Old 06-28-2009, 07:12 PM
4dr 4dr is offline
Default 15 X 6 rims
I am going for the poverty cap look on my 66, so I got a SS cap and it fits the 15 X 6 rims I got from the junk yard.
My question is, will the rims have enough clearance when I do a front disk brake conversion.
Thx
Steve
Old 06-28-2009, 08:25 PM
66Post's Avatar
66Post 66Post is offline
My understanding is any 15 inch wheel with work with front disk conversion. I have 15x7 sttel wheels on my 66, but no disk brakes.
Old 06-29-2009, 12:04 AM
66 what?
Old 06-29-2009, 09:41 AM
66Post's Avatar
See the picture? 66 GTO
Old 06-29-2009, 09:44 AM
4dr 4dr is offline
Default 15 X 6
66 lemans.
What would be the minimum backspace measurement.
Old 06-29-2009, 01:50 PM
so that would make it a 4dr 66 GTO? you fail.
4dr - backspace is not the issue; the shape of the "bell" in the rim is.
Old 06-29-2009, 02:52 PM
4dr 4dr is offline
Default 15X6
The rims were pulled off an 85 buick.
I forgot to look if they had disks.
I'll spend another dollar to go back into the junk yard.
Should I abandon these and try the 15X7.
Would there be any noticable difference in the look of the tires.
Old 06-29-2009, 09:13 PM
no, your Buick rims will clear quite a few setups, including stock.
Old 07-01-2009, 07:11 PM
66Post's Avatar
Nice post and PR for your LLC.............Good for business right? Now who fails?
Old 07-01-2009, 07:41 PM
We're not Nordy's; if we see you need to be told to get stuffed - we most assuredly will.
Old 07-02-2009, 10:29 AM
4dr 4dr is offline
Default 15x6/Carlisle/Jim Wanger
I have been doing mostly body work the past few years and I am gearing up for the mechanical end. Trying to decide on Scarebird, Right Stuff,or Inline.
I was at Carlisle last saturday and met Jim Wanger, and got an autograph copy of Glory Days. He asked about my four door hardtop, and I said I was adding period correct options to the car such as floor console/shifter, vacuum gauge, bucket seats and such. You don't see many of the 4dr hardtops at the events. Undercoating from the orginal owner saved the metal.
I thoughly enjoy the journey in getting this project completed. Without this forum and meeting people in the hobby, I would have flipped this car.
Old 07-02-2009, 12:05 PM
What 85 Buick did the rims come off of? Most with intermediate patterns were 14" those years - unless you snapped them up off of a LeSabre. Both Right Stuff and Inline Tube are good co.s.
Mr Wangers is a class act.
Old 07-02-2009, 09:45 PM
4dr 4dr is offline
Default 15x6
Yes it was a LeSabre. I was surprised that my bolt pattern template fit when I checked them. I figured it would have been a 5x5 pattern.
Am I better off doing the front suspension and brakes and lines all at the same time.
Old 07-03-2009, 12:36 AM
Yes, especially labor wise. What type of powerplant does this have?
Old 07-05-2009, 05:23 PM
4dr 4dr is offline
Default 15x6
Old reliable 326 dual exhaust 4bbl. with points.
Old 07-05-2009, 11:32 PM
You should have a few choices in brakes - 1969-72 stock is good (especially if you get the OEM spindles and brackets, not repops).
Note: following is biased
We have two setups that work with the drum spindles: one is heavy duty, other is light duty (sole design criteria was to fit inside stock 14" rim, but will work fine with your 326, especially with a S10 booster.)
