Brad says he'll have some new R&P gears soon to fit that rear......
" Darksiders Rule "
Old 05-08-2009, 09:33 PM
66bonne's Avatar
misterp266: thanks for the reply. Question: If the ring gear is the same diameter on 12 bolts then why wouldn't a 12 bolt spool work ?
Thanks, jim
Old 05-08-2009, 09:40 PM
66bonne's Avatar
Also, thanks for the news regarding upcoming R&Ps, that would be great.
Thanks, jim
Old 05-09-2009, 09:43 AM
misterp266's Avatar
Jim,
I admit I never tried it but I'm assuming the spool would be:
  • different width.
  • different bearing size.
  • different axle diameter and maybe spline.
As far as I know only 3.55:1 gears will be available. Primarily targeted to street use. Not sure when, you'd have to ask Brad.
" Darksiders Rule "
Old 05-09-2009, 08:22 PM
66bonne's Avatar
misterp266: thanks for the post. I also posted this question in the Race forum. The answer I got over there was that the difference is the ring diameter [which means the pinion is also different].
So you're right, a spool for a conventional [non-Ponitac big car] 12 bolt will not work in a Big Car Pontiac.
Thanks for the info, Jim
