Old 06-29-2009, 10:44 AM
cas cas is offline
Default horsepower ?
what kind of horse power would I expect from a stock rebuilt 71' 455 with 6x-8 heads?
motor isn't rebuilt yet. came from 71 big pontiac. been sitting for years.
68' Lemans conv.
69' GTO conv.
Old 06-29-2009, 07:43 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
depends on how much $$ you want to throw at it. I'll say that with a mild/medium build, you could see 415ish
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 06-29-2009, 08:14 PM
goatless's Avatar
goatless goatless is offline
Need more info. Cam is key.
1966 GTO
Old 06-30-2009, 09:31 AM
I had a 455 with 6X heads and T400, it was bone stock (mid seventies Qjet and distributor) in a 69 GTO with muffler shop duals and it pulled almost 200 horse on the chassis dyno, I swapped a set of 71 GTO heads (96?), intake, carb and distributor and a 068 mellings cam and ended up at 250. A stock 350 horse 400 auto GTO pulls about 240 on that dyno and a tuned 455 HO with full but performance exhaust is about 290 just to put things in perspective. Also my 69 Lemans with a 2bbl 350 and T400 pulled only 145.
Old 06-30-2009, 09:33 AM
to convert to gross just multiply my above numbers by about 1.35 to get a ball park number.
Old 06-30-2009, 09:41 AM
cas cas is offline
Sorry for the vague description. I'm just wondering. Now I have a 76' pontiac 350 originally a 2bbl now a 4bbl setup and it's decent and moves the car but won't really break the tires free. especially after I put a 10 bolt posi in over the winter.
I was thinking if new heads would pep it up , but was told that it's not worth the expense.
I do have a 455 that has been sitting for quite awhile. Would need a total rebuild, but as always money is the concern. If I did a budget rebuild, if there is such a thing and put the 6x-8 heads on the 455.then where would that get me.
not sure what heads are on 455. I think they're original to block. Motor came from 71-72 big pontiac
68' Lemans conv.
69' GTO conv.
Old 06-30-2009, 09:47 AM
cas cas is offline
So with North's info I'd be lucky to get 200 net or 270 gross HP. I must only have about 120 now lol
68' Lemans conv.
69' GTO conv.
Old 06-30-2009, 11:32 AM
PontGuy's Avatar
PontGuy PontGuy is offline
I have been in a similar place with my 69 Lemans vert with a mildly built 350. The engine actually pulls nicely at higher RPMs, but it does not have quite enough on the bottom to spin the tires. I am starting a major refurbishment of the car and decided to go with a 455 to wake it up. Nothing really special, a 462 with '71 400 heads and a relatively mild cam. My goal is not to get a ton of extra horsepower, but I want a lot more bottom end torque. The car just has to be able to burn rubber and pull hard to be "right"! Not sure if this is what you are looking for too, but all the extra cubes should get you there. The additional HP whatever it is would be a bonus.
Walt
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 07-01-2009, 11:23 AM
cas cas is offline
Walt, seems we're on the same page. I'm not looking for anything crazy, just enough a$$ to break them loose. Car pulls ok at higher RPM, just not enough torque. Was hoping for a bolt on fix, but I guess I'll have to wait for the 455 sometime in the future.
68' Lemans conv.
69' GTO conv.
Old 07-01-2009, 01:11 PM
PontGuy's Avatar
I've probably got more experience experimenting with Pont 350's than anything else since I used to use them racing dirt track on a budget "back in the day". We were limited to 360 CI so the 400s were out, and the bigger engines probably would have overheated like crazy anyway. Found the Pont 350s were about bullet-proof which was a big plus. Tried all kinds of heads, valve sizes, cams etc. Was able to build engines that had great mid range and top end power, but the bottom was always a bit anemic no matter what I did. Of course bottom end torque is really not important for dirt track racing so it was not a problem. By the way I was very competitive running the Pontiac mills against the top Chevy and Ford guys which all of them found surprising. It was lots of fun but way too much time and work and I wanted to stay married so I had to give it up.
But the bottom line.. I don't know of a bolt-on fix that would give the 350 the bottom end grunt that we are both looking for.
My new 455 is still sitting in the crate and it looks like it will still be some months before I will be ready to drop it in. Can't wait to see what it does!
Walt
Old 07-01-2009, 01:27 PM
goatless's Avatar
The way to give that 350 more bottom end (or at last feel like it) is to put a steeper gear in the rear end.
The beauty of the 455 is that it'll have tons of torque just about any way you build it. Even with highway gears it'll still roast the tires any time you want.
1966 GTO
Old 07-01-2009, 01:28 PM
cas cas is offline
good luck with it.
what's a good source of info for me to get to learn about the pontiac motors and heads? seems cofussing to me
68' Lemans conv.
69' GTO conv.
Old 07-01-2009, 01:50 PM
Ron Landis's Avatar
Wink I'd say...
shave the 6-X heads @ .020 or so and use either an 068 cam with present gearing or a 744 stick with stiffer gears, as mentioned. I've seen some relatively strong 350s. Do not abandon the 455 project, as there is still no substitute for cubes. Put a 2400 stall converter in it to hit the tires a little harder and get you into the power band. You'll be amazed! GM did that on their 375 hp Camaros and Chevelles. Don't be intimidated by the numbers. Those are flash stall...not brake stall numbers.Good luck. Ron
Old 07-01-2009, 07:23 PM
BVR421's Avatar
BVR421 BVR421 is offline
Originally Posted by cas View Post
good luck with it.
Drop by your local bookstore or Amazon.com and pick up a copy of Jim Hand's excellent book "How to build High Performance Pontiac Engines" History, part numbers, his own HP street success, recipes from mild to wild from renowned Pontiac engine builders.
also these links
classicalpontiac.com
http://psp.aquacomp.net/
pontiaczone.com
Pontiacheaven.com
wallaceracing.com
and many more....
dogpile.com is your friend
Old 07-01-2009, 10:00 PM
PontGuy's Avatar
I haven't read Jim Hands book, but probably a good place to start if you are new to all of this.
The problem with the 350 is not that it won't make good power, I proved that to myself at the racetrack. The challenge is getting it to make good power, and bottom end torque, and be streetable down the interstate- all at the same time. Also there is much less good info available on how to set up a 350 compared to the 400 and 455 engines.
So what heads are suitable for a 350... all 350-455 CI heads will physically fit, but that doesn't mean that they will work well.
The 6X-8 heads are the 101 cc ones, right? If the pistons are stock flat tops then the CR with 101 cc heads would be extremely low (without milling them) which would be very bad for performance. A 72 cc head is about right for a 350 with flat top pistons running today's pump gas. I also learned that you have to be careful with big valves on a 350 engine since the distance across the valves can actually be bigger than the bore, which limits how much valve lift you can have without cutting reliefs. Too much lift and the valves will hit the cylinder walls. And most of the newer-style cams have much higher lifts than the original Pontiac grinds.
If you haven't already found one here is a link to a site that lists stats for all the Pont heads: http://www.angelfire.com/on/geebjen/heads.html
I built my current 350 about 15 years ago and it is pretty well worn out. It has '67 #061 heads, 72 cc with 2.11/1.77 valves. I cut reliefs in the bores for the big valves and installed a Crower cam with 210/221 duration. The rest of the build was pretty much standard performance stuff. This engine was an attempt at finding "the middle ground" since I wanted to run a street gear. Results were mixed. Off the line with the 'vette converter its probably not much stronger than a stock 60's vintage 2bbl, but it pulls hard once it gets moving and the redline is up around 6000. With a big gear and converter it might even turn in some respectable times. But then it wouldn't be much fun on the highway.
More cubes makes things a lot easier and in the end, I think building the 455 would make you happier.
Walt
Old 07-01-2009, 10:26 PM
I built a 455 for daily use some years back, using all factory Pontiac parts or repros of them.
It had stock 114cc #66 1971 455 heads (8.2:1 compression) and a '66 Tri-Power setup along with repro '67 GTO HO exhaust manifolds. Cam was the Crane 'blueprint' 068 cam (one step above the 067 which came in most stock 'standard' 455 4-barrel engines), which is said to not be as good as the OEM Mellings version. I put some good used stamped-steel RAIV 1.65:1 rockers on it too.
This is about as stock as it gets for a 455. The Tri-Power setup was mostly for looks, a well-setup Q-jet on a stock iron intake would easily equal it in performance or at least come very close to it.
Horsepower at the flywheel was estimated at 328. The 1/4-mile MPH (101.85) and car weight with driver (3980) along with the ET (13.899) were entered into the calculator on the SD Perfomance website to arrive at the 328 HP figure.:http://sdperformance.com/calc_hpet.p...=3980&check2=1
Horsepower according to the ET was considerably lower at 293, but ET is a better measure of traction than horsepower. The car was very traction-limited and geared quite tall (2.56 open rear with 235/45-17 street radials).
Old 06-14-2016, 10:41 PM
cas cas is offline
Here 's a belated thanks for all the replies back in 2009. I don't know why I never got back to this post.
Anyway as of yesterday the 455 is in the machine shop getting checked out, I got the cam out and called the manufacturer for specs, Erson.
Ill get back with the info I found out
68' Lemans conv.
69' GTO conv.
Old 06-18-2016, 02:06 AM
Darth Menace Darth Menace is offline
Old 06-18-2016, 06:36 AM
cas cas is offline
Very funny, I know, it's been awhile. I guess i could start a new thread. Now i. I'm looking for all the info i have written down over the years.
68' Lemans conv.
69' GTO conv.
Old 06-18-2016, 08:11 PM
I know how it is. I resurrect old posts from myself or others, beats starting new ones and having people complain you could have used the search function (I am not meaning on this forum). I do love going back and getting the info on a project maybe you put off for too long, and it is all still waiting for you. I wish I had the same help on the Viper forum as I have here. Post some pictures of the 455 when it is up and running
