Old 06-25-2009, 07:53 AM
Tinindian6702's Avatar
Tinindian6702 Tinindian6702 is offline
Default Quick Help needed-Drum brake question
The car is on the mechanics lift and the meter is running!! I have a 67 firebird with stock 4 wheel drums. I have been having trouble getting a master cylinder and booster.
I ordered a booster and MC from JEGS. Supposed to be the right one for the 67. The mechanic is telling me the rod that goes into the MC is too long. Make a long story short, I ordered the complete booster/MC/prop valve setup from Matts Classic Bowties. It was listed as the right part for the Pontiac. The setup came and it has a metering block that the original setup didn't have. I think it is for disc fronts??? I have 4 wheel drums. Please let me know what you think! Can I use the setup with the distribution valve and not use the metering valve??? Are the MC and booster the same. Thanks
1967 400 Firebird Convertible :
1978 Firebird Esprit
1980 Trans Am Pace Car (SOLD)
2002 RamAir Convertible
Old 06-25-2009, 09:24 AM
quicksilver97ta's Avatar
This should be easy for the mechanic to figure out. Is that metering block a completely separate item? Just have the mechanic replace what has been removed, the booster and master assembly. There should be a distribution block that is suspended under the master- reuse that.
Old 06-25-2009, 01:48 PM
PITTSBURGH 64 PITTSBURGH 64 is offline
You can not use a master cyl for a disc system on a drum system. The drum master has check valves....
I'd send it all back through the US postal service with a delivery confirmation and go down to the local NAPA or let your mechanic order the parts through his supplier.....
Old 06-25-2009, 08:23 PM
tjdjr's Avatar
tjdjr tjdjr is offline
I have a metering block with my 4 drums. should only have to take out the 2 lines from the MC and put them back in the new one.
Old 06-26-2009, 12:42 AM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Call the tech line from where you got it, they should be able to figure it out for you.
Old 06-26-2009, 07:57 AM
Please explain which changes you mean. Thanks
Old 06-26-2009, 09:58 AM
So is the car still on the mechanics lift with the meter running?
What happened?
Old 08-09-2009, 01:22 PM
Reused the old block and everything works. Thanks
